Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 9, 2019 at 10:42 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    He needs to make sure he did it with the throttle fully open as well. Those numbers are way too low. I would recommend redoing the compression check
    Torspd and 05Taco4x4[QUOTED] like this.
  2. May 9, 2019 at 10:46 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Never heard of keeping the throttle open but I can totally redo the test when I prepare for a leak down test.
    Thanks I'm going to try cleaning them first before I think about replacement. It wouldn't surprise if some of them are clogged from dirty oil.
    05Taco4x4[QUOTED] likes this.
  3. May 9, 2019 at 11:47 AM
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    Not saying this is the cause, but my recommendation from my own personal experience is ensure there are absolutely no boost leaks before doing any work on tuning. Everyone with a forced induction car that also works on their own shit should have a boost leak tester, and use it not only when setting up their system for the first time and tuning, but periodically as well.
    Nothing wildly expensive or fancy is needed either. Just a source of compressed air, and a simple coupler with a gauge. This is basically the type I use:
    buyobuyo likes this.
  4. May 9, 2019 at 12:27 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Go back a few pages unless you talking about the older 2.7s
    Taco critter likes this.
  5. May 9, 2019 at 6:14 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Pop into my build thread for more . Feel free to ask whatever. I'm still new to the forced induction world so still figuring things out.
    20190504_184611 by Ryan Heintzelman - Flickr2BBcode
  6. May 9, 2019 at 7:40 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    File off corners
    Make sure clears hole
  7. May 11, 2019 at 9:50 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    That's really clean man.
    So I reran the compression test and still got around 125 psi
    I then did the leak down test which showed all cylinders had the same amount right between yellow and green zones.
    Sooooo now I believe the lash adjusters need a good cleaning/replacement. Do we know if it's possible to remove/install them without removing the cam or messing with the timing chain?
    05Taco4x4[QUOTED] and Torspd like this.
  8. May 11, 2019 at 9:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I really like what you've done here.
  9. May 11, 2019 at 9:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MrCrowntown, 5 Lug Fury and 05Taco4x4 like this.
  10. May 11, 2019 at 9:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is good news.
  11. May 11, 2019 at 10:02 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Are you doing the compression test cold or warm? The FSM calls for doing the compression test with the engine warmed up to operating temp.
    http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/00800110.pdf
    Section 10 on page 3.
  12. May 11, 2019 at 10:03 AM
    05Taco4x4
    2TR-FE Enthusiast
    You do have to remove the cams to get to them
  13. May 11, 2019 at 10:24 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I did the test cold both times because I didn't want to risk stripping the plugs. So that means my numbers should be even higher when hot. I'm just glad they tested all the same.
    Ughhhhhhhhhhhhhhhhhhhhhhhh I don't like that. So doesn't that also mean timing chain, timing cover and the whole front of the engine?
    Yeah I'm glad the valves are ok although if something more serious was wrong I'm pretty sure I would have been driving as much as I have been. I don't thin I've had any loss in power just more ticking sound.
    Torspd[QUOTED] likes this.
  14. May 11, 2019 at 11:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. May 11, 2019 at 12:06 PM
    Reh5108
    Idaho
    I found a used setup. I'm in about 2250. I can weld so I was able to save money making my exhaust.
    I was thinking about turboing my T100 as cheap as I could. Just added a bunch of stuff to my ebay cart and it totalled around $1500. Not quality parts by any means.
  16. May 11, 2019 at 12:14 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    The good thing about all of the 4 bangers is there are turbo manifold available and they are pretty cheap and save a ton of fabrication
  17. May 11, 2019 at 10:49 PM
    05Taco4x4
    2TR-FE Enthusiast
    I've seen pics of guys zip-ting chain in place on sprocket, so don't have to remove front cover and chain stays in correct place... loosen bracket and lift, swap adjuster etc. If you take your time it could go by quickly :thumbsup:
  18. May 12, 2019 at 5:53 AM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Updates?
    Vacation lol
  19. May 12, 2019 at 7:44 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    How much boost is that ?
    05Taco4x4 and yota243 like this.
  20. May 12, 2019 at 8:06 AM
    05Taco4x4
    2TR-FE Enthusiast
    :oldglory:
    MrCrowntown[QUOTED] likes this.
