Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Oct 31, 2018 at 8:30 PM
    #9081
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    i had both sides to a catch can, then vented out to atmosphere
    yota243 likes this.
  2. Oct 31, 2018 at 11:40 PM
    #9082
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I’ve seen them tied into the exhaust ahead of a cat if you still have it. Tied in at a 45* or sharper angle and the exhaust gasses kind of pull the crankcase vent as well.
  3. Oct 31, 2018 at 11:54 PM
    #9083
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    WHAT? That’s a terrible idea.
  4. Nov 1, 2018 at 12:30 AM
    #9084
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    With an Air/Oil Separator, what happens with the vapor/water? It goes into the intake?
  5. Nov 1, 2018 at 1:02 AM
    #9085
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    This actually works well. The exhaust pulls a vacuum when tied in correctly.
    Jcyr likes this.
  6. Nov 1, 2018 at 1:05 AM
    #9086
    05Taco4x4
    2TR-FE Enthusiast
    So post sensors and before cat? Wouldn't the oil accumulate in the cat?
  7. Nov 1, 2018 at 4:24 AM
    #9087
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    It’s still just vapor that is passing though so I believe is just will burn through there. I’m cat less but plan to trybit eventually
  8. Nov 1, 2018 at 6:10 AM
    #9088
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My Bimmer's OEM only.
  9. Nov 1, 2018 at 7:00 AM
    #9089
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    It depends on the setup. Some route to the intake pre-turbo and others vent to atmosphere.
    For the WRX, IAG Performance recommends recirculation for under 600hp running e85 to help pull ethanol vapor from the crankcase, and atmospheric vent for everything else. For over 600hp on e85, they recommend 1500-2000 mile oil changes because of oil dilution due to ethanol vapor buildup in the crankcase.
    Torspd likes this.
  10. Nov 1, 2018 at 7:42 AM
    #9090
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Beat me to it. Knew a guy with a turbo 1GR who had his in this fashion. Worked flawlessly. Simple fluid dynamics at its finest.
    Jcyr likes this.
  11. Nov 1, 2018 at 9:49 AM
    #9091
    05Taco4x4
    2TR-FE Enthusiast
    So the AOS seems same as a catch can but with more baffles to get more oil out the air, with the option to add coolant lines to help sludge from accumulating within the AOS due to water. I still don't understand where the fuel goes, oil or air- I'm thinking oil, so then what's the point of having it.
  12. Nov 1, 2018 at 10:19 AM
    #9092
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Blow-by pressure relief, and gunked up intake tracts caused by the oil vapor.
  13. Nov 1, 2018 at 10:34 AM
    #9093
    05Taco4x4
    2TR-FE Enthusiast
    Obviously, I mean what's the point of have an AOS vice simple catch can if the blow-by fuel will remain in the oil
  14. Nov 1, 2018 at 11:25 AM
    #9094
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    buyobuyo likes this.
  15. Nov 1, 2018 at 2:16 PM
    #9095
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    An AOS is heated by coolant which drives fuel/water vapor off of the oil vapor before returning the oil to the sump. The fuel/water is sucked through the intake and burned or vented to atmo. A catch can just catches everything (oil/water/fuel vapor) and holds it until you dump it.
    Torspd likes this.
  16. Nov 1, 2018 at 4:20 PM
    #9096
    05Taco4x4
    2TR-FE Enthusiast
    OK that's what I was waiting to hear, thanks :thumbsup: I'll likely go with one of these, I don't want to have to keep emptying a can
  17. Nov 1, 2018 at 4:49 PM
    #9097
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I just empty the catch can on my truck when I do my oil change. I'm sure there would be more blow by with a turbo setup, but it shouldn't be exponentially more. I only catch maybe an ounce or two in 5k miles currently.
  18. Nov 1, 2018 at 4:56 PM
    #9098
    Jcyr
    Jack
    North east
    I just leave the little drain screw off on my catch can... a small drop of oil drips on my frame every now and then...
    yota243 likes this.
  19. Nov 1, 2018 at 5:11 PM
    #9099
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I don't have a drain screw/plug. The whole body unscrews from the cap on mine.
  20. Nov 1, 2018 at 6:38 PM
    #9100
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Never will it rust. ;)
    MadTaco461 likes this.
