Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 16, 2019 at 2:40 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    What else is a good/easy upgrade for the A340 (for up to 350hp)? I've been reading about it not having enough pressure at higher horsepowers and the clutches slip/burn. I know the stage 2 kits get kevlar clutch upgrades and billet pieces but, once again, I believe that's for those above 800hp
  2. Mar 16, 2019 at 3:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So just a clutch, or buy/build for 800/custom install for auto.....sounds like a fun adventure.
  3. Mar 16, 2019 at 3:33 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Lol good and easy dont go together with what you are wanting! I would reccomend going for the 800hp kit right away. Save time and heartbreak
    5 Lug Fury likes this.
  4. Mar 16, 2019 at 4:58 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    The transgo kit apparently increases the pressure that why I did it I was having a really slow 1st to 2nd engagement. The Kevlar clutches for sure and probably a nice fat trans cooler. Since your going a340f you already have a bigger fluid pan so alittle more cooling. If you creep on some Lexus forums you can find some info. Eventually I'm going to pick up a a340f and build it so I can convert to a 4wd. Also the a340f has an atlas 4 speed kit available.
    05Taco4x4[QUOTED] likes this.
  5. Mar 16, 2019 at 5:12 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    All this talk of transmissions... I'm wondering what the 3rd gen's AC60E/F transmissions will put up with...
  6. Mar 16, 2019 at 7:10 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Yes u can.
  7. Mar 16, 2019 at 8:03 PM
    05Taco4x4
    2TR-FE Enthusiast
    Someone in the OVTune turbo waitathon thread was asking and was replied Toyota uses it for a much more powerful vehicle overseas and wouldn’t be a problem.
    Brice likes this.
  8. Mar 16, 2019 at 8:16 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    "Waitathon" Good nickname. Tbh I ain't to enthused with the way he handles stuff. Imo he should have delayed any releases or indication of the product a couple more years.
    But if I'm honest the OVtune on my stock truck got me better mpg (or atleast caused a mind trick that did lol)
  9. Mar 16, 2019 at 9:16 PM
    05Taco4x4
    2TR-FE Enthusiast
    I think too much hype. These guys thinking they're going to slap on a turbo kit and get massive amounts of power. Woe to him, they aren't going to pull their engines, swap rods and pistons. And on what, open deck engine? It's already moved from twin turbo to single turbo. I'm not hating on him, but there's going to be a mass exodus when those guys get a better idea of what they have to put into it.
    And I aint building no 800hp transmission, I'd be lucky to get 350hp out my engine lol
  10. Mar 16, 2019 at 9:34 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I'm thinking like 250 to 300 lol
  11. Mar 16, 2019 at 9:36 PM
    MrCrowntown
    Alyn
    Ky
    Not with that mindset.. :anonymous:
  12. Mar 16, 2019 at 9:36 PM
    05Taco4x4
    2TR-FE Enthusiast
    A boy can dream
    5 Lug Fury[QUOTED] likes this.
  13. Mar 16, 2019 at 9:45 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Not to talk too much trash but I am pretty sure I did some googling a year or two ago when they hinted about a tune for the 2.7 and found a bunch of pissed off Mazda people complaining about the same sort of thing- vaporware that is hyped but never shows up.
    I'm toying with the idea of turbo or supercharger on my 2TR more as a "OEM Tune" style thing- imagine if it was equipped that way from the factory. Reliability as a chief priority, reasonably efficient, and a nice "driveable" power band that isn't anything nuts.
    Hit about 200HP and 225 TQ (crank numbers) and I would be thrilled to have it as a daily drive.
    I'd really like to be able to run it on regular gas but that is probably the first thing that has to go if you wanna make that number.
    And it's nice to see that the AC60s can hold up to about 300 lb-ft on "official" numbers that are usually pretty conservative.
    MadTaco461 and Brice[QUOTED] like this.
  14. Mar 16, 2019 at 11:03 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    When I first put the turbo on my truck I wanted it to feel like it was something that Toyota offered. It was a lot of fun for a few years.
    Now I want moar.
    I have a feeling ov tune going to end up following Tor build but for a 3.5. If he just made a header and downpipe, let the buyer get a haltech to tune it instead of flash tuning that ecu. Pnp turbo kit isn't that easy on these newer motors.
    Torspd and 5 Lug Fury like this.
  15. Mar 17, 2019 at 12:12 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Yeahhhhhh for me I was like hey this is pretty good ......I want more of it lol
    it makes the truck feel like it doesn't have 33s on it and I'm undergeared
    MadTaco461[QUOTED] likes this.
  16. Mar 17, 2019 at 12:17 AM
    05Taco4x4
    2TR-FE Enthusiast
    2TR with just 5psi is a completely different driving experience. It's climbing long steep grades on cruise 65mph at/below 5psi that would have me dropping into 4th and literally giving 100% throttle and maybe holding 55mph back when normally aspirated! I can actually accelerate when merging too.
    This could be done for a reasonable price.
  17. Mar 17, 2019 at 4:27 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I'm an ex Mazda3 Skyactiv owner. This was back in '14-'15 that went down. I'm glad someone else finally did a bit of research and realized what I tried to say waaaaay back in the OV 2.7 thread, they'll deliver "something" for the bigger engines and screw the little guys.
  18. Mar 17, 2019 at 9:21 AM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    What supporting mods did you need at 5 PSI? Gas grade, injectors, ECU, let me know some details! :D
    The main thing really holding me back is the fact that my truck is a DD and I don't really have an allowance for downtime while I figure out fabrication on parts.
    The setup I am imagining in my head is a little off the beaten path but what I would do is grab a reman IHI VF52 (2008+ WRX Turbo) which was mated with a 2.5L engine and made 256HP at about 14 PSI so I think the sizing would be right about spot on.
    The disadvantage would be that all the flanges except for the cold side inlet would need custom fab...
    [​IMG] [​IMG]
    Fortunately the aftermarket for these is massive so you can always mine ebay for used aftermarket goodies and then do a little :sawzall: on the flanges then a little :welder:onto your Toyota-based equipment.
    Then once the turbo is there, run the charge pipe straight over the top of the valve cover with an air/water IC not entirely unlike this crazy dude from Aussie land did to a Hilux:
    (hopefully a little less jank without lines and fittings exploding across creation...)
    Then run the IWG on the VF52 with a spring set to about 5 psi (It's stock is set to... 7 I think but there's a solenoid that alters the pressure to hit higher boost) and have the air/water IC run its hoses to the front of the truck.
    Toyota was nice enough to already give you holes and mounting points for the v6's tow package oil cooler, it would be downright rude not to use them! :D Plop a reasonably sized cooler there and a little spal fan over it, and boom...
    Again, the big problem with all this is that it is a lot of custom fabrication and I would not have a DD in the meantime.:bananadead:
    Boring, 5 Lug Fury and Brice like this.
  19. Mar 17, 2019 at 9:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Awe...c'mon. :boink:
  20. Mar 17, 2019 at 9:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You have a built engine. Aren't you already pushing 10 psi??? What max CFM does you turbo flow, or HP is it rated for?
