Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 28, 2017 at 10:16 AM
    #4541
    Ricky876
    Ricky876 Well-Known Member
    2002 Toyota Space Cab
    Under construction
    ill go forged internals if i get bored with this power
    forged internals id run 20psi
    Looool yea that flywheel failing wasnt no joke everything ripped apart
  2. Nov 28, 2017 at 10:19 AM
    #4542
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Would you stay with the 5vz or try a diff engine? Those Pauter rods are like $1,600 for the set.
  3. Nov 28, 2017 at 10:25 AM
    #4543
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Cheaper than Carrillo CP....
  4. Nov 28, 2017 at 10:28 AM
    #4544
    Ricky876
    Under construction
    only other setup id go is JZ as long as i can keep my 4wd sure
  5. Nov 28, 2017 at 10:30 AM
    #4545
    Ricky876
    Under construction
    we have a drag event in December gonna run and see what i do on the quarter
    i ran 15.0 with the supercharge setup at 230hp..
    hope i can pull a low 13 or high 12
  6. Nov 28, 2017 at 10:39 AM
    #4546
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What kind of wheel hop, if any, does your truck have off of the line?
  7. Nov 28, 2017 at 10:42 AM
    #4547
    Ricky876
    Under construction
    oh i launch in 4wd.... pointless launching in 2wd... feeel like the back end want to leave the chassis lool:annoyed:
    Torspd[QUOTED] likes this.
  8. Nov 28, 2017 at 11:00 AM
    #4548
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I weigh 3600lb on 9psi and run a 11.4 1000' which is ~13.7 quarter mile. Depending on how much you weigh, that might be low 13 high 12.
    Oh that's with a 2.1 60' time because I can't boost off the line without drag radials- it just blows up stock tires.
    Jstand likes this.
  9. Nov 28, 2017 at 11:01 AM
    #4549
    Ricky876
    Under construction
    niceeee you have a build thread??
  10. Nov 28, 2017 at 11:05 AM
    #4550
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Sorry not on this truck.
  11. Nov 28, 2017 at 11:39 AM
    #4551
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Where’s the dislike button? ;)
    MrCrowntown likes this.
  12. Nov 28, 2017 at 11:49 AM
    #4552
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can retain 4wd and run the same tranny even. Bolts right to a 2jz. Need to run electric fans though due to length of motor. Plenty of other custom shit too. But very doable.
  13. Nov 28, 2017 at 11:50 AM
    #4553
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    cxracing website has 15% off for 4 more days; promo code is bkfrd17sub
    05Taco4x4 likes this.
  14. Nov 28, 2017 at 11:52 AM
    #4554
    Ricky876
    Under construction
    niceee well here in jamaica a 2jz or 1jz is cheaper than a 5vz engine
    5VZ engine $350,000JMD equivalent to 2600us
    1JZGTE $150,000- $200,000JMD equivalent to 1100us - 1600us
  15. Nov 28, 2017 at 11:56 AM
    #4555
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wouldn't bother personally with a 1jz. Too small and too much of a hit on low end torque. Especially for a truck. 2jz all day. Only other down side is parts for those fuckers are insane.
    Ricky876[QUOTED] likes this.
  16. Nov 28, 2017 at 11:59 AM
    #4556
    yota243
    E.J.
    north Alabama
    it kinda sounds like you need to sell your 5vz and buy a 2jz and put ~$1000 usd in your pocket
    MadTaco461 likes this.
  17. Nov 28, 2017 at 12:36 PM
    #4557
    Ricky876
    Under construction
    LOOL this is tru
    MrCrowntown and yota243[QUOTED] like this.
  18. Nov 28, 2017 at 2:52 PM
    #4558
    Blackdawg
    Monte
    Wyoming/St. Louis
    if only it were that simple..
  19. Nov 28, 2017 at 6:07 PM
    #4559
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Engine bay officially naked!!!
    Unfortunately i have a few long days at work coming up but hope to be putting fun stuff in this weekend :) :)
    I do still need to do the fuel pump and stuff I’m gonna decide weather or not I’m replacing all fuel lines once i pull the bed off and get a better look.
  20. Nov 28, 2017 at 6:48 PM
    #4560
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Fuck yeah :thumbsup:
    Jcyr[QUOTED] likes this.
