Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 20, 2017 at 5:47 PM
    #81
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    It's only as wide as the frame if I remember correctly, height I believe if you can miss the skid your goid
    #81
  2. Mar 20, 2017 at 5:48 PM
    #82
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Effing sic!
    GreeGunc[QUOTED] likes this.
  3. Mar 20, 2017 at 5:50 PM
    #83
    GreeGunc
    Jacob
    North GA
    Haha, thank you sir. All you do is go off a manual for parts but hoses and lines you do off memory....
  4. Mar 20, 2017 at 5:55 PM
    #84
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Depends on the setup. You'll definitely need to upgrade the pump to make sure it can keep up with the demand. Some now run 2 or 3 pumps if they go with e85. Advancing timing gradually is key to make sure your not knocking or anything unwanted.
    boostedka[QUOTED] likes this.
  5. Mar 20, 2017 at 6:06 PM
    #85
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    actually they do, even have a base map. But it is only for 95-97s
  6. Mar 20, 2017 at 6:12 PM
    #86
    GreeGunc
    Jacob
    North GA
    Haha, I'll get with my dad and see where he thinks he knows of good hose
    MadTaco461[QUOTED] likes this.
  7. Mar 20, 2017 at 6:13 PM
    #87
    Lucario Runner
    Robert
    06 Toyota 4Runner
    yeah I think his was a 03? Although hey are open to custom work.
  8. Mar 20, 2017 at 6:27 PM
    #88
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea really just need a different connector and PCB layout i bet.
  9. Mar 20, 2017 at 6:46 PM
    #89
    boostedka
    James
    NM
    Torspd likes this.
  10. Mar 20, 2017 at 8:10 PM
    #90
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Google Earl's Performance. They have all of the stuff to make your own hose. All sorts of different style of fittings, with tight tolerances. Multi layer hose, to braided steel w/PTFE inner. Temp and fluid ratings. Definitely worth the money. They are a division of Holley.
    Aeroquip - division of Eaton.
    Aeromotive - not sure, but have smooth radiused transition of in their reducer fittings. Rather than step. Very high quality.
  11. Mar 20, 2017 at 8:26 PM
    #91
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Radium also makes good shiz....
  12. Mar 20, 2017 at 8:27 PM
    #92
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. Mar 20, 2017 at 8:32 PM
    #93
    Lucario Runner
    Robert
    06 Toyota 4Runner
    can confirm, is good shiz.
  14. Mar 21, 2017 at 2:58 AM
    #94
    GreeGunc
    Jacob
    North GA
    Thank you fellas, I'll probably keep the eBay hoses till I atleast get it all put on and running right
    #94
  15. Mar 21, 2017 at 7:00 AM
    #95
    GreeGunc
    Jacob
    North GA
    So, now im thinking about clutches. Im sure an orielly special will not hold up to much psi.
    Ive narrowed it down to
    Competition stage 3 from urd 375whp
    Lce dual comp clutch kit 385hp
    Centerforce dual friction ?hp
    Centerforce II ?hp
    Open to more suggestions if you have any
  16. Mar 21, 2017 at 7:20 AM
    #96
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Competition Clutch has a long negative history on the Tacoma. I recommend against that one brand for this application.
    Add to the list:
    Excedy, ACT, Spec Clutch.
    DOUBLLD and boostedka like this.
  17. Mar 21, 2017 at 7:23 AM
    #97
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    LCE. Toyota Specialist, with proven HIGH hp engines....
    j0shu4, MrCrowntown and boostedka like this.
  18. Mar 21, 2017 at 7:53 AM
    #98
    boostedka
    James
    NM
    I had good luck with an ACT on a previous non Tacoma Vehicle. I couldn't find one with a street disc for the 3rz though when looking last year. I even tried to get an ACT pressure plate for a 5vz but it has been discontinued. I thought about getting an LCE set up but I really don't plan on going over 300hp. I wound up using a Stock 3rz disc, TO bearing, and Pilot Bearing along with a stock pressure plate for the 5vz. It's been holding well so far. We'll see what happens when i makes a little more power.
  19. Mar 21, 2017 at 8:31 AM
    #99
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I plan to go LC when I upgrade due to their reputation and low cost.
    Torspd likes this.
  20. Mar 21, 2017 at 9:54 AM
    #100
    GreeGunc
    Jacob
    North GA
    Not really low cost, treadstone is cheaper. I think even urd may be cheaper....
