Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 6, 2017 at 2:27 PM
    #4701
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I think a modified short tube design, with the outlet of the header curving downward into the turbine housing inlet would work. Garrett has reverse and forward turbos, for this exact reason. Tuck each up close to the trans.
    RedLantern likes this.
  2. Dec 6, 2017 at 2:55 PM
    #4702
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Tor care to school me on what thats used for?
  3. Dec 6, 2017 at 3:03 PM
    #4703
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Deforms the block to the way it acts when the cylinder heads are torqued down. Then you bore the cylinder to get them truly round. They may return to an oval shap with the plates removed, but once you torque down the heads the cylinders return to their round shape.
    Otherwise, without them, there is a high probability to have the cylinders ovalize once the head is installed.
  4. Dec 6, 2017 at 3:13 PM
    #4704
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    The more I look at it I think in the front passenger corner will be best. Looking at urd long tube headers and build a crossover with a flange for the turbo. Not sure if long or short tube will be better. But in that location it will make plumbing cleaner I think, plus I can run the exhaust out the front fender with a small muffler tucked up high in the fender. Planning on using @OVTune self tuner and percision turbo, probably around 68mm but not sure yet. I'll be lurking this thread asking silly questions and am gonna get a parts list going. Still not sure how much boost this motor can handle, I'd like to run around 8psi but don't won't any problems since I'm not interested in building this motor
    MrCrowntown likes this.
  5. Dec 6, 2017 at 3:19 PM
    #4705
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds good. Short tube on the passenger side can make for some extra room for all of the tubing. The PowerFab kit used a pair of short tubes, to keep the primaries at least "equal." Mine is effectively a short tube on the passenger and long tube on the driver.
    dirt addiction likes this.
  6. Dec 6, 2017 at 3:36 PM
    #4706
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    I totally wanna two step my Taco so I can machine gun shot the exhaust.....can the fic6 be tuned to do that?
    MadTaco461 likes this.
  7. Dec 6, 2017 at 3:44 PM
    #4707
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Yes, it can- but not easily. You also need to add in a limit switch, and run some wiring into the underhood fuse box...there's a DIY here, on ScionLife that many people have used.
    Best bet is to get an N2MB WOT Box, as it's confirmed working/compatible with the FIC-6, and is independently tuned. This is the route I'll be going, as it also offers No Lift Shifting and more tunability....and it's less ghetto.
    j0shu4[QUOTED] likes this.
  8. Dec 6, 2017 at 5:17 PM
    #4708
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I thought two step was lowering the rev limiter in neutral (2 rev limiters) so that you can launch without burning out... no?
    I’m fairly certain that anti lag is what you want... which retards the timing enough at high RPM’s (at the rev limiter) to allow the unburnt fuel to ignite mostly in the pre-turbo headers instead of the cylinders which spins the crap out of the turbo and makes terrorists say “alahu akbar” when they hear it :cool:
    j0shu4[QUOTED] and MrCrowntown like this.
  9. Dec 6, 2017 at 5:29 PM
    #4709
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Watch these- it should help. 2-step is more of a rev-limiter that will still help you build boost. There's literally 2 steps (see what they did there) of cutting igniton. Also regarded as a "soft cut" and a "hard cut." Anti-lag is retarding timing to cause the combustion in the manifold as you said. This helps build boost MUCH faster
    j0shu4 likes this.
  10. Dec 6, 2017 at 5:31 PM
    #4710
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I cant wait for a nice ignition cut 2 step :annoyed:
    dirtdigginjoe likes this.
  11. Dec 6, 2017 at 5:44 PM
    #4711
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I can't wait for you to start working on your truck. :annoyed:
  12. Dec 6, 2017 at 5:47 PM
    #4712
    MrCrowntown
    Alyn
    Ky
    This was yesterday
    Sometimes, fuck the desert lol
    05Taco4x4, j0shu4, RedLantern and 4 others like this.
  13. Dec 6, 2017 at 6:02 PM
    #4713
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    My front end is just like that too!
    Jcyr and MrCrowntown[QUOTED] like this.
  14. Dec 6, 2017 at 6:06 PM
    #4714
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Hey this thread again
    Jstand, MadTaco461, boostedka and 2 others like this.
  15. Dec 6, 2017 at 6:55 PM
    #4715
    Jcyr
    Jack
    North east
    As does mine #twturbosdoinwork
  16. Dec 6, 2017 at 6:56 PM
    #4716
    MrCrowntown
    Alyn
    Ky
    I am also battling my alignment lol I fucked with the heims once and now im chasing my ass
    MadTaco461[QUOTED] likes this.
  17. Dec 6, 2017 at 7:06 PM
    #4717
    Brice
    Brice Turbo Member
    Brice
    Texas
  18. Dec 6, 2017 at 7:36 PM
    #4718
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As would mine, were I not DD'ing it...
    Jstand likes this.
  19. Dec 6, 2017 at 8:49 PM
    #4719
    GioGuitarDude
    Gio
    Cold air intake
    Yo dudes, is front CV axle play in all directions besides in and out normal? My front dif is leaking and I can move both CV’s up and down /side to side about 1/4” within the front dif. Or is it just bad seals? I get mixed messages in the various threads I’ve read
  20. Dec 6, 2017 at 9:04 PM
    #4720
    MadTaco461
    CA
    Kinda stock
    Never fun. I’m changing all my heims so I gotta do my alignment too. I feel better I’m not the only one doing a butt ton of maintenance.
    MrCrowntown[QUOTED] likes this.
