Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 10, 2018 at 6:11 AM
    #5901
    tacodown
    tacodown Well-Known Member
    brant
    holtwood, Pa
    96 tacoma 2.7
    it was a kit from ko and everything you said about the clocking matches up to what your saying. Original oil feed line burned a hole through it due to my lack of knowledge, had it routed wrong and must have been rubbing against the exhaust manifold.
    Ive noticed i am losing a little bit of oil but it did that before i turboed and i may have developed a leak either at the pan or the rear main seal. Its towards the back and i did put the new pan on but i had no oil leaks for the first 3 months i turboed it.
    That makes the most sense, the pcv valve is pretty new, i put that in about a year or two ago
  2. Feb 10, 2018 at 7:06 AM
    #5902
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Brice, Jstand[QUOTED] and yota243 like this.
  3. Feb 10, 2018 at 10:11 AM
    #5903
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    yea i wouldnt worry about it then. just new smells from not having a cat
  4. Feb 10, 2018 at 1:22 PM
    #5904
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  5. Feb 10, 2018 at 5:06 PM
    #5905
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    factory manifolds are off and cx manifolds are on (need to pick up a couple studs monday). oil lines and intercooler will be tackled tomorrow.
    sorry no pics. hands were way to dirty (and bloody) to touch my phone during the whole process.
  6. Feb 10, 2018 at 5:21 PM
    #5906
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Like the motorized tricycle that the MCM guys have. With lcv on its rear tyres.
    yota243[QUOTED] likes this.
  7. Feb 10, 2018 at 5:24 PM
    #5907
    yota243
    E.J.
    north Alabama
    Yes did u just watch the honda mini bike race episode yesterday? (could have been today... Im on vacation and time is non existant)
    MadTaco461 and Torspd[QUOTED] like this.
  8. Feb 10, 2018 at 7:00 PM
    #5908
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
    Okay so i dont want to over build the motor but i dont want to under build it either. I was thinking studs and a head gasket no doubt. If i would choose stronger connecting rods which with the 3rz sounds like i should, would it be a no brainer to get new pistons? Would that depend on the condition of the cylinders? If the cylinders are good could i just use the same pistons and just get new rings? I dont have a power goal but i guess im hoping for less than the power limit of the w59 trans with an upgraded clutch. At this point i shpuld probably do a new timing chain and delete the balance shafts. Thoughts?
  9. Feb 10, 2018 at 7:59 PM
    #5909
    Sacrifice
    KS
    DCSB OR 4X4 LT
    how i do every job. way too time consuming to clean hands and stop
  10. Feb 10, 2018 at 8:55 PM
    #5910
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    This is what I’ve learned through my research. The first thing to go on the motors are the connecting rods. What sucks is the w59 trans is going to be your biggest limiting factor. It only holds ~350 ft lb of torque before stuff inside starts breaking.
    If I was to build a 3RZ, I would do rods, pistons, metal HG w studs. I would also look into swapping to a R150f trans from a 5VZ though in order to actually use the built motor
    Jcyr and Torspd like this.
  11. Feb 10, 2018 at 9:24 PM
    #5911
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Yes.
    LOL
  12. Feb 10, 2018 at 9:24 PM
    #5912
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Saw them on MCMtv2 a while back, but then yes again on the episode you mentioned. Wonder how well it would handle without the PCV? Hmm.
  13. Feb 10, 2018 at 10:10 PM
    #5913
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lol I just wipe my hands with a rag and grab the DSLR anyways. Idgaf
    Brice, Sacrifice[QUOTED] and buyobuyo like this.
  14. Feb 11, 2018 at 10:15 AM
    #5914
    tacodown
    brant
    holtwood, Pa
    96 tacoma 2.7
    Yes as in i could possobly get away with just rods if the cylinders dont need bored? I dont really want to screw with the compression because there will be a point that i have to have it running with the stock ecu as it is now to pass emissions. Not sure on how much lower i can go for it to not be drivable
  15. Feb 11, 2018 at 12:03 PM
    #5915
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    How much lower with compression? Turbo + lowered compression = better reliability and the ability to raise the boost pressure substantially. If I were building up my 5vz with forged internals, I would without a doubt try to source some shorter pistons
  16. Feb 11, 2018 at 2:26 PM
    #5916
    devinzz1
    devin
    2023 aclb trd or mt
    im having a very difficult time getting a broken stud out of the head. welded a nut on 4 times and heated area with torch with no luck. have soaking in pb plaster overnight. not sure how id get a drill in if i need to drill it out.
  17. Feb 11, 2018 at 2:29 PM
    #5917
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Honestly just pull the motor at that point. It takes a few hours. Probably take the trans with it.
  18. Feb 11, 2018 at 2:32 PM
    #5918
    MrCrowntown
    Alyn
    Ky
    Yes, as in build the heck out of it :cool:
    Pistons are most important. I would get your cylinders bored with oversized pistons. That will be the safest way to get a little lower compression, without going to a different height piston, or a stroker crank. Short pistons, and a stoker crank, may require clearance modifications.
    tacodown[QUOTED] likes this.
  19. Feb 11, 2018 at 2:34 PM
    #5919
    MrCrowntown
    Alyn
    Ky
    Picture of what you are referencing to?
  20. Feb 11, 2018 at 2:42 PM
    #5920
    Blackdawg
    Monte
    Wyoming/St. Louis
    Finally some one putting the intercooler in a smart place. Look forward to seeing how you make that work
    Speedytech7 and GreeGunc like this.
