Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 29, 2017 at 5:21 PM
    #4581
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    And a $2M printer. This is a pretty vast topic that I’m not entirely educated about but I do know a very high percentage of printers are used to meet the form of the part and not the function. Ie the material properties are not suitable.
    There are only a few companies that have the capabilities to print engineering spec materials.
  2. Nov 29, 2017 at 5:32 PM
    #4582
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I can't wait for 3d printed ss turbo manifolds. Lightweight. Can do complex shapes. No welding!
  3. Nov 29, 2017 at 5:38 PM
    #4583
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    3d printing metals is hot in aerospace and defense. I'll be surprised if it hasn't expanded beyond that in 5-10 years.
    MadTaco461[QUOTED] likes this.
  4. Nov 29, 2017 at 5:43 PM
    #4584
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Most of the time, yes- a 3D printer is used for mockup to help save cost on production. That's just what they're purposing them for. Since 3D printing is all CAD-based, it can be as precise as a CNC or waterjet. The material you print with is your choice (based on what the printer can accept), as well as the infill (density) of it.
    This is 10%, 25%, then 50% infill, in a simple diamond pattern. Honeycomb pattern ups the rigidty by about 20%, or for ultimate strength, go solid (100% infill).
    There's lots of stuff you can 3D print for automotive- including gauge pods!
  5. Nov 29, 2017 at 5:57 PM
    #4585
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have actually. Which is why i would still just grab some steel and make a part that would with stand my driving more so than plastic that could...probably would..stress fracture after a few thousand hard ass miles.
    But thats just me and I drive on a lot of dirt.
  6. Nov 29, 2017 at 6:24 PM
    #4586
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Has anyone ever suddenly had high oil pressure ?
  7. Nov 29, 2017 at 6:27 PM
    #4587
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Try some carbon reinforced stuff. I had a professor doing research work with 3d printers, he'd regularly make parts stronger than milled aluminum at half the weight. But our printers were like 40k printers lol
    dirtdigginjoe likes this.
  8. Nov 29, 2017 at 6:36 PM
    #4588
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    MadTaco461 and Blackdawg like this.
  9. Nov 29, 2017 at 8:35 PM
    #4589
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    The automotive industry has been using plastics for quite a while... and it simply doesn’t last. Even glass imbedded plastic snaps after enough heat cycles and vibration. I wouldn’t use anything besides steel to mount anything that I couldn’t afford to break off. Not even aluminum is trustworthy in some cases
  10. Nov 30, 2017 at 6:38 AM
    #4590
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Which brand gauge? What does it read with the vehicle off?
    I am feeling that the sensor is bad, or the gauge is.
    Jstand[QUOTED] likes this.
  11. Nov 30, 2017 at 6:40 AM
    #4591
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Laser metal sintering? Pff I've got two machines.
  12. Nov 30, 2017 at 6:50 AM
    #4592
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    book marked for mods after turbo is done and raptor liner is applied
    BassAckwards likes this.
  13. Nov 30, 2017 at 7:32 AM
    #4593
    MadTaco461
    CA
    Kinda stock
    Jealous
  14. Nov 30, 2017 at 8:06 AM
    #4594
    Blackdawg
    Monte
    Wyoming/St. Louis
    whys it taking so damn long to get your SS headers done then? :D
  15. Nov 30, 2017 at 8:28 AM
    #4595
    Jstand
    Irving,Tx
    It’s a glow shift and I’m hoping just the sensor I would hate to have engine troubles I’m going to be putting the 440’s in next week and I did find some boost/vac leaks one at the maf
  16. Nov 30, 2017 at 9:54 AM
    #4596
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Because inconel powder life. Ain't cheep....yo
    Blackdawg[QUOTED] likes this.
  17. Nov 30, 2017 at 9:56 AM
    #4597
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cheap is as cheap does. Being at "0" psi oil pressure at idle, is my first indication of a problem with your sensor. Lest your oil be filled with metal shavings.
  18. Nov 30, 2017 at 12:46 PM
    #4598
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Just got a sharp looking gauge in from @arcenik :thumbsup: awesome packaging man everything was perfect thank again!
    MadTaco461, Jstand and Torspd like this.
  19. Nov 30, 2017 at 6:08 PM
    #4599
    Jcyr
    Jack
    North east
    Once again I’m pleasantly surprised with how good she looks after 170k B377D35B-D89E-427C-8824-D1C0F9FFEB2A.jpg
    05Taco4x4, Jstand, boostedka and 3 others like this.
  20. Nov 30, 2017 at 6:27 PM
    #4600
    MadTaco461
    CA
    Kinda stock
    Checking your valve clearance?
