Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 27, 2019 at 11:27 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I haven't been able to find this function. Maybe not available on the 1st gen :notsure:
  2. Feb 27, 2019 at 11:32 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Add display and select fuel status. It work on both my 04 Tacoma and 97 T100.
    vasinvictor likes this.
  3. Feb 27, 2019 at 11:49 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks! I'll look into it!
    Reh5108[QUOTED] likes this.
  4. Feb 27, 2019 at 2:21 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  5. Feb 27, 2019 at 2:36 PM
    Reh5108
    Idaho
    PM inbound
  6. Feb 27, 2019 at 4:53 PM
    05Taco4x4
    2TR-FE Enthusiast
    Replied
  7. Feb 28, 2019 at 7:43 PM
    Reh5108
    Idaho
    Still having an issue with oil seeping out of the center housing. I half assed a guage to the center breather and it didn't read any positive pressure. I'm starting to lean towards the turbo having a bad seal.
    If anyone sees anything I might be missing let me know.
    20190228_202832 by Ryan Heintzelman - Flickr2BBcode
    MrCrowntown likes this.
  8. Feb 28, 2019 at 7:55 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    If the turbo had been over pressurized then you may have compromised the seals already. Rebuild and retry!
    Reh5108 likes this.
  9. Feb 28, 2019 at 8:32 PM
    Reh5108
    Idaho
    @MadTaco461 when you were having O2 issues are you talking about the actual O2 post cat or the factory afr? I got a p0420 pending code while letting it idle. O2 was reading zero so it makes sense. Rev it up and it starts reading again.
    Before the turbo install I'd often get the 420 code when coasting downhills for long periods or offroad around idle. Never paid attention to the sensor as I had no idea how anything worked at that time.
  10. Feb 28, 2019 at 8:33 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Where is your PCV hooked up? Stock location? If so, you might not be getting proper vacuum to keep crank pressure negative. Mine leaks oil too and most of my research says PCV
  11. Feb 28, 2019 at 8:36 PM
    Reh5108
    Idaho
    The pcv is routed to the catch can then back into the intake pre turbo. The other port in the valve cover is to atmosphere for now.
  12. Feb 28, 2019 at 9:46 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    My issues with o2 where air leaks usually. Never threw a code though. I did change out both o2 sensors a while back before I added more boost to clean it up. Helped a little because they were old. Hot starts I still have issue because my maf sensor heat soaks.
    How your drain flange with that oil leak? I only leaked out the turbine or compressor wheel. If you leak out of the center outside it's a plumbing issue
    Torspd likes this.
  13. Feb 28, 2019 at 9:55 PM
    Reh5108
    Idaho
    I put a scope in the previous owners afr port (now plugged) and didn't see any oil inside. This was after I let it cool so it could have burned off. It leaks in between the turbine housing and center housing. Going to double check the return line before ordering seals for the turbo.
    With how the ventilation system is routed from the factory I was definitely putting 5psi into the crankcase. I'm thinking @MrCrowntown may be right and I compromised the seals by doing that.
  14. Mar 1, 2019 at 4:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Are you using any oil rated Teflon tape, on that NPT barb fitting?
    Is that rubber hose, for the drain line, or PTFE(due to steel braid I ask.) ?
    Is there silicone, or a fiber gasket a between the center cartridge outlet and drain adapter flange?
    MadTaco461 and buyobuyo like this.
  15. Mar 1, 2019 at 10:18 AM
    Reh5108
    Idaho
    I used permatex high temp thread sealant on the oil feed barb. Just looked up the temperature rating and it's only 400°F. I was seeing 450°F with my temp gun. It doesn't appear to be leaking there though.
    I'm not sure what the return hose is made of.
    There's a fiber gasket between the flanges.
  16. Mar 1, 2019 at 10:52 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Ughhh I keep getting a p0101. I plan on trying to clean it but do you think it's worth replacing on a 12 year old maf sensor?
  17. Mar 1, 2019 at 11:08 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Take your air hose and see if there is any oil in the turbo housing / air hose.
  18. Mar 1, 2019 at 1:04 PM
    05Taco4x4
    2TR-FE Enthusiast
    Man sensor?
  19. Mar 1, 2019 at 1:06 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Autocorrect lol yeah I don't want a man sensor it was supposed to be maf
    MadTaco461 likes this.
  20. Mar 1, 2019 at 2:04 PM
    Reh5108
    Idaho
    I had the TB off the other day and there wasn't any sign of oil in the charge pipes that I noticed. It takes about 3 or 4 minutes for oil to start leaking out the turbo. This makes me think it's getting backed up and causing the leak.
    There was some old thread locker or something in the feed port when I replaced the female fitting with a male. I did my best to keep that from falling into the hole but I guess there's a possibility that a piece is stuck in there blocking things. I think I'm at the point of breaking down the turbo.
