Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 10, 2017 at 9:54 AM
    #861
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    on the injector note, what size are the stock 4.0 injectors, specifically in relation to the 61# urd injectors? like if I am running e85 which needs like 35% more fuel how much extra injectors do I have and or how bad will a stock tune run on these while I street tune for the larger injectors?
  2. May 10, 2017 at 10:24 AM
    #862
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. May 10, 2017 at 10:27 AM
    #863
    yota243
    E.J.
    north Alabama
    so since they are more than double the size of oem even with a 35% difference in fuel need it will idle very poorly during the initial tune...
  4. May 10, 2017 at 10:27 AM
    #864
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those Deka injectors, yes. It will be very rich.
    yota243 likes this.
  5. May 10, 2017 at 10:30 AM
    #865
    yota243
    E.J.
    north Alabama
    are there some safe ball park figures to load to the ecu prior to start up, or do you just deal with it while you input data?
  6. May 10, 2017 at 10:32 AM
    #866
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just going to be pulling voltage at the start, while idling. Then going from there.
    yota243 likes this.
  7. May 10, 2017 at 11:27 AM
    #867
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Does anyone have this info ?
  8. May 10, 2017 at 12:24 PM
    #868
    Jstand
    Irving,Tx
    Is it just a normal thing with turbos for the engine to die if you spool it up then let off suddenly ?
  9. May 10, 2017 at 12:52 PM
    #869
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No.
    MrCrowntown likes this.
  10. May 10, 2017 at 12:55 PM
    #870
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Short answer is yes but that is because people setup their MAF/BOV incorrectly.
    Long answer: Depending on where you mount your MAF and BOV, boosting and then letting off the gas can cause the air flow to be measured twice by the MAF. The MAF doesn't care which way the air is flowing, it just measures flow. This can cause the ECU to continue to add fuel and your engine will go way rich and stall out.
    If your BOV is mounted between the MAF and the TB, when your TB closes and BOV opens, the air flows out the BOV but the flow is still measured by the MAF.
    If your BOV is mounted between the MAF and turbo, when the TB closes, the pressureized air flows back towards the BOV but the MAF will only measure the air between your TB and MAF.
    There are a lot of thoughts on how to fix this issue. Personnally I recomend mounting your MAF as close to the TB as possible to limit how much air back flows over the MAF. I also recomend you tighten up your BOV so its not dumping all the air too quickly.
    Jstand[QUOTED] likes this.
  11. May 10, 2017 at 1:06 PM
    #871
    Jstand
    Irving,Tx
    The MAF is in the stock position right after the airfilter and the bov (turbosmart Kompact recirc. w/green spring 19hg) between turbo and TB going to between airfilter and turbo
  12. May 10, 2017 at 1:09 PM
    #872
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Picture again please.
  13. May 10, 2017 at 1:22 PM
    #873
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  14. May 10, 2017 at 1:23 PM
    #874
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which size are you going to?
  15. May 10, 2017 at 1:30 PM
    #875
    Jstand
    Irving,Tx
    So the ones that you have are they the same 280cc
  16. May 10, 2017 at 1:32 PM
    #876
    Jstand
    Irving,Tx
    I just want to upgrade from stock to avoid detination
  17. May 10, 2017 at 1:35 PM
    #877
    Jstand
    Irving,Tx
    Ill take a pic in a few minutes of my setup you'll love this
  18. May 10, 2017 at 1:35 PM
    #878
    boostedka
    James
    NM
    From the research I did before my turbo install I found that they are about 315cc. ~10% increase over the browns
    I'm going to Osidetiger 540cc that I'm planning on running with a Megasquirt MS3. I just need to have the time to finish the install. I have most of the wiring done and sitting in the garage....but then life started happening....
    GreeGunc and Torspd[QUOTED] like this.
  19. May 10, 2017 at 1:37 PM
    #879
    Jstand
    Irving,Tx
    I'm interested if those will help me with stock ECU
  20. May 10, 2017 at 1:42 PM
    #880
    boostedka
    James
    NM
    I've been running them on my stock ECU for about a year now @8psi intercooled without any issues. They replaced the exact same injectors you currently have.
