Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 28, 2019 at 4:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Soon to be VERY exciting! Makes me want to swap cams out ASAP!
  2. Apr 28, 2019 at 4:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Who's doing the tuning? You knocking it out, or taking it somewhere?
  3. Apr 28, 2019 at 4:50 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Well, next big hurdle, is getting my truck out here lol
    Then i'll probably steal(cough), or utilize @05Taco4x4 map and build off of that on my own. Just street tune stuff to learn. I have to do some serious local searching for a good dyno.
    Anyone know of anyone good around the western KY area? :confused::D
    MadTaco461 likes this.
  4. Apr 28, 2019 at 4:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hmm. Sounds fun. Lol
  5. Apr 28, 2019 at 9:57 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Bet if you look North into Indiana there probably some good shops.
    MrCrowntown[QUOTED] likes this.
  6. Apr 29, 2019 at 9:35 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Turbo kit instructions unclear; ended up with a 2019 Civic Si. :confused:
    My access cab has no rear seats (utility package) and I was looking for an addition to the stable that's a little more... sedan-like and fuel efficient. Turns out the Civic Si checks all sorts of boxes- only available with a 6MT, turbocharged (20 PSI from the factory!! :eek:) and it's got all sorts of cool tech on it like adaptive suspension. Really darn good value for a ~25K MSRP and it gets 38 MPG on the highway. So I figured I would sate my turbo craving this way.
    In the meantime at least. :devil:
    Brice, skyking3, Torspd and 1 other person like this.
  7. Apr 29, 2019 at 9:53 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Nice! I love the Type R with the turbo but I was a bit disapointed the SI used a turbo 1.5L. IMHO, the SI should have stayed N/A with a high rev 1.8 or 2.0L engine.
  8. Apr 29, 2019 at 12:23 PM
    MadTaco461
    CA
    Kinda stock
    If my car dies that will probably be my next dd. Already looks like there is a bunch of aftermarket if you want to go down that rabbit hole.
  9. Apr 29, 2019 at 3:45 PM
    MrCrowntown
    Alyn
    Ky
    I think i am going to use Freedom Racing Engines to dyno :cool: theyre out of indiana
  10. Apr 29, 2019 at 9:16 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    I feel like a detuned 2.0T related to the Type R would have been cooler than an up-tuned 1.5T from the EX-T trim, and I do understand that traditionally "Honda" and "8K Redline" go hand in hand...
    That said, the way this thing's powerband hits is... damn impressive. 192 foot pounds from 2100 all the way to 5000 RPM! :eek: It gives me that same instantaneous spool giggles that my modded Mk4 VW GTI from years gone by did, only now it has an LSD so no torque steer.
    And apparently this little 1.5 is quite strong, people have been beating the piss out of them at power levels exceeding 300 HP with no windowed blocks so far... supposedly 400 is the stock internals limit but I have no intention of testing that...
    Oh yes there is... which is awesome. Honestly though the state of tune it ships factory is pretty darn agressive and to my mind, what would really make it shine is some beefy "supporting mods" (Bigger IC, heat wrap, silicon boost hoses, and so on) and I do plan on doing some of that.
    MadTaco461[QUOTED] likes this.
  11. May 1, 2019 at 7:39 AM
    MrCrowntown
    Alyn
    Ky
    Christmas in May :transformer:
    RedLantern, skyking3, Depoxy and 9 others like this.
  12. May 1, 2019 at 9:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Whooooooooohoooooooo! Man am I excited for you!
    MrCrowntown likes this.
  13. May 1, 2019 at 9:13 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  14. May 1, 2019 at 9:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So, @MrCrowntown . Have it in, tuned, and here by this weekend's Coffee and Cars?
  15. May 1, 2019 at 9:44 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I missed it, what is in the crate?
  16. May 1, 2019 at 9:48 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Its the turbo spooler.
    buyobuyo and loginfailed[QUOTED] like this.
  17. May 1, 2019 at 10:57 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I figured that much, but curious what the specs are.
  18. May 1, 2019 at 12:02 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :woot:
  19. May 1, 2019 at 3:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I want to say, but I also don't want to take that away from him.
    loginfailed[QUOTED] likes this.
  20. May 1, 2019 at 5:42 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I assume it was posted previously somewhere, but I got tired of clicking the little back arrow.
