Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 26, 2020 at 3:48 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Low manifold pressure at low rpm and low throttle position is most likely late intake valve closing. I don't know your cam profile, but when your manifold pressure shoots up your piston is pumping a bit of air back into your manifold before your valve closes. That increase of pressure helps with pumping loss. That is mostly for emissions with little to no change in performance.
    05Taco4x4[QUOTED] likes this.
  2. Feb 26, 2020 at 5:53 PM
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    Oh thats already done i went 4.88 with an arb in the front and the true trac in the rear with a twin stick fj transfer case.
  3. Feb 26, 2020 at 5:55 PM
    Bloodytaco208
    Usually if you have oil in your exhaust you have blown your turbine seal. If you have pre turbo thats even worse. Might have to yank it off and reseal it
  4. Feb 26, 2020 at 6:23 PM
    Bloodytaco208
    Vaccuum is dictated by many things such as how far the valve opens up, throttle plate position, load or no load, and altitude. The less vacuum the less parasitic drag forced on the piston. Like a syringe the diameter of the piston and the diameter of the opening dictate how difficutl it is to pull back( the viscosity of the fluid plays a part). Atmospheric pressure in a naturally aspirated engine plays a big part with vacuum. I mean it can get pretty involved especially if its diesel or gas direct injected or indirect injected. If you start playing with vvt im guessing with your 2tr fe? I havent started tuning yet but that is a big chunk what i have learned. I deal with mostly diesels and we usually dont worry about vacuum
  5. Feb 26, 2020 at 6:37 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I had oil everywhere but journal bearings and stuff so... I had it off today but its back on now
  6. Feb 26, 2020 at 7:17 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should have gone 5.29s for 35s
  7. Feb 26, 2020 at 8:53 PM
    Bloodytaco208
    The 5.29's in our trucks are very temperamental and are prone to break
    Torspd likes this.
  8. Feb 26, 2020 at 9:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah? according to who?
    Thats a myth man. haha they are actually stronger than your 4.88s.
    Zuk the gear god of toyota's even proved it on his site.
    Also..mine are doing fine
    [​IMG]IMG_0123 by Benjamin Springli, on Flickr
    BananaMan likes this.
  9. Feb 27, 2020 at 7:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Material strengths can overcome leverage forces.
    Bloodytaco208 likes this.
  10. Feb 27, 2020 at 7:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just started messing with the VVT-I aspect of the Haltech, eh?
  11. Feb 27, 2020 at 8:18 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I’ve had it working but the table was populated with another vehicles’ tune (still is).
    I’m playing with the injector timing now, which is honestly a waste of my time because I don’t know what I’m doing. I wish I knew a tuner I could just drop it off and say “here, have fun and I’ll see you in a couple days”.
  12. Feb 27, 2020 at 8:20 AM
    05Taco4x4
    2TR-FE Enthusiast
    A lot of my tables are borrowed from other tunes, no idea what I’m doing with those. I have all the sensors calibrated, that I could do. I really do need to find a tuner.
  13. Feb 27, 2020 at 9:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which vehicle did you use to setup your VVT-I solenoid?
  14. Feb 27, 2020 at 9:58 AM
    05Taco4x4
    2TR-FE Enthusiast
    2JZ got me real close
  15. Feb 27, 2020 at 12:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Compare against the Lexus IS300 in your file. That one is the closest. Their map is actually the same as what was found on the 1GR Tacomas, when HP Tuners was able to view it.
    05Taco4x4 likes this.
  16. Feb 27, 2020 at 12:56 PM
    05Taco4x4
    2TR-FE Enthusiast
    It's the same, that IS300 is a 2JZ haha
  17. Feb 28, 2020 at 4:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Haltech must have updated their files then. The JZ ones didn't have the proper compatibility, when I was comparing.
  18. Feb 28, 2020 at 6:07 AM
    yota243
    E.J.
    north Alabama
    I pulled a little more fuel and it seems to pike it a little better... I may have to add a drop or two back afrs blip to 13 on the shift when load increased. Also going from a coast to wot the lag seems intensified becauae of all the vacuum I have to overcome, but in normal driving it pulls pretty great
    https://youtu.be/NcOYwuQF4Ls
  19. Feb 28, 2020 at 6:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Moving the quickest I have ever seen yours move!
    yota243 likes this.
  20. Feb 28, 2020 at 6:32 AM
    yota243
    E.J.
    north Alabama
    Really since 33s are ~8% taller than stock that is almost a 30-90 pull in ~8ish seconds and im ok with that
    MadTaco461, Torspd and buyobuyo like this.
