Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 13, 2020 at 10:51 AM
    BeachyTaco
    BeachyTaco Active Member
    Brandon
    Spokane, WA
    2010 Tacoma
    Broken Motor
    Picked up the truck about a month ago with a bad motor, previous owner said cylinder 4 was like 10psi, motor does still start and run, but very rough obviously.
    I got the idea of boosting it, and came here. It's the current motor, and I'd like to get the truck going and usable, but I also only want to "buy once, cry once" if I'm going to go turbo. However, I haven't pulled the motor yet, so I'm not even sure if the motor is free of serious damage.
    I may go the "buy a second and swap in, build slowly" route, but obviously that's more funds.
  2. Mar 13, 2020 at 10:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well if you're going to boost it, and rebuild it, then contact www.lceperformance.com. Get some forged pistons, since you'll already be in there.
    MrCrowntown likes this.
  3. Mar 13, 2020 at 11:01 AM
    BeachyTaco
    Brandon
    Spokane, WA
    2010 Tacoma
    Broken Motor
    Yeah, that's what I had planned on doing, as well as the balance shaft delete, etc. while I'm at it, but more-so looking for feedback on if anybody has had theirs rebuilt and what it cost them.
    Also looking for feedback on if anybody has run that level of power in the woods and if it made the truck unusable or if they loved it.
  4. Mar 13, 2020 at 11:07 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    That's really going to depend on each persons driving style/suspension and gearing setup. Modern rigs with v8's are pushing close to that already, so I'd say it's definitely usable. It's also going to depend on what size turbo you're running and how much lag you have or lack thereof. Tons of variables that will essentially boil down to "your mileage may vary"
  5. Mar 13, 2020 at 11:25 AM
    BeachyTaco
    Brandon
    Spokane, WA
    2010 Tacoma
    Broken Motor
    Totally understandable. Part of me just wants to put a V8 in it and call it good, but everybody does that. Final goal of truck has yet to be decided, but it will likely end up with quality suspension of some kind (fox, king, ads, etc.) and may even end up with an LT up front.
    But, I do know that I want moar powa' baby
    BananaMan[QUOTED] likes this.
  6. Mar 13, 2020 at 11:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @05Taco4x4 has built his engine. He could give you a rough idea.
  7. Mar 13, 2020 at 12:38 PM
    BananaMan
    I've got a shopping list of parts a half mile long it feels like. Last time I counted.... 3k just in quality parts?
    BeachyTaco and Torspd like this.
  8. Mar 13, 2020 at 12:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That isn't a bad price at all, considering I'm out to power that the 3rz and 2tr can handle.
  9. Mar 13, 2020 at 12:51 PM
    BananaMan
    Yeah, it's the machining work that I don't know the price of yet, and I'm slightly apprehensive of. But I'm assembling mine myself so hopefully I save some pennies there.
    You're out to power? Huh?
  10. Mar 13, 2020 at 12:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Blasted talk-to-text ruined what I was trying to state. Lol.
    Edit, the amount of power that they can handle.
  11. Mar 13, 2020 at 1:06 PM
    BananaMan
    Haha autocorrects son strikes again!
    I've seen folks speculate that the 2tr can make and possibly hold 600hp without being billet everything. My goal is to eventually get the truck up to about 400ish whp, But starting small at 200-250.
  12. Mar 13, 2020 at 1:58 PM
    BeachyTaco
    Brandon
    Spokane, WA
    2010 Tacoma
    Broken Motor
    That being said, what are people putting behind them for a trans/drivetrain? I'm sure 600hp would absolutely grenade the stock trans & rear-end on a stock Taco
  13. Mar 13, 2020 at 2:12 PM
    BananaMan
    There's a couple good posts and threads on here about the stock trans holding power, especially the automatic a340 that's also in the Supra. Apparently with a shift kit and 2800 stall converter it's pretty stout
  14. Mar 13, 2020 at 2:13 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Squirt a little Lucas in em both and :burnrubber:hahaha
  15. Mar 13, 2020 at 2:46 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Not bad prices as long as the work is solid.
    If you dont wanna cry later, get forged pistons. You will need to let your engine warm up longer than if you have hypereutectic pistons, but theyll be ready to take a boost beating. Get new forged rods too. Stock crank is able to hold all the power you can ever want.
    If theyre going into the head, look at getting hardened valve seats and valves with double valve springs. The stock springs are whack and will float when you start revving out under boost.
    Also be prepared to get a piggyback ECU to control the engine. Stock ECU will have limitations if your goal is 400hp
    BeachyTaco[QUOTED] likes this.
  16. Mar 13, 2020 at 2:47 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    If it is a dirt truck with power, will most likely need a built trans and rear end. Street can handle more power for easy stuff like pulls and hitting the canyons.
    BeachyTaco likes this.
  17. Mar 13, 2020 at 10:02 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I've done some technical rock crawling in mine and think the turbo is a big plus. I'm only running 4.5psi. The engine doesn't stall as easily and with the high loads boost builds pretty quickly. I'm sure with a boost controller you could smooth things out if youre running high pressure. The stock ecu is terrible for boost in the sub 4500rpm range on mine.
  18. Mar 17, 2020 at 10:02 PM
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    Anybody have the 2.7 2trfe mapecu wiring diagram handy? Or is everybody dead from corona?
  19. Mar 18, 2020 at 7:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I wish my buddy did. :bananadead:
    Bloodytaco208 likes this.
  20. Mar 18, 2020 at 8:31 AM
    MadTaco461
    CA
    Kinda stock
    Only way I know is cross reference from the fsm.
