Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 14, 2017 at 7:02 PM
    #421
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Thanks to everyone for the comments on the turbo matches that I posted. I went back through and made new matches using the EFR 7670 maps. I matched the turbine to the 70mm 0.92 A/R. For whatever reason, the MatchBot doesn't show the 70mm 1.05 A/R turbine.
    Sea level, summer
    Sea level, winter
    During the winter @ 10000 foot elevation, it's still running up against the choke line at redline. I live at sea level and would almost never be at that elevation, so I can live with it. I made the 10k elevation matches more for an exercise to see how things are affected and because I might end up at that elevation at some point travelling.
    Mountains, summer
    Mountains, winter
    The maps show I'll still able to build boost down at 2k RPM. :D Depending on gear and throttle position, I can make 5-10 PSI at ~2k RPM in my WRX, so I'm not too worried about drivability. I also want to make boost as low as possible given the 5500 RPM redline of the 2TR-FE. It'd be a waste to only have boost over 3k RPM when I generally only see over that when I'm passing people.
  2. Apr 14, 2017 at 10:15 PM
    #422
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    @Torspd Trucks not broken anymore!:yay:
    Don't have my wideband back from AEM yet but my LT and ST fuel trims are pretty normal.
    I rebuilt my CX turbo and it's even tighter than it was before which is good.
    I also installed a non homemade boost controller, made my key halo thing red and replaced the factory clock with a boost gauge. I'll post pics tomorrow of stuff and things.
    I noticed that the factory injectors may be de-capable for free extra flow. I may decap one of my extras and see what happens...
    MrCrowntown, boostedka and Torspd like this.
  3. Apr 14, 2017 at 11:10 PM
    #423
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Two good posts. I like where these things are headed.
    MrCrowntown likes this.
  4. Apr 14, 2017 at 11:25 PM
    #424
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well good news...you'll never be at 10k feet during the winter. Haha at least not for long normally even if you can as everything gets snowed in so...yeah.
    I know a guy on the supra forums used to rebuild oem injectors with custom nozzle ends for cheap to make them whatever flow you wanted. Made mine 650cc
  5. Apr 15, 2017 at 8:04 AM
    #425
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    :transformer:
  6. Apr 15, 2017 at 8:16 AM
    #426
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Did you have to re balance the turbo during the rebuild? Or just a straight swap of parts?
    CX has been more than amazing to me personally with customer service. When my turbo was making noise they sent me a rebuild kit FREE. And it turned out to not even be the turbo........
  7. Apr 15, 2017 at 10:19 AM
    #427
    Brice
    Brice Turbo Member
    Brice
    Texas
    I just straight up swapped the parts out. It seems that the compressor wheel was already balanced at some point, the turbine too. I think my turbo was used before I bought it but I'm not 100% sure. I think all turbos are balanced otherwise I think they'd explode... However I'm no expert. :transformer:
    Torspd, boostedka and yota243 like this.
  8. Apr 15, 2017 at 12:10 PM
    #428
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    This makes me happy in pants
    buyobuyo[QUOTED] likes this.
  9. Apr 15, 2017 at 1:44 PM
    #429
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So is this the size that you are finalized on?
  10. Apr 15, 2017 at 2:46 PM
    #430
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    :confused:NOOOO !!!! WHYYYYY !!! THIS SUCKS !!! There was a high pitch squealing noise when I got off the freeway and then 0 boost:annoyed:
  11. Apr 15, 2017 at 2:48 PM
    #431
    Brice
    Brice Turbo Member
    Brice
    Texas
    Daaaaaaaaaaang
    Oil line size? restrictor to small?
  12. Apr 15, 2017 at 2:48 PM
    #432
    Jstand
    Irving,Tx
    I bought the turbo used and it had a fresh rebuild 0 miles:annoyed:
  13. Apr 15, 2017 at 2:50 PM
    #433
    Brice
    Brice Turbo Member
    Brice
    Texas
    Did you check shaft play prior to install? Also what oil line size did you use?
  14. Apr 15, 2017 at 2:51 PM
    #434
    Jstand
    Irving,Tx
    Oil line 4an not sure on the size of restrictor but i've been having a problem with oil leaking from the oil return fittings unless it was the turbo
  15. Apr 15, 2017 at 2:53 PM
    #435
    Brice
    Brice Turbo Member
    Brice
    Texas
    Hmm Id check that restrictor. Is it all ball bearing, journal-ball hybrid or all journal?
  16. Apr 15, 2017 at 2:53 PM
    #436
    Jstand
    Irving,Tx
    I checked shaft play and it seem to me like it was too much but after looking at a YouTube video of a Percision turbo with a fresh rebuild with the same play I thought it was ok
  17. Apr 15, 2017 at 2:54 PM
    #437
    Jstand
    Irving,Tx
    All journal model 5431E
  18. Apr 15, 2017 at 2:55 PM
    #438
    Brice
    Brice Turbo Member
    Brice
    Texas
    Yeah if I understand correctly journals need more oil flow. You have a 3rz?
  19. Apr 15, 2017 at 2:57 PM
    #439
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Hm weird. Usually don't need restrictor for journaled bearing. What size is your drain?
  20. Apr 15, 2017 at 2:58 PM
    #440
    Brice
    Brice Turbo Member
    Brice
    Texas
