Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 2, 2018 at 10:19 AM
    #5781
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    You might try messaging @tcBob. Awhile back I saw a thread where someone copied a thread with broken PB links and they were able to fix links.
  2. Feb 2, 2018 at 10:24 AM
    #5782
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Boost is planned for the truck. I'm working on getting the suspension how I want it and taking care of some maintenance things that have come up. Once the suspension is done, acquisition of boost parts will start. The turbo will probably be the first thing that I buy.
    MrCrowntown likes this.
  3. Feb 2, 2018 at 10:24 AM
    #5783
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nice!
    They make an entire kit that is PnP for the early V6s that plugs right into the stock harnness. So won't have wiring issues. Even comes with a base map.
    Think it'll work well. Have known about MS3 since i had a supra. Just seemed really daunting to have a full ECU to tune by yourself.
    boostedka[QUOTED] likes this.
  4. Feb 2, 2018 at 10:38 AM
    #5784
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Heck yeah man! Which turbo have you been dreaming of?
    We have a member or two with ths MS3. Have a handful with the Haltech. I say Haltech Elite, but I am biased after the last three EMS' that I had. Not including the Mega Squirt. We'll be here to get you all sorted out. :thumbsup:
    Blackdawg[QUOTED] likes this.
  5. Feb 2, 2018 at 10:43 AM
    #5785
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I've been playing on the BW MatchBot, and I'm leaning toward the EFR 7670 with 0.92 a/r.
    Torspd[QUOTED] likes this.
  6. Feb 2, 2018 at 10:46 AM
    #5786
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  7. Feb 2, 2018 at 10:50 AM
    #5787
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Internally wastegated as well?
  8. Feb 2, 2018 at 10:51 AM
    #5788
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Yeah. The 1.05 a/r is the external wastage turbine housing for the 7670. 0.92 and 1.05 are twin scroll.
  9. Feb 2, 2018 at 10:55 AM
    #5789
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Yea I was gonna solder everything :thumbsup:
  10. Feb 2, 2018 at 10:59 AM
    #5790
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Be sure to use a lineman's splice with important connections!
    Jstand[QUOTED] likes this.
  11. Feb 2, 2018 at 11:05 AM
    #5791
    Blackdawg
    Monte
    Wyoming/St. Louis
    haltech would be nice. Not sure that is PnP though. The MS just seems the simpler solution that also merits the most control over the motor. And most affordable :p Soldering is part of what I do for a living so building the MS will be easy.
    The other hurdle i have is i don't want the divorced WG setup CX racing has...so..might have to do something different there.
  12. Feb 2, 2018 at 11:13 AM
    #5792
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Reading through the into on DIYAutotune, it looks like it pretty well laid out. looks like a pretty nice set up.
    https://www.diyautotune.com/support...ion/application-docs/1995-1997-toyota-tacoma/
  13. Feb 2, 2018 at 11:14 AM
    #5793
    Blackdawg
    Monte
    Wyoming/St. Louis
  14. Feb 2, 2018 at 11:24 AM
    #5794
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Have I missed any 2.7 revelations in the last dozen or so pages?
  15. Feb 2, 2018 at 11:57 AM
    #5795
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    The missing pics from here...couldn't recover the hi-res versions of them unfortunately:
    Ok to bypass the TB coolant lines, just take the hoses off, find a nipple to connect the two, and tighten up the hose clamps.
    The way to figure out which coil to wire to, get the truck running, and have only the power wire hooked up. Ground each side of the IAC individually. You will notice that one side lowers the engine speed, and one side raises it. Wire into the one that lowers it. Here are the settings:
  16. Feb 2, 2018 at 12:03 PM
    #5796
    boostedka
    James
    NM
    THanks Bob. That's very helpful!
  17. Feb 2, 2018 at 12:27 PM
    #5797
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    speed3? i drove one for a summer and really enjoyed the car. very spacious.
    currently my tacoma is the winter dd, integra as the fun car, and motorcycle for the summer.
  18. Feb 2, 2018 at 12:50 PM
    #5798
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Haha same mindset with vehicles. Car, truck and bikes. I like the speed 3. Good car if you don't mod it too crazy.
  19. Feb 2, 2018 at 1:01 PM
    #5799
    Blackdawg
    Monte
    Wyoming/St. Louis
    briefly looked at speed6's with awd. Looked cool on paper. Never drove one but 300hp awd 6spd sounds fun.
    MadTaco461[QUOTED] likes this.
  20. Feb 2, 2018 at 1:11 PM
    #5800
    MadTaco461
    CA
    Kinda stock
    One of the guy's I work with has a speed 6. Super clean. Making 350whp 370wtq. Super sensitive car. You can't launch hard from a dead stop in it or you blow the rear diff. Probably dumped 15-20k into it. Keeps up with some of the local stock v8 cars.
