Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 17, 2018 at 10:22 AM
    #8941
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That made me chuckle.....blame it on the boost!
  2. Oct 18, 2018 at 4:33 PM
    #8942
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Shout out to CDI (Snap-On) torque wrenches. I have one from 1998, 2012 and 2013- all three were just tested for calibrated and are still within specs :thumbsup:
    Biscuits, Torspd, Jcyr and 1 other person like this.
  3. Oct 18, 2018 at 7:35 PM
    #8943
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Late to the party, what’s for sale here exactly?
  4. Oct 18, 2018 at 8:51 PM
    #8944
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    1gr hot side.
  5. Oct 18, 2018 at 9:23 PM
    #8945
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    So, I might park the truck. I feel bad for fucking her up on the road.. and she needs some TLC anyhow
    Might snag a 92 Mercedes 300E thats been meticulously kept and drive that while I get some much needed work done on the truck.
    1k with payments aint bad :laugh:
  6. Oct 19, 2018 at 5:30 AM
    #8946
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    not that im turbo or anything but finally installed my wideband last night. car went a wee bit lean at full throttle. 16-17
  7. Oct 19, 2018 at 6:18 AM
    #8947
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Sounds like a recipe for excellent fuel mileage :bananadead:
  8. Oct 19, 2018 at 2:02 PM
    #8948
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Daily beater FTW!
    :eek: Holy smokes man!
    MrCrowntown[QUOTED] likes this.
  9. Oct 19, 2018 at 3:26 PM
    #8949
    dirt addiction
    Flagstaff
    Is anyone running a small turbo and low boost on a 1gr with the stock Ecu with the Trd reflash? Or is the only option a piggyback, haltech, etc?
  10. Oct 19, 2018 at 4:37 PM
    #8950
    05Taco4x4
    2TR-FE Enthusiast
    Didn’t know can just get a TRD flash
  11. Oct 19, 2018 at 5:29 PM
    #8951
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    When Toon had his 1GR turbo kit built, he had no tuning option. I told him, that as long as he kept it around 6 psi, his TRD s/c tune would work. It did, and well.
    05Taco4x4 and dirt addiction like this.
  12. Oct 19, 2018 at 5:48 PM
    #8952
    dirt addiction
    Flagstaff
    What size injectors should I run?
  13. Oct 19, 2018 at 7:59 PM
    #8953
    Sacrifice
    KS
    DCSB OR 4X4 LT
    youre telling me! time to get a tune scheduled. closed loop works well at least until then
  14. Oct 19, 2018 at 8:06 PM
    #8954
    MrCrowntown
    Alyn
    Ky
    What are your fuel trims? Is it intermittent or does it happen the entire time you are at full throttle?
  15. Oct 19, 2018 at 8:09 PM
    #8955
    Sacrifice
    KS
    DCSB OR 4X4 LT
    trims are usually positive for the short term. i think its the entire time. to be fair i put a base tune on it and didnt bother with it after.
    just going to take it easy for the next couple weeks. wouldnt mind learning how to tune, just dont want to mess it up either, ha.
  16. Oct 19, 2018 at 8:15 PM
    #8956
    MrCrowntown
    Alyn
    Ky
    Well, luckily you are going to be adding fuel, so you will always be getting further away from blowing it up as you adjust the map haha
    Might be a good time to learn!
    And anything positive trim means it's compensating for a lean condition. So all the way through the map you could play around too.
  17. Oct 19, 2018 at 8:57 PM
    #8957
    RedLantern
    Honolulu, Hi
    If you could get a hold of someone who could reflash your ecu with TRD tune, then TRD injectors. But I don’t think dealerships do so anymore.
    Torspd likes this.
  18. Oct 19, 2018 at 10:33 PM
    #8958
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I have all the TRD CUW tune files if anyone wants them, you will need a Mongoose Pro 2 Toyota cable and techstream to flash your ecu.
  19. Oct 19, 2018 at 10:49 PM
    #8959
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Correction I have most of the CUW files looks like I have from 2009 to 2014, which ironically means I am missing the file for my truck.
    Hacktacular and Jcyr like this.
  20. Oct 20, 2018 at 3:40 AM
    #8960
    05Taco4x4
    2TR-FE Enthusiast
    Let's talk spark plugs :popcorn:
    I'm reading that gap should decrease as boost increases, <15psi should be .028"-.032"
    I've read good things about Iridium plugs and boost applications, however it's noted that iridium plugs should never be altered.
    I remember you guys talking about colder plugs about a year ago, can't recall the specifics.
    What would you guys recommend for the 2TR and why?
