Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 16, 2018 at 4:25 PM
    #6281
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Did you use Flex-a-lite's controller? What wire did you tap into for the AC relay to turn the fan on when the AC is running?
    PapaBear likes this.
  2. Mar 16, 2018 at 4:32 PM
    #6282
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I wired it to a switch in the cab. The desert is not forgiving on... well, anything lol but for a street car its a great idea. I dont remember what I hooked it up to, but can have a look later.
    The haltech will control it eventually
  3. Mar 16, 2018 at 5:15 PM
    #6283
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Thanks. I would guess that the AC wire is what is hooked to your switch if your fan will still cycle based on the temp probe with the switch off.
  4. Mar 16, 2018 at 5:45 PM
    #6284
    MrCrowntown
    Alyn
    Ky
    Yes, it would def work that way, but I eliminated the thermostatic controller altogether. Now, the only thing I rely on(other than the switch and relay) is myself
  5. Mar 16, 2018 at 5:56 PM
    #6285
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Ah okay.
  6. Mar 16, 2018 at 5:57 PM
    #6286
    MrCrowntown
    Alyn
    Ky
  7. Mar 16, 2018 at 6:19 PM
    #6287
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Would equal length tubes matter if it's going into a turbo? I feel it still would
  8. Mar 16, 2018 at 6:26 PM
    #6288
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How particular do you want to be?
  9. Mar 16, 2018 at 7:16 PM
    #6289
    05Taco4x4
    2TR-FE Enthusiast
    Well people rave about LCE’s header and I figured the same concept applies
  10. Mar 16, 2018 at 8:12 PM
    #6290
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Let's say that F1 is the tier that you strive for. 100% perfect. If they are doing it, mimic it as closely as possible. The closer you can be to their models, the closer to "100%" you'll be.
    Do they use equal length primaries for their turbo engines? You bet your ass they do.
  11. Mar 16, 2018 at 8:14 PM
    #6291
    05Taco4x4
    2TR-FE Enthusiast
    You say it so delicately :rofl:
    :cheers:
  12. Mar 16, 2018 at 8:16 PM
    #6292
    05Taco4x4
    2TR-FE Enthusiast
    Oh, and I just discovered the 1fz-fe yesterday :drool:
  13. Mar 16, 2018 at 8:20 PM
    #6293
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    2JZ 's big brother. It's a true behemoth. Making 2k HP before it was cool.
  14. Mar 17, 2018 at 10:00 AM
    #6294
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    got the truck going and went for the first test ride yesterday. staying out of boost of course with no tuning and factory plugs. Think i broke my o2 sensor somewhere along the way too.
    going out of province again tuesday so itl be a while till my next update. parts should be shipped by then.
  15. Mar 17, 2018 at 1:01 PM
    #6295
    devinzz1
    devin
    2023 aclb trd or mt
    anyone here running hood pins? factory latch has no way of working with intercooler where it is. got my hood zip tied shut atm :D
    MrCrowntown and Jstand like this.
  16. Mar 17, 2018 at 1:07 PM
    #6296
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am.
    MrCrowntown likes this.
  17. Mar 17, 2018 at 1:07 PM
    #6297
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Hood pins going on in a few weeks.
  18. Mar 17, 2018 at 1:08 PM
    #6298
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Mar 17, 2018 at 1:19 PM
    #6299
    devinzz1
    devin
    2023 aclb trd or mt
  20. Mar 17, 2018 at 1:27 PM
    #6300
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
