Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 5, 2018 at 11:17 AM
    #7301
    Loxsl
    Loxsl tHeMaChInIsT
    Lancaster PA
    06 2.7 Tacoma 4x4 SR5 access cab
    Add a leaf and air springs
    If you dont have a surface plate and gauge blocks you'll need a 3-4in mic. The good stuff is starrett, mitutoyo, or brown and sharpe(tesa). Spi is a cheaper alternative though. Cruise Ebay and craigslist for deals.
    Make sure its .0001 gradations.
    05Taco4x4[QUOTED] likes this.
  2. May 5, 2018 at 11:48 AM
    #7302
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I'm familiar with Mitutoyo from work, good stuff
  3. May 5, 2018 at 4:41 PM
    #7303
    05Taco4x4
    2TR-FE Enthusiast
    I need clarification on machine shop process, first for me.
    My Build
    Forged pistons/rods
    Stainless valves
    Viton valve seals
    Paint engine block
    My Plan :devil:
    DIY hot tank, Magnaflux and paint then send to machine shop for bore and resurface. What would they charge me for, are there any "hidden charges"? What's a fair price, too much?
    The head is getting new ss valves; all I need to do is DIY lap those, right? No machine work other than resurface?
    Hot Tank
    Block- Potassium or Sodium hydroxide (lye) @ 1lb/5gal water
    Head- Simple Green Pro HD (nearly same Extreme Aircraft and Precision Cleaner) @ 1/3 water
    Magnaflux
    01-5750-77 Cleaner
    01-5155-77 Penetrant
    01-5352-77 Developer
    Do you know if this is a viable alternative:
    CRC
    03108 Cleaner
    03106 Penetrant
    03107 Developer
  4. May 5, 2018 at 4:43 PM
    #7304
    Loxsl
    Loxsl tHeMaChInIsT
    Lancaster PA
    Out of curiosity why ss valves?
    Rust isn't an issue and a good 4140 or similar is stronger especially under heat situations.
  5. May 5, 2018 at 4:45 PM
    #7305
    05Taco4x4
    2TR-FE Enthusiast
    Because it's all I can find lol
    Is it lighter or heavier?
    Where can I find 4140 valves for 2TR?
  6. May 5, 2018 at 4:48 PM
    #7306
    Loxsl
    Loxsl tHeMaChInIsT
    Lancaster PA
    I dont think the weight will be crazy different, but unless you're trying to rev to some crazy level it shouldn't be an issue. 4140, 4340, 4130 anything like that.
    I didn't see much around for valve options. If you have the size you can probably order them custom.
    Jcyr likes this.
  7. May 5, 2018 at 4:51 PM
    #7307
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    We want all the revs!!!! Lol
    MadTaco461 and 05Taco4x4 like this.
  8. May 5, 2018 at 4:53 PM
    #7308
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I'd seriously consider getting hardened seats if you run those SS valves.. Ive seen those stock valves do just fine up through 350hp(their dyno said higher, but I dont believe it completely lol dont know when it was last calibrated)
    Jcyr likes this.
  9. May 5, 2018 at 5:03 PM
    #7309
    05Taco4x4
    2TR-FE Enthusiast
  10. May 5, 2018 at 5:09 PM
    #7310
    05Taco4x4
    2TR-FE Enthusiast
    I had a guy tell me $1000 on Thursday to Magnaflux, soda blast and install seats. I'm not paying that. I don't think I'm going to be over 350 honestly
  11. May 5, 2018 at 5:11 PM
    #7311
    MrCrowntown
    Alyn
    Ky
  12. May 5, 2018 at 5:12 PM
    #7312
    05Taco4x4
    2TR-FE Enthusiast
    :thumbsup:
  13. May 5, 2018 at 5:14 PM
    #7313
    MrCrowntown
    Alyn
    Ky
    What about just for seats?
    Why magnaflux? You have something on the block that concerns you?
  14. May 5, 2018 at 5:19 PM
    #7314
    05Taco4x4
    2TR-FE Enthusiast
    I gotta call him back with more specific questions. That shop has a great reputation, I want to use him but not getting ripped off. Maybe he made a few assumptions, like he had to dis/assemble stuff too idk.
    I have to call other shops too; my mission Monday will be to have a shop decided on.
    No, but I think it's necessary before I build this engine up, am I crazy?
  15. May 5, 2018 at 5:21 PM
    #7315
    MrCrowntown
    Alyn
    Ky
    Not completely, but if its and extra hour or two of time, it will add to that total
  16. May 5, 2018 at 5:26 PM
    #7316
    05Taco4x4
    2TR-FE Enthusiast
    I was quoted ~$120 each piece for Magnaflux, that's why I found the part numbers above to do myself. The CRC only totaled ~$35 and is enough to do both
    MrCrowntown likes this.
  17. May 5, 2018 at 5:27 PM
    #7317
    MrCrowntown
    Alyn
    Ky
    Get the seats done, and DIY the rest. You got this :thumbsup:
  18. May 5, 2018 at 5:28 PM
    #7318
    05Taco4x4
    2TR-FE Enthusiast
    Exactly, that's why I gotta call him back
  19. May 5, 2018 at 5:34 PM
    #7319
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Lce told me my head needs new seats if I plan to rev out past factory rev limit. I’m just going to torture the stock block.
  20. May 5, 2018 at 5:45 PM
    #7320
    05Taco4x4
    2TR-FE Enthusiast
    You have to keep in mind my use- I want to come to rpm quicker, not higher. I’ve never even seen 3500 rpm in this truck lol
    I just don’t think it’s for me.
    MadTaco461[QUOTED] likes this.
