Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 16, 2018 at 4:01 PM
    #9461
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    By any chance, @MrCrowntown do you know the flow rate for the OEM injectors for us?
    I'm pretty sure I've got a bum injector since the misfire is still present, and feeling like an injector. (Missing at idle, and misses hard when leaving idle, but drives mostly fine- even in boost. Seems to happen especially if I sit at a light or stop for a min or two)
    I see Five0Motorsport has some OEM and upgraded ones, but I wanna know how much larger the 450cc's would be over stock, and if I'd throw a CEL from trying to pull too much fuel.
    I messaged them just now to see if they knew the flow rate, but even Google searches came up with nothing.
  2. Dec 16, 2018 at 4:12 PM
    #9462
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    This was discussed a few months ago. I'm pretty sure it was in this thread, but I can't find the post. I want to say that they're 300-some odd cc.
  3. Dec 16, 2018 at 4:32 PM
    #9463
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    According to the 05 FSM (https://www.customtacos.com/tech.ol.../06toyrm/06toypdf/06rmsrc/rm2006ta/010001.pdf, scroll down to page 5), the injectors are good if they flow 284-344 cc/min. If you assume the rated flow is the median of those values, the injectors would be 314 cc/min.
    Torspd likes this.
  4. Dec 16, 2018 at 4:35 PM
    #9464
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Thank you sir! I was just looking through the manual I had saved previously, you just beat me to it!
    Five0 makes some 380's that are enticing, especially since they make PNP adapters for the different pigtail types...hmmm
  5. Dec 16, 2018 at 6:10 PM
    #9465
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Yeah I know. :anonymous:
    I bought an 4.0L send gen. I’ve been looking at some performance stuff for the 1GR. Those roost factor y-pipes look pretty sic
    BassAckwards, Jcyr and yota243 like this.
  6. Dec 16, 2018 at 6:11 PM
    #9466
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  7. Dec 16, 2018 at 6:13 PM
    #9467
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. Yes!!!
    BassAckwards likes this.
  8. Dec 16, 2018 at 6:17 PM
    #9468
    yota243
    E.J.
    north Alabama
    U in the market for a place in north Alabama?
  9. Dec 16, 2018 at 9:33 PM
    #9469
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
    yota243 likes this.
  10. Dec 16, 2018 at 11:25 PM
    #9470
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I trimmed out 550cc with a piggyback. It’s about 2x my stock injector flow.
    boostedka likes this.
  11. Dec 17, 2018 at 10:48 AM
    #9471
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Sold my hotside, going to a new owner in WY. Pretty awesome cause he owns a urd Sc tacoma with a built block. Says he’ll be using it on an xrunner. He’s not on the forum but told him to make an account.
    05Taco4x4 and BassAckwards like this.
  12. Dec 17, 2018 at 11:03 AM
    #9472
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is terrific! Congrats on the sell. Quite curious to see his build.
  13. Dec 18, 2018 at 10:10 AM
    #9473
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Is it possible to use the narrowband from a plx wideband to replace the stock o2 on a 2tr?
  14. Dec 18, 2018 at 10:14 AM
    #9474
    boostedka
    James
    NM
    I did this on my 3RZ. It was a '98 though before they changed the OEM sensors on these trucks.
    Anyhow, I just used the supplied grey wire and ran it from the PLX AFR Module to the stock ecu. You just de-pin the O2 sensor wire at the ecu plug and re-pin it with the grey wire that is running from the AFR module. Mine started right up. Like I said though, I'm not familiar with the type of sensor the 2tr uses and the ecu pin-out for that specific application.
  15. Dec 18, 2018 at 10:18 AM
    #9475
    5 Lug Fury
    Kenny
    Knoxville, TN
    So it would be the white wire ox1b?
  16. Dec 18, 2018 at 10:20 AM
    #9476
    boostedka
    James
    NM
    That would be my guess. On my truck is was a white wire as well. It was labeled OX1 on the ecu pin-out I used.
  17. Dec 18, 2018 at 11:31 AM
    #9477
    MadTaco461
    CA
    Kinda stock
    That's your downstream sensor that monitors your cat. FYI. Might still get a cel if you bypass it.
  18. Dec 18, 2018 at 11:34 AM
    #9478
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Maybe I'm just missing somethin here, but why would you want to use a PLX wideband as sensor 2? Is it because you have a bad stock one and have this one laying around? Or for more monitoring purposes?
    I'd just as soon get the URD rear O2 sim. But then again my small mind probably isn't understanding your purpose
  19. Dec 18, 2018 at 11:43 AM
    #9479
    boostedka
    James
    NM
    WHen I did it, I used it for my pre-cat sensor. This way I didn't have to mount a 2nd sensor
    5 Lug Fury likes this.
  20. Dec 18, 2018 at 1:05 PM
    #9480
    5 Lug Fury
    Kenny
    Knoxville, TN
    Thats my goal
    Jcyr likes this.
