Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 31, 2017 at 8:23 AM
    #5181
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I do what i do
  2. Dec 31, 2017 at 8:23 AM
    #5182
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :cheers:
    yota243 likes this.
  3. Dec 31, 2017 at 8:29 AM
    #5183
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    On a mini vacation now but stoked to get back to the turbos stuff
    boostedka likes this.
  4. Dec 31, 2017 at 8:33 AM
    #5184
    Jcyr
    Jack
    North east
    I want to maintain my stock hard lines but i need to find an adapter to go from this to AN does anyone know of such magic? It’s a size 14mm but not sure of the thread count yet. 6104013C-6B1D-48E9-B4A0-2BBEF0859C1B.jpg
    tacodown likes this.
  5. Dec 31, 2017 at 8:50 AM
    #5185
    tacodown
    tacodown Well-Known Member
    brant
    holtwood, Pa
    96 tacoma 2.7
    Yeah i have it downloaded on my roommates computer since I have a mac :annoyed:
  6. Dec 31, 2017 at 8:54 AM
    #5186
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
  7. Dec 31, 2017 at 8:55 AM
    #5187
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup..... better to get to fiddling around with it. First go through the Functions, in the Setup menu.
  8. Dec 31, 2017 at 8:58 AM
    #5188
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
  9. Dec 31, 2017 at 9:06 AM
    #5189
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
    Yeah i have been. Some of the stuff seems over my head but like I'm sure once i have something to work with and the ecu actually hooked up in the vehicle and the computer hooked up I should do okay.
  10. Dec 31, 2017 at 11:45 AM
    #5190
    Jcyr
    Jack
    North east
    tacodown[QUOTED] likes this.
  11. Dec 31, 2017 at 12:47 PM
    #5191
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You're welcome.
  12. Jan 1, 2018 at 7:44 AM
    #5192
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    So on the way to work today up on the freeway I couldn't get past 65 mph because the engine was bogging. Afr's were at 8.00-9.00 and that was maybe 1/4 throttle. EngineLink app was showing 75-100% load and boost was high timing 3deg. :notsure: When I got off the freeway coming out of a light (slight turn) I light up the tire through second gear. It's probably that vac/boost leak at the IAC. :notsure:
  13. Jan 2, 2018 at 1:28 AM
    #5193
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  14. Jan 2, 2018 at 5:35 AM
    #5194
    yota243
    E.J.
    north Alabama
    Took some persuasion but got my truck to crank this mornin (i think it was single digits but here is the intake temp after 5 mins of driving and a 5 min warm up
  15. Jan 2, 2018 at 6:08 AM
    #5195
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cold and cranky. :rimshot:
    TacoLeeSD and yota243 like this.
  16. Jan 2, 2018 at 6:30 AM
    #5196
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MrCrowntown[QUOTED] likes this.
  17. Jan 2, 2018 at 7:34 AM
    #5197
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  18. Jan 2, 2018 at 9:19 AM
    #5198
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
    Ironically I got my base map from Luis sunday night. I'm pretty close to his shop i believe ( in pa, close to maryland line) I'm gonna have him tune it at some point but I deff want to hook it up and tweak it so it' driveable in boost at least. Need to get another vehicle for transportation so I dont need to worry about having the tacoma to get to work and such. I think from looking at the tables for fuel and timing everything is filled out up to when i would start building boost. So im thinking ill look at a couple maps to compare and start filling it out. The Rpm columns go all the way up to 10000 Rpms which ill never go over 5500 so hopfully I can alter how many rows I want. Need to figure out how to get my haltech to read my afrs from my plx module. Run my vac line through the firewall so the haltech can read boost and take out my maf sensor . Come inspection time I'm gonna have to basically put everything back to how it is now which is gonna really suck unless I can find a way to make the truck emissions exempt. But really to swap a fuel rail, injectors, and put maf sensor back on wouldnt take up more than a couple hours and it will help that I'm gonna try and make the fuel system interchangeable with the stock one
  19. Jan 2, 2018 at 9:20 AM
    #5199
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
    Hahah!! Youre welcome, I've been searching on summit for the past couple weeks trying to find the right adapters
    Jcyr[QUOTED] likes this.
  20. Jan 2, 2018 at 9:54 AM
    #5200
    MrCrowntown
    Alyn
    Ky
    You know 1412?
    I helped him out as part of his crew for a few races. 600hp e85 boosted BEAST
    Torspd and MadTaco461[QUOTED] like this.
