Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 7, 2018 at 11:25 AM
    #9401
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Yup you want size you’re spring based on the vacuum at the throttle body at idle
    Torspd likes this.
  2. Dec 7, 2018 at 12:52 PM
    #9402
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Ok, thanks again guys
    Jcyr[QUOTED] likes this.
  3. Dec 8, 2018 at 8:03 AM
    #9403
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Is that an EBC solenoid I spy? :spy:
  4. Dec 8, 2018 at 8:07 AM
    #9404
    Hacktacular
    Robert
    :bowdown:
    05Taco4x4[QUOTED] likes this.
  5. Dec 8, 2018 at 11:17 AM
    #9405
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    So far it looks like the plugs were my issue. Swapped them for some new IKH22's and gapped them down to .32 from the stock .44 which should help. Also got around to installing my MAF extension harness to finally cleanup the annoying MAF wires. I'll post pics of the plugs, but looking at the old plugs, my 2nd cylinders ground strap was worn pretty hard.. For only having 10k on those plugs, I was kinda surprised.. But I also left those at stock gap so who knows. But it finally isn't breaking up, or at least didn't on my short test drive... So problem solved for now lol.
    RedLantern, MadTaco461, Jcyr and 2 others like this.
  6. Dec 8, 2018 at 3:03 PM
    #9406
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That it is. Had it with the Pro EFI. To be adapted over.
    What I really miss however, was the GReddy Profec B2 boost controller.
    Jcyr likes this.
  7. Dec 8, 2018 at 3:04 PM
    #9407
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good deal and glad it was a simple solution.
    dirtdigginjoe[QUOTED] likes this.
  8. Dec 8, 2018 at 3:54 PM
    #9408
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I used to have a a Profec on my turbo 240sx back in the day. That unit was awesome. Two knobs, one for high and one for low boost and a button to switch between the two. So simple yet so effective!
    Jcyr likes this.
  9. Dec 8, 2018 at 5:29 PM
    #9409
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes it was! As well as setting the "start boost" function. Kind of sad that I no longer have mine. Haltech can take care of it all though.
    boostedka[QUOTED] likes this.
  10. Dec 8, 2018 at 11:10 PM
    #9410
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
  11. Dec 9, 2018 at 11:14 AM
    #9411
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. Dec 9, 2018 at 6:31 PM
    #9412
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    5 Lug Fury, boostedka and Jcyr like this.
  13. Dec 9, 2018 at 8:02 PM
    #9413
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    You happen to have a copy for the 2008 FSM? I usually use the 05 FSM on Custom Tacos, but it's not always easy to find what you want with how it's arranged.
  14. Dec 9, 2018 at 9:07 PM
    #9414
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I do not have a copy of the 2008 I usually use the 05 also.
  15. Dec 9, 2018 at 9:24 PM
    #9415
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I do have the updated Electrical, which I think is the only thing that is different. I will post it soon
  16. Dec 9, 2018 at 11:00 PM
    #9416
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
  17. Dec 10, 2018 at 4:13 AM
    #9417
    Jcyr
    Jack
    North east
    @arcenik do you have any 2001-04 formated like that!?
  18. Dec 10, 2018 at 6:26 AM
    #9418
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @mnovak
  19. Dec 10, 2018 at 7:27 AM
    #9419
    boostedka
    James
    NM
    Thanks for posting that. I just downloaded it now.
    I recently sold my 1st gen, bought a 2nd gen.
    2006 4.0L TRD 4WD with 159,000mi
    5 Lug Fury, Jcyr and MadTaco461 like this.
  20. Dec 10, 2018 at 9:05 AM
    #9420
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Thank you guys for sharing the wiring diagrams. I was able to fix my wiring and get the truck on boost. Unfortunately I may have run over my bov and now have a boost leak lol. God I hate c clips :bananadead:
    Also is there a way to test my cats to see if they're going bad? I have a feeling the interfering when I'm on boost
