Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 1, 2018 at 5:08 AM
    #8841
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    As did I the 2nd drive after the install. Forgot in the midst of installing everything that I never adjusted the wastegate preload, and hit 14psi...whoops!
    Man, it was real fun though! Immediately bought the Kinugawa adjustable lol.
  2. Oct 1, 2018 at 6:40 AM
    #8842
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I cranked my duty cycle up to 40%. It works. Whoa buddy she woke up. Thought I had an overboost protection setup. I ran right through that,lol
  3. Oct 2, 2018 at 9:50 AM
    #8843
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  4. Oct 2, 2018 at 1:00 PM
    #8844
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
  5. Oct 2, 2018 at 1:11 PM
    #8845
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When Turbo is life!
    MrCrowntown and MadTaco461 like this.
  6. Oct 2, 2018 at 1:16 PM
    #8846
    MadTaco461
    CA
    Kinda stock
    Oh it's life for sure
  7. Oct 2, 2018 at 1:38 PM
    #8847
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    im following a guy on insta thats running 15 on stock internals. dynod 400hp and 460tq on e85
  8. Oct 2, 2018 at 1:51 PM
    #8848
    RedLantern
    Honolulu, Hi
    I wish hawaii has e85. @05Taco4x4 if you plan on running water/meth, i inquired at Oreily and they can ship in the windshield washer mix that has water/meth mixture in it. Just order a whole bunch to make it worth while because they slow boat it in. Price isn’t marked up either.
    05Taco4x4 likes this.
  9. Oct 2, 2018 at 2:05 PM
    #8849
    MadTaco461
    CA
    Kinda stock
    15 is no 400hp on mine. Probably 300hp if I'm lucky. I should be good on pump gas for a while. I really want to hold 15 across the whole rpm range. It was really fun how fast I spooled up compared to boring spring pressure. I probably need 20 to 25psi plus water/meth for 400 plus meth. Still learning the settings on this.
  10. Oct 2, 2018 at 3:47 PM
    #8850
    devinzz1
    devin
    2023 aclb trd or mt
    crank not wheel
  11. Oct 2, 2018 at 3:50 PM
    #8851
    devinzz1
    devin
    2023 aclb trd or mt
    sorry i just went back to his page. he has pistons and rods running 22psi now
    bumpynips is his name
    MadTaco461[QUOTED] and Torspd like this.
  12. Oct 2, 2018 at 3:56 PM
    #8852
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Thanks for looking out :thumbsup:
    I just dropped my block/pistons off at Ted's. Is balancing the crank worth it, $250 worth it? Chad said since going higher torque on aftermarket main studs that I should have caps/block rebored because the higher torque will make it out of round- I'm calling bull on that one, those caps are thick. Looking for input on this one. He said I could throw a bearing, but may be ok.
    Torspd and MrCrowntown like this.
  13. Oct 2, 2018 at 4:35 PM
    #8853
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I had my crank shaft balanced. Harmonics can destroy an engine. Depends on the overall RPM you want to run, plus power level.
    Line honing just takes it a step further. If they are torque'd to a higher rating, it can warp them. You would torque them down to whatever the specification is for the studs, check the bore of each main cap, and then hone/bore with them still torque'd down. Just like using a deck's torque plate when boring/honingthe cylinders.
    MrCrowntown, boostedka and 05Taco4x4 like this.
  14. Oct 2, 2018 at 4:40 PM
    #8854
    05Taco4x4
    2TR-FE Enthusiast
    Thanks, I'm definitely going with the balance. I'm just not sold on the line honing, especially for a "few hundred" (his reply when I inquired how much extra that was). I guess I just don't understand how it can warp them.
    MrCrowntown and Torspd[QUOTED] like this.
  15. Oct 2, 2018 at 5:16 PM
    #8855
    MadTaco461
    CA
    Kinda stock
    lol that username. I hope I'll be happy with 15 psi for a while. Don't want to build my block yet or know how too.
  16. Oct 2, 2018 at 7:19 PM
    #8856
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Get the line bore done. The steel, no matter how thick, will deflect under higher torque. Theres a reason you use a torque plate when honing the cylinders. Same idea applies to the caps. If the contact point from the cap to the bearing is not perfectly concentric, then the bearing will deform as well, and you'll cook the crank. Possibly spin the bearing.
  17. Oct 2, 2018 at 8:38 PM
    #8857
    05Taco4x4
    2TR-FE Enthusiast
    So hone but not bore, right? I swear he said bore.
  18. Oct 2, 2018 at 8:43 PM
    #8858
    MrCrowntown
    Alyn
    Ky
    Hone is used in place of bore a lot of times. It's essentially the same process.
    Torspd likes this.
  19. Oct 2, 2018 at 8:45 PM
    #8859
    MrCrowntown
    Alyn
    Ky
    I see it as "honing" being the final precision cutting. Boring, to me, implies you are taking away lots of material.
    Just how I have seen it used in my years around the industry.
    Either way, get it done lol
    buyobuyo and Jcyr like this.
  20. Oct 2, 2018 at 9:12 PM
    #8860
    MadTaco461
    CA
    Kinda stock
    Glad you guys know stuff about engine building. I’ll ask plenty of questions when I send a rod out the side of my rig
    dirtdigginjoe and MrCrowntown like this.
