Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 2, 2019 at 2:15 PM
    #9901
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Found this on ebay. Going to give it try. Carbon Fiber adds hp right? :rofl:
    20190130_154509 by Ryan Heintzelman - Flickr2BBcode
    boostedka likes this.
  2. Feb 2, 2019 at 9:59 PM
    #9902
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I'm using a Spectre air box
    5 Lug Fury likes this.
  3. Feb 2, 2019 at 10:04 PM
    #9903
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
  4. Feb 6, 2019 at 2:41 PM
    #9904
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Im wondering if emissions will be worse or better with the turbo connected. Last time I ran with it disconnected and some denatured and passed. I was just thinking though wouldnt it be more efficient with the turbo hooked up. Whats your thoughts? Unhook it or keep the charge pipe hooked up for better emission?
  5. Feb 7, 2019 at 7:18 PM
    #9905
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
  6. Feb 7, 2019 at 7:39 PM
    #9906
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  7. Feb 7, 2019 at 9:17 PM
    #9907
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  8. Feb 7, 2019 at 11:25 PM
    #9908
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
  9. Feb 8, 2019 at 12:54 AM
    #9909
    RedLantern
    Honolulu, Hi
    Apparently this was the same guy that had UPP Turbo build his turbo kit when it was still 1gr. I posted his dyno awhile back ...509hp/552tq On 10psi. I’m guesing his Motor must have blown lol
    https://youtu.be/w_w43mtkYdQ
  10. Feb 8, 2019 at 4:33 AM
    #9910
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Were it a stock 1GR, yup. That's ~100 more HP and ~100 more TQ, on 2 more psi, than mine, Toon's, and two other people's. Means they addes a decent amount of timing, and the 1GR only likes so much in stock form.
  11. Feb 8, 2019 at 4:38 AM
    #9911
    yota243
    E.J.
    north Alabama
    I was gonna ask how much it was advanced since that is more tq and go than you had with 50% more boost :boom:
  12. Feb 8, 2019 at 5:54 AM
    #9912
    RedLantern
    Honolulu, Hi
    Time bomb. Thanks correction made
    Torspd[QUOTED] likes this.
  13. Feb 8, 2019 at 6:07 AM
    #9913
    OVTune
    OVTune Well-Known Member
    OVTune
    Likely it's corrected numbers. UPP is in Colorado, so they usually have a 1.20 - 1.25+ Correction factor. I've tuned some cars at this shop before.
    MrCrowntown likes this.
  14. Feb 8, 2019 at 9:44 AM
    #9914
    05Taco4x4
    2TR-FE Enthusiast
    Would you mind helping us out with the 1GR/2TR ignition coil dwell times
  15. Feb 8, 2019 at 9:48 AM
    #9915
    OVTune
    OVTune
    Sure, how can I help.
    I know where the coil dwell table is in the stock ECU yes
  16. Feb 8, 2019 at 10:08 AM
    #9916
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Didn't think about that. Could very well be the case. The kits that I referenced, were all sea level.
  17. Feb 8, 2019 at 11:03 AM
    #9917
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    How much can a sleeved 1GR block handle?
  18. Feb 8, 2019 at 12:49 PM
    #9918
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So far as I have seen, at least over 700whp and 700wtq. For the stock block above, the ring lands or rods will be the first to let go. Inherently weak, due to thin construction.
    BassAckwards and RedLantern like this.
  19. Feb 8, 2019 at 1:00 PM
    #9919
    RedLantern
    Honolulu, Hi
    I know the guys in UAE go for broke with the 1gr. Those uphill sand drags are no joke
  20. Feb 9, 2019 at 1:46 PM
    #9920
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Hey guys carb approved turbo kit, lol.:rofl:
