Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 21, 2017 at 3:04 PM
    #5081
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    They should take some pressure to seat, but not difficult.
  2. Dec 21, 2017 at 3:17 PM
    #5082
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    leaking at the cup will not make you lose fuel pressure it could cause a vacuum leak. If you were leaking at the top of the injector it could cause pressure to drop. Do you have an upgraded fuel pump?
    Torspd likes this.
  3. Dec 21, 2017 at 3:35 PM
    #5083
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Yes the pump is upgraded and I think I have those two issues at the same time vacuum leak at the cups but it could be the insulators and fuel pressure drop at the top. I can’t think of another reason.
  4. Dec 21, 2017 at 5:37 PM
    #5084
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Is it leaking fuel from the top of the injectors?
  5. Dec 21, 2017 at 7:25 PM
    #5085
    Jstand
    Irving,Tx
    I didn’t see anything but that pressure is going somewhere I just have to keep looking
  6. Dec 21, 2017 at 7:28 PM
    #5086
    Jstand
    Irving,Tx
    I just wonder if the insulators and o-rings are compatible with e85 :eek:
  7. Dec 21, 2017 at 8:50 PM
    #5087
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
  8. Dec 21, 2017 at 11:30 PM
    #5088
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I think you looking in the wrong area, I would check your fuel pump or your FPR. You could at idle give the FPR a little boost with some compressed air to see if the fuel pressure rises.
    Jstand[QUOTED] and Jcyr like this.
  9. Dec 22, 2017 at 3:03 AM
    #5089
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am curious if him blipping the throttle makes the engine pull more vacuum than at idle, since there isn't any load on the engine? Were that to be true, then the increased vacuum would reduce the fuel pressure as seen by the gauge. I will double check on mine in a bit.
  10. Dec 22, 2017 at 4:01 AM
    #5090
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    About to reseal my valve cover should I remove and reseal the half moons? They previously didn’t leak...
  11. Dec 22, 2017 at 5:52 AM
    #5091
    Jstand
    Irving,Tx
    It does the same thing when driving. I'm going to replace the o-rings and insulators just because when I do boost/vac leak check and put 10 psi of air it leaks down in about 5 sec. I spray soapy water all around everything and you can see the bubbles and hear the leak from the injector cups. I think its the insulators but this problem was gradual after the injectors where installed. I guess it could be the FPR its not the original I just recently got it from Advanced Auto Parts. Would the e 85 mess up the FPR or insulators:notsure:
  12. Dec 22, 2017 at 5:55 AM
    #5092
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    (with a 1000hp 2jz but still, also broke something after his 3 pass but STILL!)
  13. Dec 22, 2017 at 6:43 AM
    #5093
    Jstand
    Irving,Tx
    I'm starting to wonder if the e85 has been eating away at the FPR :notsure: and the injector insulators
  14. Dec 22, 2017 at 7:58 AM
    #5094
    Jcyr
    Jack
    North east
    Just get an upgraded aeromotive fpr
  15. Dec 22, 2017 at 8:20 AM
    #5095
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you have a fuel pressure gauge in the cab as well?
    E85 does require seals and hoses to be of a specific formula so as not to be damaged. This is why products are labeled as ethanol rated. That is a possibility.
    I'll say this though. Every time you mess with E85 or something else other than gasoline, you run into issues. Easy where to point a finger.
    Jstand[QUOTED] and Sacrifice like this.
  16. Dec 22, 2017 at 8:44 AM
    #5096
    Jstand
    Irving,Tx
    No gauge inside but yea I'm thinking to go back to 93 and replace the above things and see what happens.
  17. Dec 22, 2017 at 8:49 AM
    #5097
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    I just put an ecu on my 3.0 d4d turbo diesel.
    It installs on the fuel rail.. there is a definate difference with it.. the low end is much better acceleration is better plus smoother and more power. Well worth the money.
    I bought it on ebay... the website is http://the-black-one.com
  18. Dec 22, 2017 at 10:18 AM
    #5098
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is a good start.
    Blipping the throttle without load does increase the vacuum. Inturn reducing vac/boost referenced fuel pressure.
    Even without a gauge in the truck, I can promise the fuel pressure isn't doing the exact same as in your video. Your multiple vacuum leaks are what are making your AFR's and operation unsteady.
    Jstand[QUOTED] likes this.
  19. Dec 23, 2017 at 8:00 AM
    #5099
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    I may be wrong but if I remember right he did have a J series engine but a Honda j series. well... acura to be specific I guess.. not a Toyota Jz.
    yota243[QUOTED] likes this.
  20. Dec 23, 2017 at 8:05 AM
    #5100
    yota243
    E.J.
    north Alabama
    Jcyr likes this.
