Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jan 5, 2018 at 5:42 AM
    #5261
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is a way though.......with the addition of the Holly Hydramat....
  2. Jan 5, 2018 at 5:46 AM
    #5262
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Or just a head swap, since the blocks are the same.....as long as a Haltech is running the show. Then still, he'd have to figure out the way around emissions. Maybe head and ecu?
    Maybe just a 3rz swap, and the current ecu will still be happy. Benefit would be the added liters. This option sounds easiest to me. Swap in rods and pistons prior to engine swap. Done. Easiest swap ever.
    MadTaco461 likes this.
  3. Jan 5, 2018 at 7:04 AM
    #5263
    tacodown
    tacodown Well-Known Member
    brant
    holtwood, Pa
    96 tacoma 2.7
    Manual. It's not a big difference from when I had 30s on my truck a couple months ago. I'm probably just overreacting but I guess if I did regear it wouldn't do any bad lol
  4. Jan 5, 2018 at 8:09 AM
    #5264
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I’m pretty much sticking with this motor. Too much of a headache with emissions every other year. Trailer queen maybe, but it would be boring to tow this pile to the desert.
  5. Jan 5, 2018 at 9:17 AM
    #5265
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    If it was auto trans it would seem slow on take off. Mine is auto with 4:30's and its slow on take off but that's street not off road.
  6. Jan 5, 2018 at 11:25 AM
    #5266
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Head swap wont work. The block is the same, except the provisions for the timing cover. The cams have two drive gears, instead of the 3rz single drive gear for the cams
  7. Jan 5, 2018 at 11:35 AM
    #5267
    MrCrowntown
    Alyn
    Ky
    Putting in a 2TR wouldn't be too terrible. It's a newer motor, from a newer tacoma. Would streamline the process!
    Also, no EGR, just an air injection pump. Way easier to maintenance and remove/reinstall when it's time for smoggage
    Torspd likes this.
  8. Jan 5, 2018 at 11:48 AM
    #5268
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Add timing cover to the list. Might make that more expensive than a swap. Hmm. Random thoughts.
  9. Jan 5, 2018 at 11:57 AM
    #5269
    MrCrowntown
    Alyn
    Ky
    Well now I want to see if the timing cover would fit against the 3rz block... hmmm
    Would have to use the 2tr sub pan too though. Hmmmm
  10. Jan 5, 2018 at 12:31 PM
    #5270
    Jstand
    Irving,Tx
    It'll be interesting to see how it runs in 60 deg. It's been in the 20's and 30's for a while.
  11. Jan 5, 2018 at 3:08 PM
    #5271
    MadTaco461
    CA
    Kinda stock
    Nah I'll stick with my old 2rz for now. Shoot saw a whole complete motor last month on CL for 300 as a core.
  12. Jan 5, 2018 at 4:26 PM
    #5272
    Jstand
    Irving,Tx
    Does anyone know why my boost gauge shows 10 psi but the spring in the wastegate is 7.25. Is this normal ?
  13. Jan 5, 2018 at 4:28 PM
    #5273
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Where do you have the vacuum hose from your waste gate connected too?
  14. Jan 5, 2018 at 4:34 PM
    #5274
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Gauge sucks, or wastegate priority.
    Another gauge for comparison would give you a definitive answer.
    Jstand likes this.
  15. Jan 5, 2018 at 5:01 PM
    #5275
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    What type of wastegate do you have? With the tail I found the pressures were off. I believe the exhaust gas itself helps compress the spring.
    This is what I found with my Tial MV-S setup
    4.35 = 5-6 boost
    5.8 = 6-8 boost
    7.25 = 8-10 boost
    Jstand[QUOTED] likes this.
  16. Jan 5, 2018 at 5:09 PM
    #5276
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Be aware the some springs are not psi but bar iirc.
  17. Jan 5, 2018 at 5:40 PM
    #5277
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Interesting... think I’ll be adding that to the check list.
  18. Jan 5, 2018 at 5:54 PM
    #5278
    Jstand
    Irving,Tx
    On a vacuum block t’d into the intake manifold at the brake booster
  19. Jan 5, 2018 at 5:58 PM
    #5279
    Jstand
    Irving,Tx
    Wastegate is good it’s a Tial from Ko racing but I could just compare with another one.
  20. Jan 5, 2018 at 6:02 PM
    #5280
    Jstand
    Irving,Tx
    That’s right on point and I have the same wastegate. I’ve used each of those springs with the same results
