Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 6, 2018 at 11:56 AM
    #6701
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Need to dust off my Game Genie then....
  2. Apr 6, 2018 at 11:59 AM
    #6702
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Super jump and start with a cape ftw!
    Torspd[QUOTED] likes this.
  3. Apr 6, 2018 at 12:11 PM
    #6703
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Two diodes facing opposite directions? Wouldn't you create a black hole, with current entering both directions and nothing leaving? :boom:
  4. Apr 6, 2018 at 12:15 PM
    #6704
    yota243
    E.J.
    north Alabama
  5. Apr 6, 2018 at 12:16 PM
    #6705
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    He didn't say if it is wired in series or parallel. Assuming parallel would make the best sense so current can flow either way. Wouldn't matter what direction you install your homemade fuse.
    Edit: went stupid for a second
    loginfailed likes this.
  6. Apr 6, 2018 at 12:19 PM
    #6706
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :rofl:
    yota243[QUOTED] likes this.
  7. Apr 6, 2018 at 2:24 PM
    #6707
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The diodes will cause a certain amount of voltage drop across them. Usually about .6 or .7 volts.
    The S terminal on the alternator senses voltage at the battery. It uses the sensed voltage to determine how much it needs to charge.
    So if you put a .7 voltage drop on the sense wire, the alternator thinks the battery is .7 less than it actually is. So the alternator increases the voltage to compensate.
    05Taco4x4 likes this.
  8. Apr 6, 2018 at 2:25 PM
    #6708
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Exactly.
    up down up down left right left right b a select start.
    05Taco4x4 and yota243[QUOTED] like this.
  9. Apr 6, 2018 at 2:27 PM
    #6709
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Something like that, yes. It’s magic, really.
  10. Apr 6, 2018 at 2:29 PM
    #6710
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, parallel.
    This guy only uses 1 diode. Same principle though.
    https://youtu.be/Dp7J083exKw
  11. Apr 6, 2018 at 2:32 PM
    #6711
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    :rofl:
  12. Apr 6, 2018 at 2:32 PM
    #6712
    TacoLeeSD
  13. Apr 6, 2018 at 3:35 PM
    #6713
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I had a 2rz 2.4 so you might not be able to get that high.
    Jstand[QUOTED] likes this.
  14. Apr 6, 2018 at 3:37 PM
    #6714
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Here I just did this to illustrate. On my work bench I have a power supply like they use at car audio stores to run the display radios. The power supply supplies about 13 amps at 13.5 volts.
    Here is the DVOM reading with no diodes involved.
    Here I’ve put a 1/4 watt diode on the positive lead. The stripe needs to face the alternator. In this case the DVOM is the S terminal on the alternator.
    As you can see, the particular diode drops voltage by approximately .25 volts.
    Lets add another diode in series.
    Now we are down .5 volts.
    One more for fun.
    You can put more diodes in parallel to increase current capability. The ALT-S fuse is 7.5a so I’m pretty sure you can get away with not having any in parallel.
    Different sized diodes have different voltage drops.
    The guy in the video I posted earlier says the diode also acts as a fuse. I can’t vouch for that, so I’d try to keep the fuse. Either by splicing the diodes into the harness or making some sort of jumper if doing it inside the fuse box.
    05Taco4x4 and Torspd[QUOTED] like this.
  15. Apr 6, 2018 at 4:18 PM
    #6715
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  16. Apr 6, 2018 at 4:28 PM
    #6716
    MadTaco461
    CA
    Kinda stock
    :goingcrazy:
    MrCrowntown[QUOTED] likes this.
  17. Apr 6, 2018 at 4:31 PM
    #6717
    MrCrowntown
    Alyn
    Ky
    Shopping Weld Els and whatnot..
    gimme a couple weeks. Already have a local buddy to tig 'em up, and it will be for the EFR as well..
    05Taco4x4 and MadTaco461[QUOTED] like this.
  18. Apr 6, 2018 at 4:33 PM
    #6718
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thank you!
  19. Apr 6, 2018 at 4:33 PM
    #6719
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fawk yeah! Welcome back EFR!
    yota243 likes this.
  20. Apr 6, 2018 at 4:34 PM
    #6720
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Looks like a T4 flange? Yes?
