Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 23, 2018 at 1:57 PM
    #9001
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Exacerbated by tiny problems one after the next. Takes a hell of a lot of fortitude to keep pushing sometimes.
  2. Oct 23, 2018 at 2:00 PM
    #9002
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    yeah sometimes it definitely does. the e36 had a fuel pump issue, brake master cylinder went bad, clogged rear brake line and guibo bushing all within a month or two. followed by integra brake master went out and now fuel pump dying. couldnt even reach pressure regulator setpoint as i just tried.
    Torspd[QUOTED] likes this.
  3. Oct 23, 2018 at 2:07 PM
    #9003
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    First mod on the Bimmer was an upgraded fuel pump. Lol.
    BassAckwards likes this.
  4. Oct 23, 2018 at 3:12 PM
    #9004
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Couple more years and all the parts will arrive
    MrCrowntown, MadTaco461 and buyobuyo like this.
  5. Oct 23, 2018 at 3:19 PM
    #9005
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The denso plugs are listed as well in my owner's manual.
    05Taco4x4[QUOTED] likes this.
  6. Oct 23, 2018 at 3:28 PM
    #9006
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pff. I give you a month. :D
  7. Oct 23, 2018 at 4:18 PM
    #9007
    05Taco4x4
    2TR-FE Enthusiast
    I'm waiting for last order of engine parts, should arrive within 2 weeks.
    I'm still putting the fuel system together, that won't be finished for at least 3-4 weeks.
    Any suggestions for a fuel pump? I have 650cc injectors and will likely run E85 after I return to the mainland- the 2TR hard piping is 5/16" OD
    edit:
    I would like to have an inline pump, something outside of the tank
  8. Oct 23, 2018 at 4:31 PM
    #9008
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Holly, Bosch, Fuelab, Aeromotive....
  9. Oct 23, 2018 at 5:11 PM
    #9009
    Sacrifice
    KS
    DCSB OR 4X4 LT
    we found an Amazon replacement :laugh:
    should be fine for now, itll get a new pump again when its swapped.
    got the pump changed in the integra. finally explains why i always had positive trims, because even with the pump running full time (motor off) it couldnt generate enough pressure to over come the regulator. ended up having to disconnect the supply line to drain the whole tank.
    it now has some 12afrs so a bit rich for n/a (i think 13.2 is the goal?) damn does the car scoooooot now though. i should have done it when i swapped the motor in but i was lazy. 3rd gear wheelspin with full throttle :burnrubber:
  10. Oct 23, 2018 at 8:09 PM
    #9010
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    "They say" 13.5...., but I am more than happy being safe with ~12.5ish.
  11. Oct 24, 2018 at 5:17 AM
    #9011
    Sacrifice
    KS
    DCSB OR 4X4 LT
    great, ill probably just leave it then. since that is figured out i signed up for HPDE in 2 weeks :woot:
  12. Oct 24, 2018 at 5:55 AM
    #9012
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    All the cool kids like it to drop to 10 for a second yaknow cause flames
    MrCrowntown and boostedka like this.
  13. Oct 24, 2018 at 6:41 AM
    #9013
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Envious of you. Haven't done one in a while! :pout:
    This. Watched a fireball shoot out of my friend's 2TR exhaust, one night!
  14. Oct 24, 2018 at 7:01 AM
    #9014
    Jcyr
    Jack
    North east
  15. Oct 24, 2018 at 7:08 AM
    #9015
    Sacrifice
    KS
    DCSB OR 4X4 LT
    itll be my first in a car. went to a couple on my old 600rr.
  16. Oct 24, 2018 at 4:11 PM
    #9016
    05Taco4x4
    2TR-FE Enthusiast
    Haltech "2.29 firmware, due to be released by the end of November, will have Cruise Control via DBW available in Elite 1500 and Elite 2500"
    :bananadance::dancingbacon::broccoli::kona::taco:
    MrCrowntown and Hacktacular like this.
  17. Oct 24, 2018 at 4:12 PM
    #9017
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fawk yeah!
  18. Oct 24, 2018 at 4:12 PM
    #9018
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Aside from that.....:welder:
    Hacktacular and 05Taco4x4 like this.
  19. Oct 24, 2018 at 4:20 PM
    #9019
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    I wouldn't bank on it. It's been coming FOREVER.
    Jcyr likes this.
  20. Oct 24, 2018 at 4:26 PM
    #9020
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just a little something ...
