Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jan 17, 2018 at 8:20 PM
    #5461
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I finally replaced the IAC valve took 45min. For me that’s good. Fast idle seemed like it wasn’t working but I’ll check tomorrow.
    MrCrowntown likes this.
  2. Jan 17, 2018 at 8:20 PM
    #5462
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    O_O
  3. Jan 17, 2018 at 8:22 PM
    #5463
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you disconnect the battery during install? Would that even help on your vehicle?
  4. Jan 17, 2018 at 8:22 PM
    #5464
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah. Guy said they were looking at bring a trailer to help sell it..
    Fuck me.
    That site is a joke of car inflation.
    So here we are. A 95 sx taco instead haha
    Torspd[QUOTED] likes this.
  5. Jan 17, 2018 at 8:23 PM
    #5465
    Jstand
    Irving,Tx
    I didn’t but that’s a good question if it would help
  6. Jan 17, 2018 at 8:24 PM
    #5466
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Should make the ecu relearn parameters.
  7. Jan 17, 2018 at 8:24 PM
    #5467
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wouldn't hurt. It'll rest the ecu if you unplug the batter for longer than 15mins
    Jstand[QUOTED] likes this.
  8. Jan 18, 2018 at 8:51 AM
    #5468
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Whats the happs?
  9. Jan 18, 2018 at 10:13 AM
    #5469
    Jstand
    Irving,Tx
    The happs?:confused:
  10. Jan 18, 2018 at 10:14 AM
    #5470
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    As we white people would say, "What's happening with it now?" or "What's the end result of the change you made?"
  11. Jan 18, 2018 at 10:15 AM
    #5471
    MrCrowntown
    Alyn
    Ky
    :bananadead:
    How does you truck run today?
    Jstand[QUOTED] and boostedka like this.
  12. Jan 18, 2018 at 10:18 AM
    #5472
    MrCrowntown
    Alyn
    Ky
    How does YOUR truck run???
    Jstand and dirtdigginjoe[QUOTED] like this.
  13. Jan 18, 2018 at 10:25 AM
    #5473
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I didn't ask you the other day. Are you also on stock injectors as well as the ECU?
  14. Jan 18, 2018 at 10:33 AM
    #5474
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    For the next 2 days, yes to both lol.
    I have an AEM FIC currently inside the truck, just not wired back up (I was having an issue with a stutter at high load/low RPM with one of my injector wires, so I reverted to stock). I plan on wiring it back up over the weekend and tuning closed loop so I can actually get on it more than 40%.
    Right now, minus the wastegate not being able to go lower than about 10psi (New Mambatek adjustable being delivered today), it drives like stock as long as I lean into it when it hits open loop. Closed loop it'll maintain 14.7-15.0 AFR, which I'm not comfortable with at any boost level.
    I do have plans to get some larger injectors, as well as the AEM E85 fuel pump so I can run E85 here in the spring. The FIC will handle all of the tuning requirements.
    I'm working on getting a build thread together, just been super busy at work lately!
  15. Jan 18, 2018 at 10:36 AM
    #5475
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    See above post to Dirty Deeds lol.
    Really just waiting for the new wastegate actuator to arrive so I can really control the boost. But otherwise it's fun as hell- I've already gotten asked tons of times about the truck, especially when people hear the HKS BOV. Biggest question is, "Dude how did you do that?"
  16. Jan 18, 2018 at 10:36 AM
    #5476
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I know the aem fic can only retard timing, but technically could you take out like 350* if you wanted to add 10*? I thought I read somewhere that's how the mapecu3 actually advanced timing
  17. Jan 18, 2018 at 10:37 AM
    #5477
    Blackdawg
    Monte
    Wyoming/St. Louis
    Again, I don't see why guys in here keep trying to run e85. Yes you can make more power and yes it is cheaper to buy.
    But the trucks fuel system is NOT designed for it. Just replacing the pump isn't good enough. You need to replace every piece of rubber the fuel touches as well. Just doesn't seem worth it to me.
    ON top of that you need more fuel delivery which means bigger pump and bigger injectors. Which also means you use more fuel so in the long run its not that much cheaper and is harder to find. Without a really well tuned fully stand alone ECU that can handle blends of e85 and gas, you can't ever get a good tune by just guessing how much to blend if you try and do that.
    Just my opinion though..
    elnip, Jcyr and Torspd like this.
  18. Jan 18, 2018 at 10:41 AM
    #5478
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    As much as I agree that it CAN be a waste for most- I planned on redoing the fuel lines with the pump and injectors. The truck has enough miles for me to justify doing the "maintenance upgrade." My purpose for E85 is the significantly lower IATs and detonation protection. In my BMW I used to run an E30 blend, and while it made a very noticeable power difference, I was able to see the much lower IATs- even when I still had the stock intercooler. Plus with the URD fuel upgrade kits, it takes care of adding an external fuel filter.
    Blackdawg[QUOTED] likes this.
  19. Jan 18, 2018 at 10:47 AM
    #5479
    Blackdawg
    Monte
    Wyoming/St. Louis
    thats good your redoing the whole system.
    And idk what URD kit you are referring to, they don't have an e85 upgrade kit or anything that i've seen?
    as for the BMW, it was made to do that im sure. Has a sensor in the fuel tank so it know what the ethanol levels are and the ECU can change its tune accordingly and fuel delivery accordingly. Your AEM FIC6...not gonna do that. THat's my point. Your tune will never be as good as it could be if you are constantly mixing in various amounts of ethanol. Because it isn't designed to do that. Its not a flexfuel setup unless you go all out and make a full standalone ecu for the truck.
    So again, I don't really see the point.
    I'm going to pick 1 fuel type. And tune for that to get the most out of it and keep it safe. If i want to lower detonation, I'll add a meth/water kit. Way easier to tune for and control.
    Maybe im just a control freak..but when it comes to boost/turbos especially on motors that aren't really made for it from the factory...im not taking chances.
  20. Jan 18, 2018 at 10:49 AM
    #5480
    Jstand
    Irving,Tx
    Sorry lol yea it’s fine. The idle seems low on cold start at 600-700 rpm like it’s going to stall but it doesn’t I’m sure there’s an adjustment. The annoying open loop on the freeway is still there. It makes it hard to drive 70-80 mph cruising with the afr’s as low as 8.3. Eventually I’ll get fuel management (cheapest) and plug n play harness but first I need to get another DD and pay off some debt.
