Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jan 8, 2020 at 4:43 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    That’s a nice kit. I’m honestly considering it. Might be better than venting to atmosphere
    RedLantern[QUOTED] likes this.
  2. Jan 8, 2020 at 10:29 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    would it not wind up there if it recirculated back to the intake anyway?
  3. Jan 8, 2020 at 10:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct
    yota243[QUOTED] likes this.
  4. Jan 8, 2020 at 2:53 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Yes but it gets burnt before going to the cat.
  5. Jan 10, 2020 at 9:21 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Yeah, top row split in the gulley. I cut it out and replaced with tubing. So far so good. Glad the leak is gone, the noise was getting worse and annoying. There was a bit of lost power too, response is better now.
  6. Jan 12, 2020 at 4:47 PM
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    Trying searching mayne people here are better then me with that deal. Im ordering an aem pump for my truck? Are the pumps the same for 05-15 between 1gr and 2tr, i have a 2tr so if anybody has the correct part number that would be the best. Thanks. Once step closer to the turbo setup.
  7. Jan 13, 2020 at 10:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The AEM pump is universal. So how you go about installing it may be slightly different than for the 1GR.
    Check out www.urdusa.com. They should have a fuel pump kit, and then you select which pump you want to go with the kit.
  8. Jan 13, 2020 at 11:49 AM
    Bloodytaco208
    Ok thank you. Yeah i saw theyre kit i was just going to order the pump myselffrom a different dealer i just didnt know if it took an offset or inline pump so to say. Sorry to derail yall conversion.
  9. Jan 14, 2020 at 5:52 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I am running an AEM 50-1000 in my 2TR, its a 340Lph
    Bloodytaco208[QUOTED] likes this.
  10. Jan 15, 2020 at 9:36 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I had used the same hoses, and actually had one rupture on cooldown in my driveway...just as an FYI.
    I since switched to a Kinugawa braided AN kit, and also threw some heat shileding over them for extra protection from the turbine housing (Which was also under a turbo blanket).
  11. Jan 15, 2020 at 9:40 AM
    Jon64l
    Jon
    Interesting. I have some heat wrap around the one closest to the turbine, no problems so far.
  12. Jan 15, 2020 at 6:10 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Jcyr likes this.
  13. Jan 19, 2020 at 8:53 PM
    Bloodytaco208
    Yeah thats what i ordered. After i got the pump and sending unit in it was a pretty simple task.I just got the pump installed, clutch from lce (300whp) and new flywheel, and finally got the fitting drilled and tapped for my trubo oil retun. Now i just needs some fitting and such and its turbo time. Goal is to have it forced induction in two weeks. I ordered the tial 4.6 psi boost actuator for my GT2871R
  14. Jan 20, 2020 at 4:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good turbo selection. That is the size that I keep telling my friend to get for his 2TR. Keep us updated.
  15. Jan 21, 2020 at 5:37 AM
    yota243
    E.J.
    north Alabama
    So it was 23° this morning and my truck wouldn't start... I have the command afr gauge on torque and it was at ~5:1 while trying to crank which seems a little rich to me but what do I know? Apparently it needs even more fuel based on what this guy did, is there anything like this in the mapecu3 software?
    https://youtu.be/1cblVCOnt0Y
  16. Jan 21, 2020 at 7:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cold start enrichment. I don't know about on the MAP-Ecu. @MadTaco461 may know? Figure that the OEM ECU would still take care of that.
  17. Jan 21, 2020 at 9:36 AM
    Bloodytaco208
    Did it smoke at all while cranking? Stutter while cranking?
    Or did it just crank?
  18. Jan 21, 2020 at 9:38 AM
    Bloodytaco208
    Anybody run no cats with there turbo setup with urd o2 simulator?
  19. Jan 21, 2020 at 9:39 AM
    yota243
    E.J.
    north Alabama
    It would hit 1 lick every 3 or 4 seconds. Yesterday it was 27° or so and it fired up and ran for a few seconds and died but the 2nd time around it acted kinda right and stayed running
  20. Jan 21, 2020 at 9:42 AM
    yota243
    E.J.
    north Alabama
    Yes... I feel like questions will ensue long the lines of "how is that working for you" to which I will reply, "I always have check engine light on for one reason or another, but its almost never cat related"
    Torspd likes this.
