Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 21, 2017 at 8:53 PM
    #4461
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That thing scoots now!
    yota243[QUOTED] likes this.
  2. Nov 22, 2017 at 5:20 AM
    #4462
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I'm running the pink top 325cc
  3. Nov 22, 2017 at 5:28 AM
    #4463
    Jstand
    Irving,Tx
    I lost track with all the pages but is yours the 3rz ?
  4. Nov 22, 2017 at 5:29 AM
    #4464
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    1gr, Bromantic comedy
    Jstand[QUOTED] likes this.
  5. Nov 22, 2017 at 6:10 AM
    #4465
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You're making me want to make an acceleration video.
  6. Nov 22, 2017 at 6:11 AM
    #4466
    yota243
    E.J.
    north Alabama
    this is literally the only reason I even did this, I was like "wonder what I can do to get more tor videos"
  7. Nov 22, 2017 at 6:14 AM
    #4467
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh: Whatever.
  8. Nov 22, 2017 at 6:15 AM
    #4468
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Tor got any vids of that stroker?
  9. Nov 22, 2017 at 6:24 AM
    #4469
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A few. No acceleration videos though. It wasn't until recently that the tune was good enough to make one. Prior, on the OEM ECU, it was a pig. Timing was pulled a lot, due to the intake cams not phasing. Since they are locked. Wasn't a happy ECU.
    Then after a long while, I installed the Haltech. Took my time tuning and refining. Drove great, compared to factory. Was still down on power for what I felt it should be.
    Swapped to large injectors and had to retune the fuel map. These being the injectors for the turbo, I now was able to refine and adjust timing as necessary. After a fun run, to get a point of reference, I adjusted the timing map a little more.
    Runs just a little slower than a 5vz with ~6 psi. Not bad I'd say, for N/A. @Brice knows the exact PSI.
    Brice, TacoLeeSD, RedLantern and 3 others like this.
  10. Nov 22, 2017 at 8:29 AM
    #4470
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    What size are stock? And what duty cycles are you running at WOT? I tend assume the stock ecu is around 70-80% at WOT and with that assumption you highest fuel cell in the FIC shouldn't be over 0, i.e. a positive number.
    Oh and e85 uses about 30% more fuel than petrol so I think you might be hitting a wall on that front.
    Brice, Torspd and Jstand[QUOTED] like this.
  11. Nov 22, 2017 at 8:56 AM
    #4471
    Jstand
    Irving,Tx
    Stock is around 280cc and not sure the duty cycle too bad ai cant put slightly bigger injectors
  12. Nov 22, 2017 at 9:14 AM
    #4472
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    There isn't a kit for the 5vz either, just a bucket of random parts that kind of fit together, enough that the hood will latch :D
    If I did this again it would definitely be custom. I think there is quite a bit of performance/efficiency left on the table with the cx kit, it was pretty clearly designed from a packaging standpoint. There is a documented 5vz custom turbo build somewhere in the depths of this site and the thing was making like 350 whp on 9 psi on something tiny like a 50 mm inducer.
    Brice and yota243[QUOTED] like this.
  13. Nov 22, 2017 at 9:17 AM
    #4473
    yota243
    E.J.
    north Alabama
    well I can prolly count the welds on both hands that weren't made by me or one of the other two guys that helped me, and that's including inside the muffler haha
    Clay_916[QUOTED][OP] likes this.
  14. Nov 22, 2017 at 9:22 AM
    #4474
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Sounds like a new business venture :thumbsup:
  15. Nov 22, 2017 at 9:24 AM
    #4475
    yota243
    E.J.
    north Alabama
    I actually asked the other guys what they thought about making hot side kits "HELL NO!" was the jist of the response haha
  16. Nov 22, 2017 at 10:36 AM
    #4476
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    pretty much right at 6psi :D Im at 10 or so now. With a little more fuel on the top end i'll be golden.
    MadTaco461 likes this.
  17. Nov 22, 2017 at 10:46 AM
    #4477
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just you wait, homeslice. Get a diff, and it'd be quite entertaining to see what it runs at Royal Purple Raceway.
    Brice likes this.
  18. Nov 22, 2017 at 1:12 PM
    #4478
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Did some measurements. Changes in my future.
  19. Nov 22, 2017 at 2:27 PM
    #4479
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Valvebody mod next?
  20. Nov 22, 2017 at 2:30 PM
    #4480
    Jcyr
    Jack
    North east
    Any turbo related deals for Friday???
