Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 6, 2018 at 7:09 PM
    #6741
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Very close need to put 2&3 under and outside of 1&4. Then equal length. No subi gurgle. Bit more difficult to sketch.
  2. Apr 6, 2018 at 7:13 PM
    #6742
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    https://www.cxracing.com/EB-T4-300V-CAST_VB_1-1_KIT
    Im thinking of something like this, to allow for that if you really want.
    yota243[QUOTED] likes this.
  3. Apr 6, 2018 at 7:14 PM
    #6743
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I nearly did that but i was thinkin it would get in the way of the 1,4 turbo i guess if the 2,3 went under it would be fine or have one flange up and one down...
    MadTaco461[QUOTED] likes this.
  4. Apr 6, 2018 at 7:17 PM
    #6744
    MadTaco461
    CA
    Kinda stock
    twin turbski. That be wild. Easier to do a larger twin scroll.
  5. Apr 6, 2018 at 7:19 PM
    #6745
    yota243
    E.J.
    north Alabama
    But then we get away from equal length or the ability to use the heavier sturdier tube i think...
    MadTaco461[QUOTED] and Jcyr like this.
  6. Apr 6, 2018 at 8:38 PM
    #6746
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    Those are really nice! Where did you get those from?
    05Taco4x4 likes this.
  7. Apr 6, 2018 at 10:09 PM
    #6747
    MadTaco461
    CA
    Kinda stock
    Yeah turns into tubular. I’m going to try it on my truck. Should stay in place
  8. Apr 7, 2018 at 12:32 AM
    #6748
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Took my girl to dinner, fingered my phone and saw three new pages and was all like :spy: what do we have here?
    I read this GREAT post and was thinking, dude- that's awesome! :bowdown:
    but THEN I see THIS and got a full blown swellington
    Yes, where did you get that- more importantly, how do I get one? You wanna trade an intake for an exhaust? :evil:
    I got this in today :bananadance:
    I didn't realize it has a hole for a 5th injector, I thought all the holes were threaded- surprise
  9. Apr 7, 2018 at 6:12 AM
    #6749
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Giggity giggity goo
    Jcyr, 05Taco4x4 and TacoLeeSD like this.
  10. Apr 7, 2018 at 1:02 PM
    #6750
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Crazy weather in Dallas it was 34 degrees earlier and its still 38. Yesterday it was 80 degrees
  11. Apr 7, 2018 at 1:10 PM
    #6751
    05Taco4x4
    2TR-FE Enthusiast
    That type of weather gives me a cold
    Jstand[QUOTED] likes this.
  12. Apr 7, 2018 at 4:16 PM
    #6752
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Same over here on the east coast.
  13. Apr 7, 2018 at 4:19 PM
    #6753
    05Taco4x4
    2TR-FE Enthusiast
    No it’s not
    Jstand likes this.
  14. Apr 7, 2018 at 4:22 PM
    #6754
    Jstand
    Irving,Tx
    I got home from work and changed the WG spring to the next one down which gave me 8 psi. After changing the spring I went for a tuning run. First I did some 1/2 and 3/4 throttle runs and found a spot where it would drop to 9.9-10.9 on the afr’s. I was able to pinpoint that spot and smooth it out then I saw that I had that same problem at WOT afr’s where 16.00-17.00. For that I highlighted the table on the 4000 to 5000 rpm range partly in the vacuum section full boost and bumped the fuel up a lot. I was able to get in the 13s afr’s. Injector duty is 91% which I found out by putting the gauges on the AEM full screen and looked over at it until it shifted into the next gear :D I’m just glad I’m getting somewhere now.:thumbsup:
    Torspd, boostedka and 05Taco4x4 like this.
  15. Apr 7, 2018 at 4:25 PM
    #6755
    Jstand
    Irving,Tx
    The humidity though!!
    05Taco4x4[QUOTED] likes this.
  16. Apr 7, 2018 at 5:03 PM
    #6756
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Anything over 10% for us in NM is like a Sauna!
  17. Apr 7, 2018 at 7:49 PM
    #6757
    yota243
    E.J.
    north Alabama
    I hate you...
  18. Apr 7, 2018 at 7:51 PM
    #6758
    MrCrowntown
    Alyn
    Ky
    Well, LCE was too busy, so I got a flange to make one myself.. its been a long time coming! Once I get a manifold made up and finalized, we can talk about tradsies
    Jcyr and 05Taco4x4[QUOTED] like this.
  19. Apr 8, 2018 at 9:47 AM
    #6759
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Figure out how to log your runs. Then you don't have to look on the fly. You do a run, log the data, analayze it, and make adjustments in the approrite RPM and boost ranges. Log again, adjust again, so on and so forth. THAT is how you tune.
  20. Apr 8, 2018 at 3:27 PM
    #6760
    MadTaco461
    CA
    Kinda stock
    That’s how all the cool kids tune.
    TacoLeeSD, vasinvictor and Jstand like this.
