Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jan 5, 2018 at 6:10 PM
    #5281
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    That may be your issue. Bist in your manifold well always be lower than at you turbo because the TB. Your waste gate won't open despite making boost at the turbo. You should always reference boost at the turbo fire the waste gate.
    Where is the vacuum connection for your boost gauge?
  2. Jan 5, 2018 at 6:14 PM
    #5282
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Tial says a +/- 2 psi from actual is not uncommon.
  3. Jan 5, 2018 at 6:15 PM
    #5283
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Same place
  4. Jan 5, 2018 at 6:17 PM
    #5284
    Jstand
    Irving,Tx
    By the way the 10.15 was 14-15 boost
  5. Jan 5, 2018 at 6:27 PM
    #5285
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Does it peak at 10? Or does it sustain 10 PSI at WOT?
    Does your turbo have a vacuum fitting on it? If so, that's where your WG should be connected.
  6. Jan 5, 2018 at 6:30 PM
    #5286
    Jstand
    Irving,Tx
    There is a place for a fitting and it stays at 10
  7. Jan 5, 2018 at 6:37 PM
    #5287
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Move it to the turbo and see if that fixes it. If not, if you have boost creep, your WG and/or dump pipe is too small (assuming nothing wrong with the spring and WG).
  8. Jan 5, 2018 at 7:36 PM
    #5288
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I swear we covered this before, bout 100 pages back. You had other issues inhibiting the performance. Now that things are all getting taking care of, things are working the way they should finally. Wastegate priority is my call.
  9. Jan 5, 2018 at 7:59 PM
    #5289
    Jstand
    Irving,Tx
    Wastegate priority ?
  10. Jan 5, 2018 at 8:48 PM
    #5290
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    The most important control, is wastegate control. The signal(vacuum line) needs to be as exact as it can, to control boost as well as it possibly can.
  11. Jan 6, 2018 at 5:11 AM
    #5291
    Jstand
    Irving,Tx
    Ok so just move WG and boost gauge vac line to fitting on turbo like @StAndrew said :thumbsup:
    MrCrowntown[QUOTED] likes this.
  12. Jan 6, 2018 at 5:39 AM
    #5292
    Jstand
    Irving,Tx
    With all of the issues through out this turbo project I lost track of past threads and issues having to prioritize like stopping in the middle of one issue to solve another issue to get on the road again. Like you said now that things are working these small issues from before are coming up again. I forgot some of the issues we already covered Thank you for your patience.:)
  13. Jan 6, 2018 at 6:55 AM
    #5293
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Move the WG to the turbo and leave the boost gauge on the manifold post throttle body if you want to measure vacuum.
  14. Jan 6, 2018 at 6:57 AM
    #5294
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    This is how mine is set up
    Jcyr and Jstand like this.
  15. Jan 6, 2018 at 7:02 AM
    #5295
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Color me confused, but i thought a while back we all agreed that all the vacuum/boost lines should come from the manifold so they were accurate representations of what was actually happening to the truck.
  16. Jan 6, 2018 at 7:12 AM
    #5296
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    For the gauge and piggyback/standalone ecu, yes. You pull the WG from as close to the turbo as possible to minimize lag in the WG system controlling the boost. Adjust WG spring and/or boost controller to get the pressure that you want at the manifold.
    MadTaco461 likes this.
  17. Jan 6, 2018 at 9:43 AM
    #5297
    MrCrowntown
    Alyn
    Ky
    Everything but the wastegate should be to the manifold. Just not the brake booster line, as when you push your foot on the brake, air is allowed to be introduced into the motor, post metering.
    tacodown, Jstand and yota243[QUOTED] like this.
  18. Jan 6, 2018 at 9:52 AM
    #5298
    Jstand
    Irving,Tx
    Ok I put vac lines in the right place now. I’ll drive it at lunch to see how it does. :thumbsup:
    MrCrowntown likes this.
  19. Jan 6, 2018 at 10:36 AM
    #5299
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I still have a slight vacuum in my manifold even when the turbo is building boost. If you connect your waste gate to the manifold, your turbo will boost but the waste gate won't open until the manifold starts seeing boost. This will cause over boosting
    The boost gauge and tuner should be connected to the manifold but wg should be connected to the turbo.
  20. Jan 6, 2018 at 10:52 AM
    #5300
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Post up a picture of your exhaust where the wastegate mounts, please. The fabrication picture.
