Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 13, 2017 at 3:12 PM
    #4181
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    1.5 months is not bad, I waited for 8 months for my whole kit from KOracing, it was worth the wait though. I like the forward intake manifold for the shorter piping run, it not good having a big U bend on the intake track, not to mention I have 2 more right off my intercooler. It would cut almost 2 feet off the run.
    MrCrowntown and Torspd like this.
  2. Nov 13, 2017 at 3:43 PM
    #4182
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Sehksi af!
    Jcyr[QUOTED] likes this.
  3. Nov 13, 2017 at 7:09 PM
    #4183
    yota243
    E.J.
    north Alabama
    Screenshot_2017-11-13-21-06-19.jpg so much more boost will be going into my engine instead of just whirling around in my engine bay!:burnrubber:
    Also glad i didnt pay the extra ~$30 for 2 day shipping... And there was no way i was paying for over night haha
    05Taco4x4 likes this.
  4. Nov 13, 2017 at 7:10 PM
    #4184
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    You need to stop, how can I not “like” this?
  5. Nov 13, 2017 at 7:11 PM
    #4185
    yota243
    E.J.
    north Alabama
    @Torspd you wouldnt happen to know where to get a maf sensor o-ring would you?
  6. Nov 13, 2017 at 8:00 PM
    #4186
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    took a look at my manifold studs. Im probably gona have fun taking them off...
  7. Nov 13, 2017 at 8:26 PM
    #4187
    05Taco4x4
    2TR-FE Enthusiast
  8. Nov 13, 2017 at 8:32 PM
    #4188
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Toyota or O'Reilly's perhaps.
    yota243[QUOTED] likes this.
  9. Nov 13, 2017 at 8:40 PM
    #4189
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No knock control. Doesn't have the ability to long term trim learn where any knock is, amd pull back timing in those cells, to prevent knock. That is my only concern.
    Unless you find a way to circumvent what it has, and connect it to read a knock sensor some how.
  10. Nov 13, 2017 at 8:43 PM
    #4190
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Are yours fighting coming out as well?
  11. Nov 13, 2017 at 8:46 PM
    #4191
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
  12. Nov 13, 2017 at 8:54 PM
    #4192
    05Taco4x4
    2TR-FE Enthusiast
    OK, so it looks like the E1000 will work, methanol, flex fuel and all?
  13. Nov 13, 2017 at 9:08 PM
    #4193
    devinzz1
    devin
    2023 aclb trd or mt
    haven't tried. I removed the crossover pipe earlier and snapped 3 out of 4 studs after having them soak in penetrant and heating them to the point of glowing. Il keep my fingers crossed. It will probably be over a month till i get around to installing them. cxracing hasn't even shipped them yet.
  14. Nov 13, 2017 at 9:23 PM
    #4194
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    E1000 has knock control but no long term knock control. It will correct knock but not learn.
    Torspd likes this.
  15. Nov 13, 2017 at 10:30 PM
    #4195
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Just for anyone that wants to download and play with the Haltech software here is the Map I am running. If you so choose to run this please verify all wiring or just import the tables only.
    This Map is running
    Injectors ID725's
    Fuel pressure regulator is referenced to MAP including vacuum
    running a Haltech air temp sensor, knock sensor
    MAC boost control solenoid
    Haltech Wideband
    and an after market speed sensor
  16. Nov 14, 2017 at 5:29 AM
    #4196
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @MadTaco461 , time to get a Haltech.....:boink: Black Friday sale perhaps???:D
    MadTaco461 and Jcyr like this.
  17. Nov 14, 2017 at 7:45 AM
    #4197
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You can download the software for free?
  18. Nov 14, 2017 at 8:03 AM
    #4198
    Ricky876
    Ricky876 Well-Known Member
    2002 Toyota Space Cab
    Under construction
    Question for you guys.... ive recently turboed my Tacoma im not sure what the oil pressure was before or what it is now i need to get a gauge installed but for my turbo oil feed i tapped into the block beside the oil filter
    im running a holset hx35 on my set up no restrictor.... what should the oil pressure be like at idle
    what recommended grade oil can i run?
    heres a pic of my set up
    RedLantern, Jstand and yota243 like this.
  19. Nov 14, 2017 at 8:04 AM
    #4199
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Straight off of their main website. Yes.
    MadTaco461[QUOTED] likes this.
  20. Nov 14, 2017 at 8:05 AM
    #4200
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Does it have its own restrictor?
