Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Aug 20, 2018 at 9:06 PM
    #8521
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What about all of the performance shops IN Cali? They cannot ship it to you either?
    Such as www.frsport.com?
  2. Aug 20, 2018 at 9:25 PM
    #8522
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Small places can usually get away with it. It’s just a really weird sue happy battle carb has with companies. It’s way over my head. The work around is just buy from somewhere else. Big companies like Amazon, jegs and summit racing is where this comes from.
    I’m going to be ordering turbo stuff soon so curious how messy it is going to be. Figured universal parts are cool since it isn’t vehicle specific.
    This is the bs that started this mess.
    https://ww2.arb.ca.gov/news/nationw...illion-settle-case-selling-illegal-auto-parts
  3. Aug 21, 2018 at 4:46 AM
    #8523
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    "For Off Road Use Only," I suppose no longer leaves it in the hands of the consumer.
    Stupid CARB. Quote,"We make the rules so that we know how to break them." < True quote.
    RedLantern and MadTaco461 like this.
  4. Aug 21, 2018 at 5:05 AM
    #8524
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    What you need is a middle man...gnome saying.
    MadTaco461, MrCrowntown and yota243 like this.
  5. Aug 21, 2018 at 5:16 AM
    #8525
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Or like an Oregon p.o. box ir somethin
    MadTaco461 likes this.
  6. Aug 21, 2018 at 7:34 AM
    #8526
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Jroc in the house!
  7. Aug 21, 2018 at 7:34 AM
    #8527
    MrCrowntown
    Alyn
    Ky
    I giggled, and then cried.
    05Taco4x4 and MadTaco461 like this.
  8. Aug 21, 2018 at 7:37 AM
    #8528
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    @Torspd any idea how I could do what Boostedka did in his megasquirtto the haltech
  9. Aug 21, 2018 at 8:25 AM
    #8529
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Have you checked into how your IAC Valve is wired up with the PNP harness? I would think that would be a good starting point to know how to tweak the settings in the software. See if Paradise wired up two grounds and which is wired to what. I think that the newer 1st gens like yours also have a RSD wire...I'm not sure what that does. I just know the RSO opens the valve and the RSC closes it.
  10. Aug 21, 2018 at 10:20 AM
    #8530
    Jcyr
    Jack
    North east
    I wasn’t sure if there’s a way to troubleshoot that in the software because it’s almost impossible to get a hold of parasites
    Torspd likes this.
  11. Aug 21, 2018 at 1:28 PM
    #8531
    boostedka
    James
    NM
    I would just pull the harness out of the truck and use a ECU Pinout to find which are the idle wires. Then use the Haltech Wiring diagram to figure out what they wired into that harness. Then you'll know which settings to address in your software.
    Here's a 1st Gen ECU Pinout guide if you don't already have one handy:
    http://www.well.com/user/mosk/images/Early_Tacoma_ECUs_v2.pdf
    Torspd and MadTaco461 like this.
  12. Aug 21, 2018 at 6:56 PM
    #8532
    Jcyr
    Jack
    North east
    Thanks for the link its much better than what i was using
    Torspd and boostedka like this.
  13. Aug 22, 2018 at 4:33 AM
    #8533
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. This ^^^ :D Like we were trying to say the whole time. That Harness needed a pinout sheet. Alakazam
    boostedka[QUOTED] likes this.
  14. Aug 22, 2018 at 6:49 AM
    #8534
    Jcyr
    Jack
    North east
    Yeah and like everyone else has realized with paradise it’s impossible to just get something like that after already paying... I might just run my own three wires from the haltech. It might be easier
    Torspd[QUOTED] likes this.
  15. Aug 22, 2018 at 7:17 AM
    #8535
    boostedka
    James
    NM
    The IAC Valve is a three wire valve. The middle wire is a fused positive that you can leave wired in the stock wiring. The other two are ground wires that are used to open or close the valve depending on which on is being (more) grounded. I say "more" because it's a varied duty cycle so that if one is has a 40% duty cycle then the other will have a 60% duty cycle like a push pull valve. You have to figure out which wires the Haltech uses to do this to know which should be wired in there then you control those two wires through your software. Which Haltech unit are you running?
    Torspd likes this.
  16. Aug 22, 2018 at 8:14 AM
    #8536
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Anybody have an 05 ecu pin out?
  17. Aug 22, 2018 at 8:30 AM
    #8537
    MadTaco461
    CA
    Kinda stock
    MrCrowntown likes this.
  18. Aug 22, 2018 at 8:33 AM
    #8538
    Jcyr
    Jack
    North east
    Its the 550 and you can select wires to be the output
  19. Aug 22, 2018 at 10:23 AM
    #8539
    boostedka
    James
    NM
    I'm looking at the info on the 550 Elite on the Haltech website.
    Quote: "Closed Loop Idle Speed Control - requires 1 or 2 user defined outputs (BAC type)"
    Features: "5 x Digital Pulsed Outputs"
    Looking at the wiring diagram, the violet wires with differet color stripes are the DPO's. I'm guessing that you can use two of those outputs to gain Idle speed control as long as they are defined that way by you in the software. IDK if these Digitial Outputs are what are being referred to when they say "1 or 2 user defined outputs (BAC type)"
    I've not actually used a Haltech so I can't say for sure if this is correct info. The Haltech guys on here will have to say if that's right or I'm just saying nonsense.
    https://www.haltech.com/product/ht-150400-elite-550-ecu/
    http://files.haltech.com/downloads/ESP/Updated Diagrams 1_3_2018/Elite_550_Premium_Harness_Diagram.pdf
    http://files.haltech.com/downloads/ESP/Updated Diagrams 1_3_2018/Elite_550_Basic_Harness_Diagram.pdf
    05Taco4x4, MadTaco461 and Torspd like this.
  20. Aug 22, 2018 at 11:05 AM
    #8540
    Jcyr
    Jack
    North east
    Yea you’re right the issue is the way paradises jumper is made it’s basically impossible to test without a legit pinout diagram which is why I’ll probably end up just doing that portion with my own wire
