Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 5, 2017 at 6:52 AM
    #821
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Thanks bud, will do
  2. May 8, 2017 at 4:09 AM
    #822
    GreeGunc
    Jacob
    North GA
    I forgot which clutch you guys recommended, to lazy to go through the pages :D
    1st gen 2.7l probably max of 14psi for a while, 7psi for a bit
    Love clutch dumps:rolleyes:
    Also, can you run an intercooler upside down? I need the inlet/outlet up top but havnt found as many as on the bottom
  3. May 8, 2017 at 5:16 AM
    #823
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    mine is upside down I guess and it is running fine but I haven't really gotten in to any boost
    GreeGunc[QUOTED] likes this.
  4. May 8, 2017 at 5:41 AM
    #824
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The air to air intercooler doesn't care about position. Water to air, might be a different story.
    GreeGunc likes this.
  5. May 8, 2017 at 6:16 AM
    #825
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MrCrowntown likes this.
  6. May 8, 2017 at 9:32 AM
    #826
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  7. May 8, 2017 at 10:04 AM
    #827
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. May 9, 2017 at 6:26 AM
    #828
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I put the turbosmart bov in yesterday and shortened recirculating tubes truck runs much smoother and dosen't die :bananadance:
    MrCrowntown, Torspd and boostedka like this.
  9. May 9, 2017 at 6:36 AM
    #829
    Jstand
    Irving,Tx
    What a learning experience its been with this turbo install. I couldn't have gotten this far without help from boostedka, yota243, Madtaco461, StAndrew, Torspd, Mrcrowntown and everyone else who put their 2 cents worth THANK YOU!! :bowdown: and I'm sure ill have more questions :)
    j0shu4, StAndrew, MrCrowntown and 4 others like this.
  10. May 9, 2017 at 6:49 AM
    #830
    Jstand
    Irving,Tx
    Next question if I put pink top injectors without anything else would there be an improvement if nothing else less detonation ?
  11. May 9, 2017 at 7:05 AM
    #831
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    They'll help you get a little extra fuel under boost. I think they are about 10% higher flowing than the browns. If anything, you'll get more evenly distributed fuel just from having clean injectors vs 200k carbon build up injectors.
    Jstand[QUOTED], Torspd and GreeGunc like this.
  12. May 9, 2017 at 7:23 AM
    #832
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you changed your fuel filter recently?
    Also, very happy to hear how much more refined the operation is now. You are a lot wiser now than when you first started. All of the trials and tribulations, bridge that gap between the idea of what works, and the reason why good parts prove their value.
    Jstand[QUOTED] likes this.
  13. May 9, 2017 at 7:35 AM
    #833
    Jstand
    Irving,Tx
    Yes I have learned a lot I changed the fuel filter at around 130000 miles.
  14. May 9, 2017 at 8:05 AM
    #834
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And you have 200k now? If so, you should change it again.
    I also Highly recommend Redline Oil S1 Fuel system cleaner. It is concentrated, and works very well. Will help keep the injectors running all at a lot closer precentage to each other.
    Jstand likes this.
  15. May 9, 2017 at 8:12 AM
    #835
    Jstand
    Irving,Tx
    Is MP4193 the correct p# for the injectors ?
  16. May 9, 2017 at 11:03 AM
    #836
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Make sure your fuel pressure regulator is hooked up to your manifold so your fuel pressure rises with boost. I get low 12's in open loop at about 1-1.5 PSI (highest I've boosted so far :oops:)
  17. May 9, 2017 at 11:40 AM
    #837
    Jstand
    Irving,Tx
    Mine is at 11.2 open loop at 7psi but I think I'm push the limit of everything the way it is
  18. May 9, 2017 at 11:51 AM
    #838
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    11.2 is very good. No reason to go richer.
  19. May 9, 2017 at 1:25 PM
    #839
    GreeGunc
    Jacob
    North GA
    Since I'm doing my ic in grill, i was thinking of cutting the tabs on grill and mounting the grill to the IC to get a cpl more inches...
  20. May 9, 2017 at 1:38 PM
    #840
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    won't line up with well....everything else though. lights, corner lights, hood..
