Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 19, 2017 at 8:43 AM
    #521
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Yup it's an 06. Comes with the rare 4.0 in a tundy factory.
    Blackdawg[QUOTED] likes this.
  2. Apr 19, 2017 at 9:08 AM
    #522
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    is it the regular cab with 8' bed like how all the tundies used to be that weren't access cabs?
  3. Apr 19, 2017 at 9:11 AM
    #523
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    There is a regular cab long bed tundra here with a 1gr for sale, manual.
  4. Apr 19, 2017 at 9:12 AM
    #524
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Apr 19, 2017 at 9:14 AM
    #525
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I like how low your turbo is located.
    yota243 likes this.
  6. Apr 19, 2017 at 9:15 AM
    #526
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
  7. Apr 19, 2017 at 9:16 AM
    #527
    Brice
    Brice Turbo Member
    Brice
    Texas
    Dang that's yours?
  8. Apr 19, 2017 at 9:18 AM
    #528
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. Apr 19, 2017 at 9:18 AM
    #529
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :spy:
  10. Apr 19, 2017 at 9:18 AM
    #530
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    don't mind me
    yota243 likes this.
  11. Apr 19, 2017 at 9:21 AM
    #531
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. Apr 19, 2017 at 9:30 AM
    #532
    yota243
    E.J.
    north Alabama
  13. Apr 19, 2017 at 9:36 AM
    #533
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
  14. Apr 19, 2017 at 9:56 AM
    #534
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Nice clean set up! What turbo blanket are you using?
    Thanks. I was a little worried about it being so close to the AC lines but the heat wrap and blanket has kept everything proper. It made fabbing the DP easier than some of the other off the shelf manifolds I've seen. Also made my hot side IC pipe almost a straight shot to the IC.
  15. Apr 19, 2017 at 9:59 AM
    #535
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Is that recent or an older picture? Haven't been in your thread for a while, which engine are you running this week? We're still waiting for your +700HP dyno pull.
    MrCrowntown, yota243 and Brice like this.
  16. Apr 19, 2017 at 10:37 AM
    #536
    MadTaco461
    CA
    Kinda stock
    Front end is still under construction.
  17. Apr 19, 2017 at 10:41 AM
    #537
    Brice
    Brice Turbo Member
    Brice
    Texas
  18. Apr 19, 2017 at 11:03 AM
    #538
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I'm way behind....
    Arghhhh...
  19. Apr 19, 2017 at 11:51 AM
    #539
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is the old DEI turbine wrap. Shreds to pieces after a few year. I now have PTP turbo blanket. MUCH better quality!
    Good trade-offs for your setup. Simple is best.
    boostedka[QUOTED] likes this.
  20. Apr 19, 2017 at 11:54 AM
    #540
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Still N/A on the 4.3L. Waiting on the welder to get after it for the BW EFR. You are correct though about the pictures.
    I tried to get a picture of when the EFR was on there, but Photobucket had an ID10T error.
