Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jun 3, 2019 at 10:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Shoot, almost done at this point! Great fitment.
  2. Jun 3, 2019 at 10:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Properly torqued pressure plate bolts prevent this.
    Literally an unevenly worn flywheel surface.
    Lucario Runner likes this.
  3. Jun 3, 2019 at 11:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Lucario Runner
  4. Jun 3, 2019 at 11:01 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Didn't slip doe
  5. Jun 3, 2019 at 11:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Edited above
  6. Jun 3, 2019 at 11:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Where did you purchase the wiring adapters from?
  7. Jun 3, 2019 at 11:26 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Made them
    Torspd likes this.
  8. Jun 3, 2019 at 11:36 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Commanded intake advance. Actually same values for "stg 3" and stock tune. I never touched my cam profiles on my car. You can open a csv file with excel and see what the car does for actual values. Can also import this into Virtual Dyno.
    05Taco4x4[QUOTED] and Torspd like this.
  9. Jun 3, 2019 at 11:43 AM
    MadTaco461
    CA
    Kinda stock
    I was happy that the 3 levels removed of fixtures still landed the turbo in the same spot. Few more tweaks and it should be there.
    05Taco4x4 and Torspd[QUOTED] like this.
  10. Jun 3, 2019 at 12:29 PM
    05Taco4x4
    2TR-FE Enthusiast
    Thank you.
    The tunes Haltech provides uses RPM and vacuum/boost on axis, is their default so that’s what I’ve been using.
    I haven’t done much any work with logs yet because of my clutch situation.
  11. Jun 3, 2019 at 1:39 PM
    MadTaco461
    CA
    Kinda stock
    Yeah this tune is a hybrid of load based and boost based tuning. Load based just accounts for temp and elevation which make it a bit more stable. A boost based y axis will look pretty close to the same. I tune my truck with boost based. Clutch slip isn't fun.
    05Taco4x4[QUOTED] likes this.
  12. Jun 4, 2019 at 11:24 PM
    05Taco4x4
    2TR-FE Enthusiast
    I would like to put together a Haltech base file for the 2TR. I have quite a bit of info, sensor calibrations and such, but not enough. Would you mind contributing stock info, such as the timing and cam table? You're the only one that can accurately provide this. My goal is to safely get guys up and running on a Haltech, as if still on their stock ECM.
  13. Jun 5, 2019 at 6:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My goal is to get @mnovak running on the Haltech with his 2TR....
  14. Jun 8, 2019 at 10:38 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Well I finally got the truck back together today and the sound is still there. I think it's coming from my split gooch. It's gotten alittle louder and now it seems like exhaust noise than a lifter
    MadTaco461 and 05Taco4x4 like this.
  15. Jun 8, 2019 at 12:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    One problem solved, one to go. You'll get it. I have all of the faith.
  16. Jun 8, 2019 at 1:52 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Thanks...I'm just not a fan of wack a mole lol
  17. Jun 8, 2019 at 1:55 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sometimes solving a problem uncovers others that need attention. It was a good thing you were in there.
  18. Jun 9, 2019 at 2:03 PM
    05Taco4x4
    2TR-FE Enthusiast
    Finally did a compression test and looked at spark plugs, pretty much same across the board.
    I forgot to open the throttle :facepalm:
    BassAckwards, Torspd, Brice and 2 others like this.
  19. Jun 9, 2019 at 4:12 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Seems pretty good no? :notsure:
  20. Jun 9, 2019 at 6:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It has started.....
