Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 25, 2017 at 3:09 PM
    #601
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Yes! U got it bro. Denmah on lsx forums did this a few times on his builds and so far no problems. Pushing over 800hp on them too
    Brice[QUOTED] likes this.
  2. Apr 25, 2017 at 4:12 PM
    #602
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Matt happel? I can't remember his username...unless that's it.
    If that is who you're talking about, his builds are awesome! After the 1097whp stock bottom end colorado build I feel like nothing is making as much power as it could lol...puts my 350hp goal to shame
  3. Apr 25, 2017 at 4:25 PM
    #603
    RedLantern
    Honolulu, Hi
    Yea that's him. Denmah is his user name. I'm running his turbo package that Vsracing sells. Still working on getting my bw turbo installed tho.
  4. Apr 25, 2017 at 4:39 PM
    #604
    Brice
    Brice Turbo Member
    Brice
    Texas
    What's the LS in?
    Because of his vids I've decided I'm gonna do an LS swap after this 5vz blows :D but we'll see
  5. Apr 25, 2017 at 5:00 PM
    #605
    RedLantern
    Honolulu, Hi
    No it's not on a ls, it's on my Tacoma.
  6. Apr 25, 2017 at 5:54 PM
    #606
    Brice
    Brice Turbo Member
    Brice
    Texas
    Oh I see, I just went and skimmed through your build thread.
    When does that turbo spool?
  7. Apr 25, 2017 at 7:04 PM
    #607
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Changed the oil and filter today from Amsoil to Rotella T6 and change the wastegate spring to the red one 5.80 psi is what it's rated at but my gauge shows 7psi hm are there other variables in this equation
    MrCrowntown likes this.
  8. Apr 25, 2017 at 7:06 PM
    #608
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Did we forget to tag @KirkRio in the op?
  9. Apr 25, 2017 at 7:37 PM
    #609
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Regarding the use of diesel oil (HDEO) make sure it its dual rated otherwise non dual rated commercially available diesel engine oil shouldn't be used in gasoline engines as excessive wear may happen, most likely in the ring/piston/bore area. There are plenty of S (SJ - SN) spec oil out there in thicker weights if that is the desired goal. For example I use motul 15w50 in my rb26 as mandated per the manual.
    Torspd likes this.
  10. Apr 25, 2017 at 9:52 PM
    #610
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I assume you mean 2rz for higher revving?
    But anyways, all the rods are drop forged in the rz family. Most people over advance their timing beyond the sweet spot while trying to squeeze more power out, where you run into problems with even billet forged rods.
    The pistons are hypereutectic so they would in theory be the weakpoint as far as the crystalline structure of the material is concerned.
    I will agree that the head gasket and studs are a very necessary upgrade though!
    StAndrew[QUOTED] likes this.
  11. Apr 26, 2017 at 1:23 AM
    #611
    RedLantern
    Honolulu, Hi
    On rolling launches it Hits full boost around 3400ish if I just pedal mash. But if I launch it on 2nd/3rd gear it's around 3200.
    From dead stop it's super laggy but once it gets going it just flys. Barely do this tho.
    I tagged him but always good to remind him. I barely see him on here now. He's active on ig tho with rebuilding turbos. Looks like he's trying to sell his STI.
    yota243[QUOTED] likes this.
  12. Apr 26, 2017 at 4:57 AM
    #612
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yes. Thanks. Pistons are strong but the 95mm stroke has always been considered a bit too long for a stout rod :shrug:
    I have no experience but on Customtacos, its pretty common knowledge (or at least commonly preached) that the 2RZ makes more power than the 3RZ on stock rods. I don't know about the pistons; never seem one of those fail.
    5VZ also tend to break rods before anything else (5VZ is not forged btw).
    MrCrowntown[QUOTED] likes this.
  13. Apr 26, 2017 at 5:33 AM
    #613
    Jstand
    Irving,Tx
    So when my engine goes could i just get a 2rz or would i have to change motor mount or trans location?
  14. Apr 26, 2017 at 5:39 AM
    #614
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    IF your engine goes. 3RZ is still very stout. I think you should be good for 300+ hp. 350 with a spot on tune. The 2RZ, with an RPM bump, generally is safe up to 400. All that is assuming head studs (and while you're at it, a new head gasket).
    Jstand[QUOTED] likes this.
  15. Apr 26, 2017 at 6:04 AM
    #615
    Jstand
    Irving,Tx
    I'm sure I'm pushing the limits at 218000 miles no intercooler and 5.80 psi but the gauge shows 7psi
  16. Apr 26, 2017 at 6:26 AM
    #616
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Any of you guys running diesel oil, DO NOT DISREGARD this information. DO NOT.
  17. Apr 26, 2017 at 6:28 AM
    #617
    Jstand
    Irving,Tx
    So is the Rotella T6 5w 40w ok ?
  18. Apr 26, 2017 at 6:48 AM
    #618
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I'm still runing penzoil platinum 5w-30. They make a "Euro spec" 5w-40 full synthetic you can buy on Amazon. What oil should I run?
  19. Apr 26, 2017 at 6:56 AM
    #619
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Euro spec usually has more zddp than non euro spec. Which is a plus.
  20. Apr 26, 2017 at 6:56 AM
    #620
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Read what he wrote, and apply to the container you have.
