Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 27, 2017 at 11:36 AM
    #681
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Boosted LSx speed boat?
  2. Apr 27, 2017 at 11:59 AM
    #682
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  3. Apr 27, 2017 at 12:11 PM
    #683
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    MadTaco461 likes this.
  4. Apr 27, 2017 at 12:31 PM
    #684
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Needs twin BW's!
    MrCrowntown[QUOTED] likes this.
  5. Apr 27, 2017 at 1:34 PM
    #685
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I believe several people had voltage bleed through the FIC6 with the ultragauge installed. I'm not sure how exactly... I also read people had trouble tuning with the ultragauge IIRC with thing acting erratic. I assume its because the UG taps into things the SG2 does not...
  6. Apr 27, 2017 at 2:48 PM
    #686
    MadTaco461
    CA
    Kinda stock
    It does have full air conditioning which like no v8 swaps have in here.
    MrCrowntown[QUOTED] and Torspd like this.
  7. Apr 27, 2017 at 4:55 PM
    #687
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The PLX gauge I put in my truck is digital and displays inhg for vacuum. The factory gauge in my WRX displays PSI for vacuum.
    The ultragauge just plugs into the OBD2 port like the scangauge.
  8. Apr 27, 2017 at 5:43 PM
    #688
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Are there a bunch of different one I don't want to get the wrong one
  9. Apr 27, 2017 at 6:03 PM
    #689
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    This is the one for android i assume it looks the same for iphones
  10. Apr 27, 2017 at 6:06 PM
    #690
    yota243
    E.J.
    north Alabama
  11. Apr 27, 2017 at 6:34 PM
    #691
    Brice
    Brice Turbo Member
    Brice
    Texas
    Yes but I'm thinking the ultragauge is using more/different pins than the SC2 I dunno though.
  12. Apr 27, 2017 at 6:42 PM
    #692
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I have an ultragauge in my truck, but I've never paid attention to how many pins are in the connector that plugs into the obd2 port.
  13. Apr 27, 2017 at 6:44 PM
    #693
    Brice
    Brice Turbo Member
    Brice
    Texas
    Take a pic and we can compare :D
  14. Apr 27, 2017 at 6:46 PM
    #694
    yota243
    E.J.
    north Alabama
    My penis much bigger than yours
    Pen is i forgot the space
    Torspd likes this.
  15. Apr 27, 2017 at 6:50 PM
    #695
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I'll snap a pic tomorrow or this weekend if I don't forget.
    I don't know bro. My pen is pretty big. :rofl:
    As for the other one, I'm hung like a tuna can. 1.5" long and 4" across. I can't hit bottom, but I'll split you in half. :ohsnap:
  16. Apr 27, 2017 at 6:51 PM
    #696
    Brice
    Brice Turbo Member
    Brice
    Texas
    Mega chode^^^
  17. Apr 27, 2017 at 7:20 PM
    #697
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have heard of other people having strange issues related to the Ultragauge, from others besides Brice, as well. Few and far between though. I have had them without issue though.
  18. Apr 28, 2017 at 6:47 AM
    #698
    Jstand
    Irving,Tx
    It just seems like the bov is opening soon but i dont want to put strain on the turbo ill just have to expirement
  19. Apr 28, 2017 at 7:43 AM
    #699
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I had a scan gauge and when I installed the FIC-6, I had some major issues. I can't remember what they were, I'll have to dig it up in my build.
    You need to tune the BOV spring. I think there is a way to adjust it. You shouldn't be dumping boost like that. Its not a bad thing perse, but everytime you left of the gas you lose all your boost and have to build it back up which can affect performance. If you have a manual trans, you will lose all your boost between each shift.
  20. Apr 28, 2017 at 7:44 AM
    #700
    Brice
    Brice Turbo Member
    Brice
    Texas
    If I'm correct your BOV should close under boost then open under the sudden vacuum?
    EDIT: I meant bov not wastegate for those who saw that :D
    Jstand likes this.
