Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 2, 2018 at 7:33 AM
    #5761
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    This is what I drive 95% of the time. Truck just comes out for fun.
    yota243, boostedka and Jstand like this.
  2. Feb 2, 2018 at 7:34 AM
    #5762
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Would t-tap connectors be ok to use for wiring the ECU ?
  3. Feb 2, 2018 at 7:36 AM
    #5763
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Damn! Slickdeal
    Jstand[QUOTED] likes this.
  4. Feb 2, 2018 at 7:37 AM
    #5764
    MadTaco461
    CA
    Kinda stock
    So clean. I'd dd that for sure. Probably rides like butter.
  5. Feb 2, 2018 at 7:37 AM
    #5765
    boostedka
    James
    NM
    That's looks like it's pretty damn fun too!
    MadTaco461[QUOTED] likes this.
  6. Feb 2, 2018 at 7:42 AM
    #5766
    MadTaco461
    CA
    Kinda stock
    It what started this sickness. Been good to me.
    boostedka[QUOTED] likes this.
  7. Feb 2, 2018 at 7:49 AM
    #5767
    MadTaco461
    CA
    Kinda stock
    I imagine Tor has one insane car after the other.
  8. Feb 2, 2018 at 8:19 AM
    #5768
    boostedka
    James
    NM
    I normally get to work on my old MTB converted to a SS commuter. When it's my turn to make the daycare run, I drive the 4Runner.
    Jstand, MadTaco461 and yota243 like this.
  9. Feb 2, 2018 at 8:41 AM
    #5769
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Was getting there until that frogger deer. :annoyed:
    Jstand and MadTaco461[QUOTED] like this.
  10. Feb 2, 2018 at 9:06 AM
    #5770
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Good cars, as long as the wiring isnt cracked and breaking lol
  11. Feb 2, 2018 at 9:14 AM
    #5771
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    another tacoma...and if that's down...another tacoma :anonymous:
    MadTaco461 and Jstand like this.
  12. Feb 2, 2018 at 9:15 AM
    #5772
    boostedka
    James
    NM
    Lol. I saw in the reg cab thread to recently acquired a V6 RC. How are you liking it so far?
  13. Feb 2, 2018 at 9:19 AM
    #5773
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've driven it very little other than the 540 miles home. Had title issues so waiting to get it back from the guy i bought it from as his ex wife had to sign it too...and she is on vacation.
    But, other than that. It is fun as hell to drive. So tiny and yet so powerful. Love it. Can't wait to drive it more. I need to replace the motor mounts i think and speedo cable. Plus the fan switch and washer fluid pump. Other than that, the thing is insanely clean and drives great. Will be DD it straight for a few week while the double cab gets repaired and a bit of an overhaul.
    Then it'll just be the back up DD and town run around truck for myself and the girl for when it snows.
    Really wanted an 07-08 FXT manual..but couldn't find one near by or that i could afford. wanted something "sporty" to drive.
    Reg cab V6 is kinda sporty..right? :cookiemonster:
  14. Feb 2, 2018 at 9:37 AM
    #5774
    MrCrowntown
    Alyn
    Ky
    I strongly advise against that.
    You need the ECU to keep you from blowing up your motor. Dont let that control rely on those bs little clamps
  15. Feb 2, 2018 at 9:51 AM
    #5775
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    The other Tacoma. An 05 PreRunner
  16. Feb 2, 2018 at 9:56 AM
    #5776
    boostedka
    James
    NM
    Sounds like it'd be a pretty fun truck to drive. I can't even imagine once you get boost on it.
  17. Feb 2, 2018 at 9:57 AM
    #5777
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I've got a WRX for my non-Tacoma ride. I've been driving it a lot lately because I'm limiting the miles on the truck until I get around to doing the water pump. I miss 6th gear and the boost when I switch back to driving the truck.
    MadTaco461, Jstand and boostedka like this.
  18. Feb 2, 2018 at 9:57 AM
    #5778
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah i am excited to try a small turbo on it. Not for big power reasons but it would make it ridiculously fun.
    Already accelerates good in 5th gear going up hills. Frankenstein never could do that even when he was stock.
    speaking of..
    how was the MS3 to work with? What i'll be using.
  19. Feb 2, 2018 at 10:08 AM
    #5779
    boostedka
    James
    NM
    It was pretty easy to wire up using the PNP harness. The only issue was the IAC valve. I didn't wire that up correctly so the valve was stuck open and idling at 1700rpm. I haven't been able to figure out yet exacly how to wire it up correctly. I've found a couple write-ups on CT but the pics for them are now gone since Photobucket fucked everyone over. So that makes it difficult for me to understand them. The use of it was pretty simple. I had a guy on CT that helped me out a lot with the initial settings. Once that was going, tuning is pretty straight forward. There is an autotune function with the full software that works pretty well for tuning around town and cruising speeds.
    I removed it for now with the intention of selling it since I wasn't really using it near it's full potential. But lately I'm thinking about putting it back in if i can just get the idle wiring all figured out. It definitely is much more responsive with the MS and spools a little quicker as well. It would spool even faster with a 3 or 4 port BC as well.
  20. Feb 2, 2018 at 10:16 AM
    #5780
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Boost it following a similar path as @dirtdigginjoe
    dirtdigginjoe and MadTaco461 like this.
