Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 19, 2019 at 12:08 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    No sir, I don't have an extra clutch
  2. Apr 19, 2019 at 12:41 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I never ran an EGT on my truck just because I'm not pushing it hard enough to need one right now. If I go above 20 psi then I'll consider it.
  3. Apr 19, 2019 at 7:16 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    With the weight of my truck and the long passes I drive I thought it was a good idea. Especially not being super confident in the stock ecu handling boost.
    MadTaco461[QUOTED] likes this.
  4. Apr 19, 2019 at 9:27 PM
    MadTaco461
    CA
    Kinda stock
    Running lean makes a difference. I run my stuff fat for the extra cooling and not trusting the ecu also
    05Taco4x4 likes this.
  5. Apr 19, 2019 at 11:57 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I have a few more things for sale if Anyone is interested...I’ll post a thread in the next few days but this may be of interest to some here.
    I have a 3” aluminum MAF adapter with flow straightener inside. It was used with the 1gr maf when I had it on my truck. Asking $50 shipped. If PayPal buyer pays fees or send as gift. I also take Apple Pay too.
  6. Apr 20, 2019 at 2:36 PM
    Reh5108
    Idaho
    ireymon, MadTaco461 and RedLantern like this.
  7. Apr 20, 2019 at 2:52 PM
    RedLantern
    Honolulu, Hi
    Wow maf pre turbo
  8. Apr 20, 2019 at 2:58 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I ran mine pre turbo as well.
    Torspd, Reh5108, MadTaco461 and 2 others like this.
  9. Apr 20, 2019 at 5:12 PM
    MadTaco461
    CA
    Kinda stock
    I like the staggered intake. Probably a small water drain at the bottom. If you can, stuff the largest filter you can get in there.
  10. Apr 20, 2019 at 8:23 PM
    Reh5108
    Idaho
    Decided to cut the corner off and hopefully fit my washer reservoir there. I'll put some rivnuts along the flange, add some weather stripping and put a piece of plexiglass on top.
    20190420_193314 by Ryan Heintzelman - Flickr2BBcode
    Good idea with the drain. The snorkel does suck in a good amount of rain/snow. I plan on ordering a custom afe filter with the guard 7 media. 5" long, 5 1/2" top diameter and 6" base diameter. I think that will be big enough. Going to give them a call though and ask before I order it.
    05Taco4x4, MadTaco461 and Torspd like this.
  11. Apr 22, 2019 at 9:04 AM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    Well my wife has agreed on a turbo build! When she gets a T4R and I take her car as a daily. I have an hour long commute to work so building the truck before having a daily isn’t really an option for me. hopefully within the next year I can start gathering parts. I’ve got a ton more research to do but thanks to everyone here I’ve got tons of knowledge to soak in.
  12. Apr 22, 2019 at 9:16 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Side note: I've used this meme 3 times in the last 5 mins... My kinda monday
  13. Apr 22, 2019 at 9:19 AM
    jfoster92
    Justin
    Farmerville, la
  14. Apr 23, 2019 at 5:56 PM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Came across this....old but something Ive been looking for. Seriously debating building this 5vz fully out or swap a V8 but Im highly inclined to think of how cool a 1000hp or so 5vzfe would be. All Toyota OEM minus turbos etc.
    01:06 PM 02-02-2012
    #68
    Gadget@URD
    The power record as far as I know is 1600 crank HP. This was a dedicated drag car from a race team in Florida. They had a sponcership from TRD and their engines were built for them.
    TRD tried to switch them to the 1GR and the blocks would fail between 800-1000 HP. They dropped the sponcership and went to the 2JZ and URD bought all the old 5VZ parts they had. One rotating assembly went into Brian's 4Runner and one was supposed to go in my 4Runner, but Brian sold it off with the rest of the stuff instead.37620d1294454596-attempting-turbo-4runne_6f34627a09af3639dd9894bbc708ee7f29c806a6.jpg
    There is a picture of Brian's 4Runner with an estimated crank HP of 1200. Everything in the drive line kept breaking and each part was addressed one at a time. It was depowered and depowered and depowered so it was not so scary to drive. Estimated power level was down to less than 800 and it was run in all wheel drive mode all the time. The last engine management used was Weber RedLine. The death nail of the project was a former TRD engineer/engine builder talked Brian into a reversed cooling system. I knew it was a super bad idea and it would never work, but more URD funds were poured into it and yep it was a big fail. The engine was pulled once again to put the cooling system back to stock and it was never finished. The vehicle was given away and should now be one bad ass SAS off road runner with a 1GR driving it now. The engine and turbo system was parted out and that was that. Was a pretty cool project and very scary to drive. G
    BassAckwards, RedLantern and Reh5108 like this.
  15. Apr 23, 2019 at 7:54 PM
    Reh5108
    Idaho
  16. Apr 28, 2019 at 4:39 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Gonna take delivery of my motor this Thursday!!
    :goingcrazy:
  17. Apr 28, 2019 at 4:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  18. Apr 28, 2019 at 4:41 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Juuuuust kidding!!!
  19. Apr 28, 2019 at 4:42 PM
    MrCrowntown
    Alyn
    Ky
  20. Apr 28, 2019 at 4:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
