Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 21, 2019 at 6:03 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Only knew because I subscribe to The Skid Factory channel and watched that video recently.
    05Taco4x4 and Jcyr like this.
  2. Dec 21, 2019 at 6:27 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    I figured it out as soon as I posted asking for help i just was pulling at straws before pulling the motor again. On the bright side i can pull the motor real quick now
    05Taco4x4 and buyobuyo like this.
  3. Dec 21, 2019 at 7:00 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You'll never forget now though. Lesson learned.
    buyobuyo likes this.
  4. Dec 22, 2019 at 4:59 AM
    Jcyr
    Jack
    North east
    It was my first time mating an auto tranny. I much prefer manuals for pretty much everything but I Will admit autos for the most part are the future
  5. Dec 22, 2019 at 7:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They are pretty much the present
    MrCrowntown, Jcyr and 05Taco4x4 like this.
  6. Dec 26, 2019 at 2:52 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Does anyone on here run a TD04 turbo on their build? If so how did you get the coolant to the turbo and where did you return it to?
  7. Dec 26, 2019 at 3:12 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You can use the coolant loop from the throttle body and EGR. Also could splice a T at the heater core.
    BananaMan[QUOTED] and Jcyr like this.
  8. Dec 29, 2019 at 4:50 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I tapped into the heater core. Don't use plastic T's. I just ordered some metal one that I think some ford's use. 5/8x 3/8. I did just notice the I have a leak at the valve. Hopefully that plastic isn't degrading as well.
    BananaMan[QUOTED] likes this.
  9. Dec 29, 2019 at 4:59 PM
    Reh5108
    Idaho
    What are the likely places that I was able to dump over a quart of oil out of the turbo in 5 miles and then it stops? I still had oil and topped off. Was fine after that. Probably shouldn't have continued to drive it with it leaving a smoke cloud that would make a diesel proud but it was Christmas and I had places to be.
    My first thought was that my oil return was clogged up but I just pulled it apart and it's clean. I will say that it was a cold morning. Temps were probably near single digits. I suppose something could have been frozen.
    So how many places is it possible to dump that much oil in such a short time and then it stop and be seemingly fine?
  10. Dec 29, 2019 at 5:27 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    If you were smoking out the tailpipe, I'd say oil had to be leaking past the seals into the exhaust housing. Your guess of a clogged return line sounds plausible if it was single digits. It could have had some condensation that froze and clogged it. Once the engine bay warmed up enough, it would melt, and the problem would clear itself.
    Reh5108[QUOTED] likes this.
  11. Dec 29, 2019 at 6:29 PM
    Reh5108
    Idaho
    That's my best guess as to what happened for now. Decided to pull it all apart and inspect things.
    Found this. Not sure if it's from it being on fire or if it got that hot.
  12. Dec 29, 2019 at 6:43 PM
    Jcyr
    Jack
    North east
    Looks to just be deteriorating. What wrap did you use? I’d bet past the seal too
  13. Dec 30, 2019 at 7:04 AM
    Reh5108
    Idaho
    Ledaut. Something off Amazon.
    I was referring to the flange starting to deteriorate
  14. Dec 30, 2019 at 7:59 AM
    BananaMan
    If that flange got hot enough to ruin the temper and compromise it.... :bananadead:
  15. Dec 30, 2019 at 9:10 AM
    Jcyr
    Jack
    North east
    I wouldn’t use heat wraps on anything in a snow state. It traps moisture and causes crevice corrosion in cold weather states. It’s also notorious for shortening life of headers.
  16. Dec 30, 2019 at 11:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mild steel is my hypothesis. Only ever seen mild steel flanges crumble apart, in that exact same manner.
    As for the smoke show, that is something else.
    Reh5108 likes this.
  17. Dec 30, 2019 at 12:07 PM
    Reh5108
    Idaho
    I believe the pipe is stainless. The flanges is definitely not.
  18. Dec 30, 2019 at 12:41 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You've a welder, right?
  19. Dec 30, 2019 at 12:46 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    His last name miller or Lincoln? I actually went to school with a holbert...
    Torspd[QUOTED] likes this.
  20. Dec 30, 2019 at 1:09 PM
    Reh5108
    Idaho
    I have access to one.
