Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jan 3, 2018 at 8:13 PM
    #5221
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    350TQ will start to break gears
    tacodown[QUOTED] likes this.
  2. Jan 3, 2018 at 8:19 PM
    #5222
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I do and most of the time it goes away plus it has no effect on street driving.
  3. Jan 3, 2018 at 8:24 PM
    #5223
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    what I mean is if you are getting into open loop while trying to pass on the freeway your ECU goes to a preprogramed map because you have bigger injectors it could be flooding this could be why you are getting so low in the AFR's.
    While is closed loop your ECU is trimming your bigger injectors, but once open loop comes it dumps fuel in, causing you to go rich and bog out.
    Could also be that you don't have a MAF clamp and you are hitting a voltage limit on you MAF. Just throwing out ideas.
    Torspd, 05Taco4x4 and Jstand[QUOTED] like this.
  4. Jan 3, 2018 at 8:54 PM
    #5224
    Jstand
    Irving,Tx
    Maf clamp ?
  5. Jan 3, 2018 at 8:57 PM
    #5225
    Jstand
    Irving,Tx
    Also would going into open loop pull timing to 3 deg from 16
  6. Jan 3, 2018 at 9:05 PM
    #5226
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    When to much air passes over the MAF and voltage rises above a certain point the ECU does not like it, happens when you turbo with a MAF, this can be taken care of by a URD MAF clamp or AEM FIC.
  7. Jan 3, 2018 at 9:07 PM
    #5227
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I am not sure what timing goes to but I know when you get to open loop your AFR's will suddenly drop, with your bigger injectors this sounds like the issue. what size injectors are you running? can your scan tool show you open and closed loop?
    Jstand[QUOTED] likes this.
  8. Jan 4, 2018 at 6:25 AM
    #5228
    Jstand
    Irving,Tx
    I’m running 440cc and not able to see open/ closed loop. I could be to the point were I need a way to tune I’m just seeing how far I can go before that.
  9. Jan 4, 2018 at 7:42 AM
    #5229
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    You are as far as you can go if you want it to run better you need something to tune it.
  10. Jan 4, 2018 at 8:12 AM
    #5230
    Jstand
    Irving,Tx
    I decided to take out the manual boost controller and just put the correct spring in the wastegate so according to the chart if I put the green with red I’ll get 10.15 psi :eek::eek: it was more like 14-15psi so I guess we’ll try black or yellow :D
    MrCrowntown likes this.
  11. Jan 4, 2018 at 10:29 AM
    #5231
    Jstand
    Irving,Tx
    It looks like the yellow spring is going to work at 10psi :thumbsup:. 15 psi sure felt good at 3/4 throttle for a second but even if the afr’s are good I think that’s past the limit for stock bottom end and mine is at 230000 miles
    05Taco4x4 and boostedka like this.
  12. Jan 4, 2018 at 10:30 AM
    #5232
    boostedka
    James
    NM
    I'll be interested to see what 10psi does for you on that set up. 12-13psi has been said to be about the limit for the stock rods. Thats with a tune.
    :fingerscrossed:
  13. Jan 4, 2018 at 10:30 AM
    #5233
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    On the plus side, you're not gonna get piston rings butting ends.
    Jstand[QUOTED] and Torspd like this.
  14. Jan 4, 2018 at 10:33 AM
    #5234
    Jstand
    Irving,Tx
    Ok you guys got me nervous now:eek::eek::eek::eek:
  15. Jan 4, 2018 at 10:34 AM
    #5235
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    well I mean a rod can only be slung once right? #silverlining
  16. Jan 4, 2018 at 10:42 AM
    #5236
    tacodown
    tacodown Well-Known Member
    brant
    holtwood, Pa
    96 tacoma 2.7
    :burnrubber:
    Jstand likes this.
  17. Jan 4, 2018 at 10:44 AM
    #5237
    Jstand
    Irving,Tx
    With a tune it’s probably close to the lean limit. I ran around yesterday on the freeway and around town at 11psi afr’s WOT were at 10.9 Today I took the manual boost out and put a spring in the wastegate rated at 7.25psi and it runs at 9.5-10psi according to my gauge.
    boostedka[QUOTED] likes this.
  18. Jan 4, 2018 at 11:05 AM
    #5238
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    lol I'm 10 psi on pinks with a tune. I think I just have a lot of turbine back pressure though.
    Jstand likes this.
  19. Jan 4, 2018 at 12:16 PM
    #5239
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Once, 4 times.....:rimshot:
    Jstand likes this.
  20. Jan 4, 2018 at 12:25 PM
    #5240
    yota243
    E.J.
    north Alabama
    4, one time right? and I mean surely atleast one of them would have to stay in so it could sing the others out right?
    Jstand likes this.
