Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jan 3, 2019 at 8:17 AM
    #9621
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Do i want a Detroit locker or the trutrac? Hmmm
    BassAckwards likes this.
  2. Jan 3, 2019 at 8:22 AM
    #9622
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    TruTrac, unless you need the locker for a lot of Off Roading.
  3. Jan 3, 2019 at 8:26 AM
    #9623
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    From what I read, it depends on how you’re your going to off-road. If your getting one rear wheel off the ground a lot, you need to use the brake at the same time in order to get the wheel on the ground to spin with the Truetrac. The locker obviously means their locked and both spin all the time regardless.
    What I like about the Truetrac is it just works pretty much all the time. You don’t have have to engage it or flip any switches. Just go
  4. Jan 3, 2019 at 9:14 AM
    #9624
    Jcyr
    Jack
    North east
    Will a trutrac spin both tires off the line? I really hate the 1 wheel burnout
  5. Jan 3, 2019 at 9:21 AM
    #9625
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The Trutrac will have better road manners when going around turns, but the Detroit should unlock for turns. I was considering the Detroit when I ordered my 3rd member from ECGS. For street driven trucks, they suggested the Trutrac or a selectable locker over the Detroit. I didn't want to deal with 1-wheel peels when I get around to adding FI, so I went with the Trutrac. @EatSleepTacos has a PowerTrac (if I remember right) which is similar to a Detroit, so he could give his perspective.
    The Detroit locker should be an auto locker. Unless he's looking at their e-locker, but it isn't referred to as a Detroit so probably not.
    It should.
    EatSleepTacos likes this.
  6. Jan 3, 2019 at 9:35 AM
    #9626
    boostedka
    James
    NM
    Thanks for clarifying. I was thinking selectable for some reason.
    buyobuyo[QUOTED] likes this.
  7. Jan 3, 2019 at 9:38 AM
    #9627
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have a mechanical locker and I love it. Easily the best bang for your buck, and I love how simple it is. No need to run any air lines/wires so just less points of failure. Never need to think about hitting a switch either to lock it up.
    It took getting used to on road, but now I hardly even know it’s there since I’ve adjusted my driving style. Would definitely recommend.
  8. Jan 3, 2019 at 9:40 AM
    #9628
    Jcyr
    Jack
    North east
    What did you have to adjust with your driving style
  9. Jan 3, 2019 at 9:43 AM
    #9629
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The locker locks when under moderate throttle, so now I have to use a light, consistent throttle through turns. For a right turn, I don’t accelerate quickly through the turn, or it’ll lock and I’ll chirp tires. Or the locker will unlock with a loud bang (which is a normal characteristic of mechanical lockers, they’re noisy).
    You have to gradually accelerate through the right turn, and once you’re straight you can hammer it as hard as you want.
    Sounds kinda annoying but you get used to it real quick. I drive like a grandpa anyways so it was a quick adjustment period.
    Here’s my thread on locker install for anyone interested.
    https://www.tacomaworld.com/threads...lip-aka-lunchbox-locker-in-my-2nd-gen.561142/
    Torspd and buyobuyo like this.
  10. Jan 3, 2019 at 9:53 AM
    #9630
    boostedka
    James
    NM
    @Jcyr You probably won’t be driving like a grandpa with that turbo setup. Lol. Especially with those new injectors working nicely
    Jcyr likes this.
  11. Jan 3, 2019 at 10:00 AM
    #9631
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes
  12. Jan 3, 2019 at 11:28 AM
    #9632
    boostedka
    James
    NM
    Jack, check out this video if you haven't already. Go to about 6:30 for in info on the Trutrac and ~22min for the Detroit Locker
    Jcyr, MrCrowntown and Brake Weight like this.
  13. Jan 3, 2019 at 3:52 PM
    #9633
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    I prefer removing the bed. Makes life a lot easier, even for something like changing out brake lines.
    I use an engine hoist with ratchet straps and drive out from under the bed. I just put moving blankets between cab and bed.
    https://youtu.be/9N2UKtoDBf4
  14. Jan 3, 2019 at 9:25 PM
    #9634
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I have the Truetrac in the rear, I like it a lot. It's loads better off-road than when I had an open diff. Concurrently with my engine install I'm doing the front- I originally bought an Aussie locker for the front (I have manual hubs) BUT then a member successfully put a limited slip in the front and I'm torn about which to install. I don't know much I'll be able to use the limited slip up front with my FJ t-case but I do know the Aussie locker will be hella useful up front off-road with the limited slip in the back. I'm considering the AWD 4Runner case and limited slip up front so I can have an AWD turbo Taco. I'm torn between off-road or turbo road use.
  15. Jan 4, 2019 at 7:20 AM
    #9635
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you have a link to the guy with the limited slip up front?
  16. Jan 4, 2019 at 7:25 AM
    #9636
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
  17. Jan 4, 2019 at 8:17 AM
    #9637
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  18. Jan 5, 2019 at 11:10 AM
    #9638
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I think it’s confirmed.
    Looks like he’s scrapping the twin turbo idea.
    MrCrowntown likes this.
  19. Jan 5, 2019 at 11:11 AM
    #9639
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just like on the 2nd Gen , very limited space on the driver side. Unless a LOT of things are relocated.
  20. Jan 5, 2019 at 1:44 PM
    #9640
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    EFR 7670? I like their style :cool:
    MadTaco461 likes this.
