Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 7, 2018 at 9:29 PM
    #9181
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That it is.
  2. Nov 8, 2018 at 5:35 AM
    #9182
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    hey now...:bananadead: i need to get mine on rollers to see what its got
    depends on how large the injector is and how much the ecu can control it.
    MrCrowntown[QUOTED] likes this.
  3. Nov 8, 2018 at 5:35 AM
    #9183
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    This actually makes real, factual sense, and funny as well. :)
    Coming from a Honda background, not really, I just had a '99 Prelude is all but I was deep into it for sure. It makes perfect sense. The 2TR is iron block, forged guts, with alu head. About 2x the displacement of the popular 1.whatevers in the Honda world that are similar builds.
    Those tuner d-bags love a good ebay turbo kit and push the components to max psi on the reg. Most over 10psi iirc. And without a proper tune or ECU.
    IT CAN BE DONE!
  4. Nov 8, 2018 at 5:37 AM
    #9184
    Sacrifice
    KS
    DCSB OR 4X4 LT
    B series -1.8L
    H - 2.2L
    K - 2.0 or 2.4L (latter being more common now)
    J - 3.2 or 3.5L
  5. Nov 8, 2018 at 5:38 AM
    #9185
    dirty deeds
    Nick
    Eastern KY
    Looks like I'm gonna build a NA all motor 2tr. ftmfwaf
    MrCrowntown likes this.
  6. Nov 8, 2018 at 5:38 AM
    #9186
    dirty deeds
    Nick
    Eastern KY
    H series, at least mine, was alu block and head. #1 reason it ate the ever living piss outta quarts of oil, without a better gasket kit.
  7. Nov 8, 2018 at 5:49 AM
    #9187
    Sacrifice
    KS
    DCSB OR 4X4 LT
    valve seal guides and higher crankcase pressure when in vtec are the #1 cause.
    i just spent all weekend at the roadcourse with my K series and hardly burned any.
    Torspd likes this.
  8. Nov 8, 2018 at 5:53 AM
    #9188
    dirty deeds
    Nick
    Eastern KY
    It was like a Bond car when I got into vtec range.
    Smoke screen, ENGAGE!
  9. Nov 8, 2018 at 5:55 AM
    #9189
    dirty deeds
    Nick
    Eastern KY
    I'm just comparing they way the Honda motors get built in terms of similarity to the 2tr. If they can run 10psi straight out the box ebay junk with no tuning or ECU, then we should be able to pull something like that off. With more displacement = more power (in theory)
  10. Nov 8, 2018 at 7:37 AM
    #9190
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Have you guys seen this dude pegging his 2tr all the way up.
  11. Nov 8, 2018 at 7:48 AM
    #9191
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I mean why have a rev limiter if u ain't gonna use it amirite?
  12. Nov 8, 2018 at 8:37 AM
    #9192
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I like this.
    I want to do the same with the motor that gets pulled from my truck for the turbo block! Put it in a sand car or a retired class 10 lol
    dirty deeds[QUOTED] likes this.
  13. Nov 8, 2018 at 8:55 AM
    #9193
    dirty deeds
    Nick
    Eastern KY
    I'm just going for longevity with hp/tq as secondary gains
  14. Nov 8, 2018 at 9:15 AM
    #9194
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I've never worked with a 2TR but I know on my 3rz, the Megasquirt3 standalone made a big difference in non boost/vac areas. The timing map tuning is where you can really can more power and responsiveness in NA.
  15. Nov 8, 2018 at 9:24 AM
    #9195
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any specs on that engine? I'd definitely like to read what was done.
  16. Nov 8, 2018 at 9:27 AM
    #9196
    5 Lug Fury
    Kenny
    Knoxville, TN
    Unfortunately no someone posted the video a long time ago and recently I spent a while trying to find it to show a friend.
  17. Nov 8, 2018 at 9:41 AM
    #9197
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Haltech in my truck now, NA for a few more weeks, really has made a difference. I'm afraid if I'd of got a proper tune I would never have bit on the turbo.
    MrCrowntown and MadTaco461 like this.
  18. Nov 8, 2018 at 9:45 AM
    #9198
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The turbo amplifies that fun factory. You'd have come around. We'd have influenced you in the right direction. :boink:
    Hacktacular and 05Taco4x4 like this.
  19. Nov 8, 2018 at 9:52 AM
    #9199
    Sacrifice
    KS
    DCSB OR 4X4 LT
    anyone looking for 10an line or possibly some 90° fittings?
  20. Nov 8, 2018 at 11:45 AM
    #9200
    dirty deeds
    Nick
    Eastern KY
    Do we know that that Suzuki is 2tr swapped?
