Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 8, 2018 at 11:50 AM
    #9201
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Yeah in this or another of the same video someone commented that it was a 2tr with land cruiser axles
  2. Nov 8, 2018 at 11:58 AM
    #9202
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  3. Nov 8, 2018 at 12:01 PM
    #9203
    MadTaco461
    CA
    Kinda stock
  4. Nov 8, 2018 at 8:54 PM
    #9204
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    God I love the sound of that engine lol
    :pout:
    dirty deeds and MadTaco461 like this.
  5. Nov 8, 2018 at 10:40 PM
    #9205
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I'm attempting to set-up Cruise on the Haltech.
    With the vehicle off, I measure resistance across the stalk, when activating the option, as:
    At Rest:795 ohm
    Main (enable/disable): 1.5 ohm
    + Res: 186.7 ohm
    - Set: 356.6 ohm
    CANCEL: 535.2 ohm
    With the key in the Run position:
    At Rest: OPEN
    Main: 25.9 ohm
    + Res: 17.6 ohm
    - Set: OPEN
    CANCEL: OPEN
    I figured something is opening the circuit (within the stalk?) to deny activating cruise. I thought maybe it is the ecu's way of disabling cruise under the minimum speed limit, so I measured resistance doing 35mph- STILL OPEN :(
    Haltech thought it was best to configure cruise with Voltage input, vice resistance. Issue above doesn't allow ESP to 'Calibrate' the voltage for the three open circuits.
    I'm stumped and very frustrated, I've spent 2 days trying to figure this out. Any ideas?
  6. Nov 8, 2018 at 10:48 PM
    #9206
    05Taco4x4
    2TR-FE Enthusiast
    And the idea of something within the stalk opening the circuit doesn't hold water because there's only 2 wires :pout:
  7. Nov 8, 2018 at 10:50 PM
    #9207
    MrCrowntown
    Alyn
    Ky
    Maybe get ahold of a ford falcon cruise control diagram and compare and modify. Might have to bypass the ECU entirely
    Torspd likes this.
  8. Nov 8, 2018 at 11:43 PM
    #9208
    05Taco4x4
    2TR-FE Enthusiast
    Something is going on with the Tacoma, outside of the diagram. There's only a few unassigned pins remaining and none output voltage.
  9. Nov 9, 2018 at 9:36 AM
    #9209
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    In case anyone is interested...
  10. Nov 9, 2018 at 11:07 AM
    #9210
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Nearly there.....
  11. Nov 9, 2018 at 11:08 AM
    #9211
    05Taco4x4
    2TR-FE Enthusiast
    OK, so ground is denied after entering the junction- so I removed the pin and ground directly... everything is gtg :thumbsup:
    MrCrowntown[QUOTED] and Torspd like this.
  12. Nov 9, 2018 at 11:16 AM
    #9212
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    BAM! Thanks for all of the leg work. Now to tinker, you genius! :D
  13. Nov 9, 2018 at 11:56 AM
    #9213
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Hacktacular
    Hacktacular likes this.
  14. Nov 9, 2018 at 12:07 PM
    #9214
    boostedka
    James
    NM
    Pretty crazy looking in through the flange seeing all the cuts! Nice work
  15. Nov 9, 2018 at 12:24 PM
    #9215
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Well, there goes Christmas funds for the kids! Sorry kids, not really :D
    Assume I'll need to contact them to see what works on the 2TR?
    boostedka[QUOTED] likes this.
  16. Nov 9, 2018 at 12:30 PM
    #9216
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If I were doing this for prototyping, to then be mass-produced, the pie cuts made for a super simple and rapid routing. Within translate into having angles necessary 4 mass production and improved efficiency in time, because of less time being spent on welds. I was able to throw the first few bins together and maybe an hour.
  17. Nov 9, 2018 at 12:39 PM
    #9217
    boostedka
    James
    NM
    LOL..
    You can basically make a Megasquirt work on anything you want. It's just having the wiring diagrams for your vehicle and figuring out some of the ins and out and whathaveyou's of making it function for your application.
  18. Nov 9, 2018 at 12:44 PM
    #9218
    dirty deeds
    Nick
    Eastern KY
    And this is why I'm here, on TW. I don't know shit lol
    Maybe I'll go the DIY route then. I like to solder.
  19. Nov 9, 2018 at 1:03 PM
    #9219
    boostedka
    James
    NM
    It looks intimidating at first because there are so many wires in order to work for multiple applications. Once you figure out what you need, you see that it's only around 15 or so wires that you use. Here's a list of what I wired into mine for an example (copy and pasted from my build page):
    Megasquirt = Tacoma wire naming system
    **Red-12V+ = B+ E5 Pin 12 White/Red
    Light Blue-TPS = VTA E7 Pin 10 Yellow
    Gray-VREF = VC E7 Pin 1 Green/Yellow
    **Black-VR- = NE- E6 Pin 6 Green (VR+, VR-, are in a shielded cable)
    **White-VR+= NE E6 Pin 12 Red
    Shielded ground = not connected
    Coolant temp = THW E7 Pin 4 Green/Red
    Air Temp = THA E7 Pin 3 Yellow/Green
    **Runs to both MS and Stock ECU
    MS3X Harness = Tacoma wire naming system
    Injector A = #10 E8 Pin 12 White/Red
    Injector B = #20 E8 Pin 11 White
    Injector C = #30 E8 Pin 10 Red
    Injector D = #40 E8 Pin 9 Red/Blue
    Pin 9 Idle valve = RSO E8 Pin 7 Black/Red
    Pin 27 VVT = RSC E8 Pin 6 Black
    Spark A = IGT1 Cyl 1&4 E8 pin 23 Black/Blue
    Spark B = IGT2 Cyl 2&3 E8 Pin 22 Brown/Yellow
    After that, it's figuring out what your setting need to be (fuel, ignition, idle, etc.). Without proper settings, the wiring means nothing and vise versa. I learned that with my idle issues that were fixed by just changing a couple of my settings.
  20. Nov 9, 2018 at 3:31 PM
    #9220
    05Taco4x4
    2TR-FE Enthusiast
    Not so fast. The stock ECU sends 10v, max input is 5v :annoyed: Gotta add a resistor to get those numbers below 5v.
