Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 10, 2018 at 9:22 AM
    #9421
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I'm going to recirculate a BOV, what should be some guidelines when deciding on which one? Does anyone have any experience with a Turbosmart Kompact Plumb Back?
  2. Dec 10, 2018 at 9:37 AM
    #9422
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Since you're not using the MAF sensor, you have the options of before or after the MAF.
  3. Dec 10, 2018 at 9:41 AM
    #9423
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Yes. Cut out. Weld straight pipe in.
    Throw away cats.
  4. Dec 10, 2018 at 9:43 AM
    #9424
    05Taco4x4
    2TR-FE Enthusiast
    ? what lol
    How can be before or after if not using it lol
  5. Dec 10, 2018 at 9:45 AM
    #9425
    05Taco4x4
    2TR-FE Enthusiast
    I'm going to put it almost immediately after turbo so is a short distance to return to turbo intake, any problems with this? I'll just have a longer vacuum line to post TB
    edit:
    or is it a rule-of-thumb to put it close to TB?
  6. Dec 10, 2018 at 9:50 AM
    #9426
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am assuming that you have completely removed your sensor. I still have mine in for modularity's sake. However, like you, I use the MAP sensor instead. Thus using the MAP it could be before or after the MAF.
  7. Dec 10, 2018 at 9:52 AM
    #9427
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The closer to the compressor outlet, the more efficient. That is how manufacturers can get away with integrated BOV's.
    With your plan, you'll reduce a lot of additional routing.
    05Taco4x4[QUOTED] likes this.
  8. Dec 10, 2018 at 9:57 AM
    #9428
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My BOV is integrated, on my EFR. No signs of compressor surge, @ 6 psi. As I increase the boost, I'll keep and ear on it. Possibly throw an external one on later.
  9. Dec 10, 2018 at 9:57 AM
    #9429
    05Taco4x4
    2TR-FE Enthusiast
    Yeah, it's currently in place for air intake temp but after the swap it'll be completely gone.
    That's good news, thanks
    So no word on the Turbosmart Kompact Plumb Back or any other BOV for this purpose?
  10. Dec 10, 2018 at 9:59 AM
    #9430
    05Taco4x4
    2TR-FE Enthusiast
    That's nice
  11. Dec 10, 2018 at 10:02 AM
    #9431
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I've seen plenty used, but no personal experience.
    Also look into GFB.
  12. Dec 10, 2018 at 10:10 AM
    #9432
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    How different do you think the internals are from a fake hks and a real one. My real one has a section missing from the bottom part that interfaces with the flange. Do you think it would be possible to strip a fake one and just use the housing?
  13. Dec 10, 2018 at 10:36 AM
    #9433
    05Taco4x4
    2TR-FE Enthusiast
    GFB T9301 looks identical to Turbosmart TS-0203-1222 but more expensive, think I'll just go with the Turbosmart. Thanks for the word
  14. Dec 10, 2018 at 10:46 AM
    #9434
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Welcome.
    05Taco4x4 likes this.
  15. Dec 10, 2018 at 12:06 PM
    #9435
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Turbosmart is good. I had one for a bit. Likes to be lubed it with white lithium grease every 5 to 10k miles.
  16. Dec 10, 2018 at 12:15 PM
    #9436
    05Taco4x4
    2TR-FE Enthusiast
    So remove the cap and grease the bore where the silicone wiper slides?
  17. Dec 10, 2018 at 12:27 PM
    #9437
    MadTaco461
    CA
    Kinda stock
    Yeah the moving internals. This was back in 2012. Not sure if it changed, but mine would get sticky after a while and get slow. Easy fix.
  18. Dec 10, 2018 at 12:31 PM
    #9438
    05Taco4x4
    2TR-FE Enthusiast
    Ok, thanks. I'll hold off and if have a problem I'll grease it :thumbsup:
    MadTaco461[QUOTED] likes this.
  19. Dec 10, 2018 at 2:27 PM
    #9439
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    2008 or 2009 was the last year of the mechanical LSD, so I think ATRACS came out in 2009 or 2010 which would be an electrical change. Also, I believe side curtain airbags because standard in 2009 or 2010.
    The BOV in my WRX recircs from right after the turbo back to the turbo inlet.
    The Boomba Racing BPV is popular on the WRX. It would be easy enough to make it work on a custom setup. You'd just need a couple silicone couplers and attachment points on your plumbing.
  20. Dec 10, 2018 at 4:25 PM
    #9440
    05Taco4x4
    2TR-FE Enthusiast
    Any reason you know as to why? It looks stout but it's quite a bit more expensive than the Turbosmart.
