Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Aug 22, 2018 at 11:10 AM
    #8541
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    It has to be one of the dpo’s.
    How many are not assigned?
    You can go though them one by one setting them to the idle control and see if they work.
    Or you can find the pin out for your ecu locate thee idle wires. Then on your haltech harness see what color there hooked too. If paradise changed the color just check for continuity to find which dpo they are assigned to.
    You could probably take some photos and we could help you also.
    boostedka likes this.
  2. Aug 22, 2018 at 11:17 AM
    #8542
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Also did you say you could raise the idle but not lower it? There is a table for minimum opening of the idle valve. If you can raise it but not lower it this could be the cause. It’s set to make sure the idle doesn’t drop too low.
    Torspd likes this.
  3. Aug 22, 2018 at 11:20 AM
    #8543
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    The table is under -idle control -min output. You can make them all 0 to test.
  4. Aug 22, 2018 at 11:41 AM
    #8544
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    No I can’t raise or lower it. I’ll get pictures soon
  5. Aug 23, 2018 at 5:29 AM
    #8545
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Well it was right at 60° when I woke up this mornin...
    Sorry for the lack of focus but u get the idea 64.4 intake temp halfway to work and it will soon be cool enough to get some serious work done
    MrCrowntown, 05Taco4x4 and buyobuyo like this.
  6. Aug 23, 2018 at 5:35 AM
    #8546
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No more hot box tuning eh?
    yota243 likes this.
  7. Aug 23, 2018 at 5:45 AM
    #8547
    yota243
    E.J.
    north Alabama
    My buddy actually put a central unit in his shop, it helps a lot with humidity and it keeps it about 10-15° cooler than ambient but 60-70 is still way better than 80
    MadTaco461 likes this.
  8. Aug 23, 2018 at 7:40 AM
    #8548
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    It’s been cool in socal this week too. Feels great but been working a lot so can can’t just kick back and enjoy it
    dirtdigginjoe, Jcyr and yota243 like this.
  9. Aug 23, 2018 at 3:45 PM
    #8549
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Nights have been cool, which the truck loves. Days are still getting up to about 80-85, but the cool nights are actually enjoyable for once.
    Except I've been working 90hr weeks, so fuck if I even get to feel the weather! lol
  10. Aug 23, 2018 at 8:01 PM
    #8550
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    It's down to 105 here. yay.
    wheeliest and MadTaco461 like this.
  11. Aug 24, 2018 at 9:10 AM
    #8551
    MadTaco461
    CA
    Kinda stock
    Need to do some tuning this weekend so I can hook this thing up.
  12. Aug 24, 2018 at 2:57 PM
    #8552
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    What is the recommended trim for a t3/t4 low boost?
  13. Aug 24, 2018 at 9:35 PM
    #8553
    MadTaco461
    CA
    Kinda stock
    Probably no bigger than a 50 trim on a 4 cyl
    Brake Weight[QUOTED] likes this.
  14. Aug 24, 2018 at 9:56 PM
    #8554
    Brake Weight
    Thanks. LCE’s is a 48 I believe but it leaves nothing for the upper end if wanting to go more. Just curious what people were running ‘real world’.
  15. Aug 25, 2018 at 12:23 AM
    #8555
    MadTaco461
    CA
    Kinda stock
    50 trim is that magic size for good spool and if you crank it up you got room to grow. If you never going above 250-300 hp a 48 is good. I just wouldn't go above 50 so you can have a wide powerband
  16. Aug 25, 2018 at 6:45 AM
    #8556
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So a new video after the tuning, yes??? Did you ever get that IAT sensor in?
  17. Aug 25, 2018 at 8:16 AM
    #8557
    MadTaco461
    CA
    Kinda stock
    Still running on the oem one. Trying a few things out with tuning. These injectors are so big I’m seeing if it solves the idle heat soak issue. Should know if I can solve the problem this weekend. Closed loop tuning is annoying on piggybacks. Takes forever.
    I’ll do a few pulls along the way. Going to get a spring pressure baseline with good afr first. Then get that ebcs in there. I see lots of fuel being burnt in this process.
    buyobuyo and boostedka like this.
  18. Aug 25, 2018 at 9:16 AM
    #8558
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    for anyone who might be interested
    MadTaco461 and boostedka like this.
  19. Aug 25, 2018 at 9:17 AM
    #8559
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Funny you say that about the exhausted fuel. I was doing idle to 2500 rpm tuning w/datalogging. Went though nearly a half tank...lol.
  20. Aug 25, 2018 at 7:30 PM
    #8560
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did a little fab-life work today. Modding a mod.
    Added in a resonator cat-less system. Which was a mod of a few days prior. The test: look for any possible efficiency gains by removal of the two inline cats, and determine if a resonator would be needed as a substitution for their noise cancelling.
