Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 7, 2018 at 10:35 PM
    #8661
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
  2. Sep 8, 2018 at 8:19 AM
    #8662
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is super professional.
  3. Sep 8, 2018 at 9:13 AM
    #8663
    tacodown
    tacodown Well-Known Member
    brant
    holtwood, Pa
    96 tacoma 2.7
    What would be the best way to bump up the idle rpm? Stock ECU. I've done it before with the throttle cable but would that be the smartest way to go about it
  4. Sep 8, 2018 at 11:27 PM
    #8664
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    My new exhaust tip
    E1C8A226-E184-436E-A4ED-A3776714BC9F.jpg C213266F-4F21-43B9-A7D1-B49B85598725.jpg C436CDF7-7AC7-41B1-8667-0428D59EFFB8.jpg
  5. Sep 9, 2018 at 9:22 AM
    #8665
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I’ve got a VW OEM spec turbo in a box after putting a bigger one on my Jetta. I don’t quite understand the intricacies of the various trims but found a replacement turbo on fleaBay listing them. I doubt that this little snail would move enough air but if it did then it’d save me some coin.
    https://www.ebay.com/ulk/itm/253283962614
  6. Sep 9, 2018 at 10:39 AM
    #8666
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Wonder what the color shift looks like after some use? I believe that was the screamer pipe, on a turbo setup.
  7. Sep 9, 2018 at 10:43 AM
    #8667
    05Taco4x4
    2TR-FE Enthusiast
    lol yeah, buddy shared these pics with me last night, on some Honda I believe.
    That is some great work.
  8. Sep 9, 2018 at 12:16 PM
    #8668
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    His work is unhinged!
  9. Sep 9, 2018 at 3:06 PM
    #8669
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Is a screamer pipe super loud? Never rode in a car with an external gate
  10. Sep 9, 2018 at 3:35 PM
    #8670
    RedLantern
    Honolulu, Hi
    It could get pretty loud. Sometimes even louder than the turbo itself. Kinda sounds like compressor hose shooting air but not
    MadTaco461[QUOTED] likes this.
  11. Sep 9, 2018 at 4:05 PM
    #8671
    MadTaco461
    CA
    Kinda stock
    Might be a bit too bold for me.
  12. Sep 9, 2018 at 4:56 PM
    #8672
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I personally don't like an external gate vented to atmosphere. I like it routed back into the exhaust. It may be my obsession with supras though lol
    RedLantern likes this.
  13. Sep 9, 2018 at 5:16 PM
    #8673
    05Taco4x4
    2TR-FE Enthusiast
    Same here
  14. Sep 9, 2018 at 5:17 PM
    #8674
    MrCrowntown
    Alyn
    Ky
  15. Sep 9, 2018 at 5:22 PM
    #8675
    Jeffas7
    Jeffas7 Monta what na???
    Missoula
    12quad6spd
  16. Sep 9, 2018 at 7:05 PM
    #8676
    MadTaco461
    CA
    Kinda stock
    Routed back in the exhaust it is. That sounds good.
  17. Sep 9, 2018 at 7:45 PM
    #8677
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Some people (like me) like the sound of an open dumped gate...others don’t. I also like that you don’t lose any power routing it back into the exhaust.
    It definitely is pretty loud though. Sounds like a jet plane. Lol. It does drown out the turbo some. You can also get a little muffler for it too to quiet it down some.
  18. Sep 10, 2018 at 10:47 AM
    #8678
    MadTaco461
    CA
    Kinda stock
    Wired up my ebcs, air temp sensor, bypassed oem air sensor on maf, and bypassed egr. Might have time to plug it in tonight. That big yellow mess of tape is my resistors I soldered in so they don't rattle apart.
  19. Sep 10, 2018 at 11:43 AM
    #8679
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Now to see how well it really works!
    MadTaco461 likes this.
  20. Sep 10, 2018 at 11:47 AM
    #8680
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My update isn't as cool as yours, but I did just a few moments ago order the few remaining material pieces that I need to re-route my turbo. Hopefully. :fingerscrossed:
    How these things go though, it will likely not be the case. Lol.
