Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 18, 2018 at 11:10 AM
    #7461
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    They are coming out with what we've been brainstorming here, and aftermarket has been doing for the 2.7 3rz .
    yota243 likes this.
  2. May 18, 2018 at 11:13 AM
    #7462
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I kind of want to find a tundra with no engine and do a swap now..!!!
  3. May 18, 2018 at 11:37 AM
    #7463
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    So is there something different than just twin scroll on the turbo? I saw this about mazda using leuvers in the manifold and wondered if a twin scroll could be retrofitted to do basically the same thing
    https://youtu.be/UCEarzwakgc
    Also i almost never say anything positive about GM but peak torque at 1500 rpm... Bravo
    MadTaco461 likes this.
  4. May 18, 2018 at 11:39 AM
    #7464
    MrCrowntown
    Alyn
    Ky
    They have a VTEC style lobe change mechanism on the cam to allow 4 different power modes, as well as dual VVTi with direct injection
  5. May 18, 2018 at 11:41 AM
    #7465
    yota243
    E.J.
    north Alabama
    Im sure you could buy a tundy with a 5.7 and sell it to a reg cab guy that wanted to swap in a v8 and take his 2tr and make up the difference for your build from dat extra cheddah
    MrCrowntown[QUOTED] likes this.
  6. May 18, 2018 at 11:42 AM
    #7466
    yota243
    E.J.
    north Alabama
    Who?
  7. May 18, 2018 at 11:42 AM
    #7467
    MrCrowntown
    Alyn
    Ky
    Been thinkin bout it the past half hour lol
    yota243[QUOTED] likes this.
  8. May 18, 2018 at 11:43 AM
    #7468
    MrCrowntown
    Alyn
    Ky
    the new chevy 4cyl
  9. May 18, 2018 at 11:45 AM
    #7469
    yota243
    E.J.
    north Alabama
    Ok i thought u may have meant mazda
  10. May 18, 2018 at 12:03 PM
    #7470
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    It definitely all sounds interesting. It's basically what my goals are. Super low spool for low end power but higher max power numbers.
    Alao, I thought the video said 3 power modes plus cylinder deactivation.
    Jcyr and MrCrowntown[QUOTED] like this.
  11. May 18, 2018 at 12:05 PM
    #7471
    MrCrowntown
    Alyn
    Ky
    Thats 4 modes it cycles through lol
  12. May 18, 2018 at 12:11 PM
    #7472
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I understood it to be the cylinder deactivation is couple with the other 3. Like you could have the fuel eco mode with or without cylinder deactivation, or normal mode with or without cylinder deactivation. Hopefully, they wouldn't pair cylinder deactivation with a power mode.
    If any kind of aftermarket performance stuff crops, I'm sure killing of the cylinder deactivation will part of it. Just like on the v8.
  13. May 18, 2018 at 12:26 PM
    #7473
    MrCrowntown
    Alyn
    Ky
    I am having a hard time thinking how they are going to cylinder deactivate a 4cyl without it shaking itself to bits lol they mentioned a damper system in the torque converter so maybe thats the secret
  14. May 18, 2018 at 12:30 PM
    #7474
    yota243
    E.J.
    north Alabama
    I was wondering the same, but i guess if at max power it is making v8 numbers, it sgould be making 4cy numbers on 2 cyl right? And at 1500 rpm (unless some false advertising is a foot)
  15. May 18, 2018 at 12:48 PM
    #7475
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    They all copying us. Though 90% torque at 1500rpm would be nice.
    Torspd and MrCrowntown like this.
  16. May 18, 2018 at 12:49 PM
    #7476
    yota243
    E.J.
    north Alabama
    All hondas have that (90% of practically nothing is practically nothing)
    MadTaco461[QUOTED] likes this.
  17. May 18, 2018 at 12:52 PM
    #7477
    MadTaco461
    CA
    Kinda stock
    I'd need pistons and rods to handle 300 ftlb of torque at 1500 rpm
  18. May 18, 2018 at 1:23 PM
    #7478
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
  19. May 18, 2018 at 1:34 PM
    #7479
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
  20. May 18, 2018 at 1:35 PM
    #7480
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes. Yes you should.
